SW86 Posted January 6, 2011 Share Posted January 6, 2011 let it rape my wallet for gas money. soon he'll get long arms and a new trac bar thrown off on there. not to mention new ball joints too and then can you say 1 ton steering set up :drool: and i wonder where my money goes sometimes :shake: but hey do it right the first time and there won't be a second Link to comment Share on other sites More sharing options...
comanche12 Posted January 7, 2011 Share Posted January 7, 2011 done grind and finally cj7 rotor fit over flange that i grinded mock up picture Link to comment Share on other sites More sharing options...
ComancheKid45 Posted January 7, 2011 Share Posted January 7, 2011 Put a few miles on the Eliminator :D Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 7, 2011 Author Share Posted January 7, 2011 I looked at it. thought about how it should be back on the road. shed a tear. then went and looked at the other one. thought how it never shoulda ended up in the condition it's in, then made wild plans for a supercharged 3800 to replace the nat. asp. one... then went back inside without accomplishing anything else. work's a b*tch Link to comment Share on other sites More sharing options...
comanche12 Posted January 7, 2011 Share Posted January 7, 2011 done grinding the driver side rear axle shaft flange. also done trim the custom flange to let caliper sit closer to rotor so pads will able wear out even and best contact Link to comment Share on other sites More sharing options...
Jakeman17 Posted January 7, 2011 Share Posted January 7, 2011 Drove it Link to comment Share on other sites More sharing options...
comanche12 Posted January 8, 2011 Share Posted January 8, 2011 Drove it how its ride goes? i just finish clean the clogged heater core out. its take me about a gallon of water to clean it sh*t out. now i have heat blowing inside my mj :banana: still gotta to fix the over heat issue. look how its dirt after unclogged. there more than jsut this amount. aboue a gallon. I havent took the pic. plus ingore the color red its transfluid Link to comment Share on other sites More sharing options...
Jakeman17 Posted January 8, 2011 Share Posted January 8, 2011 Loading it with tires Link to comment Share on other sites More sharing options...
Herc Posted January 9, 2011 Share Posted January 9, 2011 Picked up a double hoop rollbar to put in my MJ in the spring once I've Herculined the bed! Link to comment Share on other sites More sharing options...
Pete M Posted January 9, 2011 Share Posted January 9, 2011 working on water pump and thermostat... you guy won't believe me what i just found out when i just pulled the thermostat housing... there NO thermostat at all! :eek: :nuts: . why hell pervious owner never get bother to add it to keep operation temp proper on engine??? good thing that I'm gonna to replace thermostat and water pump too! :thumbsup: chances are that the previous owner mistakenly thought pulling the thermostat would help with overheating. Link to comment Share on other sites More sharing options...
johnnyc Posted January 9, 2011 Share Posted January 9, 2011 Went to play in the snow. First run with the new BFGs. Link to comment Share on other sites More sharing options...
Dirteatr717 Posted January 9, 2011 Share Posted January 9, 2011 Nice^ and I loaded mine up with tires too... A sweet set of (5) 33/12.5s can't wait to slap em on :banana: Link to comment Share on other sites More sharing options...
Automan2164 Posted January 9, 2011 Share Posted January 9, 2011 Well, I have been putting off doing another axle sawp on the ZJ, but finally can't put it off any longer. So... I had to bring the unicorn out of retirement, and get it ready for DD status. It had a flat on the front left, but it ended up being the valve stem. Since I have no way to bust it down and put a stem in it, I put on the spare wheels and tires I had laying around. Should have done it a lot sooner. Before: On baby little 215 snow tires and Elim wheels. Now: Meaty 235's on black spraypainted XJ rims. I also had to move the Farmer out of the garage, in prep for the ZJ moving in. Sigh... I wish I could be spending money on the Farmer, but the ZJ is the somewhat reliable DD in need of attention. Rob L. :cheers: Link to comment Share on other sites More sharing options...
MJRemi Posted January 10, 2011 Share Posted January 10, 2011 Dropped off the 88 at a mechanic who was highly recommended by a friend that has an XJ. Two things need to be done asap. Needs to pass smog ( running SUPER rich ) and having the AX15 installed. Should get it back next week. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted January 10, 2011 Share Posted January 10, 2011 Sprayed the salt off my 88 this morning.....thats about the extent of my work today. I Drool over that 92 everytime i see it Rob :drool: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 10, 2011 Author Share Posted January 10, 2011 pulled the tan dash out of it, going to put the OEM black and agate interior that I have into it. woohoo.... Link to comment Share on other sites More sharing options...
comanche12 Posted January 10, 2011 Share Posted January 10, 2011 working on water pump and thermostat... you guy won't believe me what i just found out when i just pulled the thermostat housing... there NO thermostat at all! :eek: :nuts: . why hell pervious owner never get bother to add it to keep operation temp proper on engine??? good thing that I'm gonna to replace thermostat and water pump too! :thumbsup: chances are that the previous owner mistakenly thought pulling the thermostat would help with overheating. Maybe? All I know that my mj didn't take good maintenance from previous owner so I'm improve my mj to get it in good shape as much I can. Link to comment Share on other sites More sharing options...
comanche12 Posted January 10, 2011 Share Posted January 10, 2011 yesterday, My good friend that have 3 years experience of weld, welded my brackets with 3 layer of weld :thumbsup: today, i painted the brackets to with anti rust spray can. soon will install rear brake parts on then focus on brake lines. :banana: Link to comment Share on other sites More sharing options...
comanche12 Posted January 11, 2011 Share Posted January 11, 2011 done with rear brakes and brake steel lines! now time to hunt the xj proportioning valve for cheap :banana: ingore the red zipties. I will buy some metal zipties someday. those plastic is just for temporary. more pics r in my project thread :thumbsup: Link to comment Share on other sites More sharing options...
comanche12 Posted January 11, 2011 Share Posted January 11, 2011 found junkyard that have ZJ front sway bar and proportioning valve for good deal :banana: Link to comment Share on other sites More sharing options...
cluricaunne Posted January 12, 2011 Share Posted January 12, 2011 I finished the headlamp harness, and put the nose back on, just need to strap in the bed, put the tank back in, finish some misc parts, get the bumpers on and do all of the inside. Also discovered that my heater box (suitcase) is thrashed, so I am hoping the 95 Cherokee I have at work will fit as a replacement... Link to comment Share on other sites More sharing options...
comanche12 Posted January 12, 2011 Share Posted January 12, 2011 nothing do with my MJ but I went to junkyard for first time. Got XJ and ZJ proportioning valve for 10 dollars both :thumbsup: Link to comment Share on other sites More sharing options...
gearboxes Posted January 12, 2011 Share Posted January 12, 2011 drove to Orlando today.... picked up four 295 75r 22.5 truck tires. Stopped by Jeepers Den and picked up the new ring and pinion for my TJ... stopped by steel company and picked up the steel for my MJ bumpers... Holy crap... that means I have a lot work ahead of me/// :doh: Link to comment Share on other sites More sharing options...
Rymanrph Posted January 13, 2011 Share Posted January 13, 2011 I swapped all the wiring and cables over from the 2wd '97 AW4 to the 4wd '97 AW4. I'm still trying to figure out if my harness has a plug for the 4wd indicator. So far, I haven't found one. Link to comment Share on other sites More sharing options...
comanche12 Posted January 13, 2011 Share Posted January 13, 2011 FML I gotta to replace almost all steel lines expect rear now. :fs1: can't afford those :grrrr: Link to comment Share on other sites More sharing options...
