what did you do to your MJ today?
JeepcoMJ
Fixed the hole in my floor then POR-15'd it!!
TODAY, (Sunday)
I painted the floor with :
It looks good, but is kinda brite...
I also decided to further adjust the seats. I am adding some washers to the rear base bolts.. I also found that the factory uses some thick washers at the base of the studs. I'm assuming they are to offset some of the carpets thickness. I removed them, some where not in good shape at all. So I found that some 1/2 washers to better level the floor. My seats have reclining backs. To fit as I have them the y are actually tilted a bit forward. So, I am hoping to get a better feeling lifting the back a bit over 1/2".
If this does what I want, I'll make up real spacers.
CW
Had a blast on my 1st ever visit to the PA All breeds Jeep Show!
There were some awesome vehicles there, including only maybe 4-5 other MJs, I also met a few fellow club members, this forum has really brought people together :clapping: :wavey:
Yesterday - threw the welder, welding equipment, hydro jack, full toolbag, spare parts, a d30, toolbox loaded with more spare parts, 4 jackstands, and air compressor in the back, drove it to New Hampshire, halfway up ended up putting my spare tire on a '99 XJ I saw on the side of i93 with a blowout, installed the d30 in a friend's '92 XJ, loaded it back up and drove home jamminz.gif
Today - drove it to work :(
Went to rotate the tires. Right rear tire was very black on the inside, so I pulled the drum off and everything was covered in goo. :fs1: Diff fluid leaking though an axle seal maybe? It's definitely not brake fluid so I don't know what else it could be.
Then, watched the truck roll off the rear jackstands. With the rear wheels off. :headpop: Slammed right down on the brake drums, but didn't seem to do any damage. I have never, ever had a jack or jackstand incident before and it's a bit worrysome to think if I had been under there. :oops:
oh yea same with me when my friend paint her front brakes while her 03 accord was on jack stand but she forget to put e-brake on... i sudden saw the jackstand was start bending :eek: so i sudden pull my friend girl out of way while she rattlecan spraying the brake. car was slammed to the ground and chipped the cement ground :nuts: the brake iits self is all fine and good shape :???:
thats most reason why i hate to go under vehicle while its under jackstand :(
:eek:
finally got new alternator for "free" by do change fluid in my brothers friends 97 yj differential gear fluids
but unforuntly it didnt keep engine running and keep dying so maybe faulty idle since have to keep feed gas little to keep it alive
don't worry ill change battery someday
then finally moved my mj into the garage that been sit on grass for like 3 weeks
Went to the junk yard to get a newer style brake caliper for the new front axle and ran into am 86 MJ that wasn't there 2 weeks ago. Completely picked clean except for the dome lights. Needed one, took both, both work, Now I got a spare!
Got the mj to start. then played around with vacuum hoses and throttle body and electrical connections. Got to play exterminator as well, found a couple of wasp nests near the firewall and one under the power steering pump. friggin wasps..... :shake:
I haven't been able to stop doing things long enough to log in lately, but I have accomplished so much I hope I can remember it all. But I think the biggest and most successful thing of them all that ties significantly with the mj, has to be the fishing trip with my 13 year old daughter thurs. evening. Just the 2 of us and a great time catching only 5 catfish between us in the 3 hours we got to spend at the lake. But we haven't gotten to do anything like that in a long time so it didn't matter how many we caught or didn't. It was all about the time spent with each other without others to bother us, or tell us what when why or how. We just fished and talked and that's the way we like it.
The MJ ran great there and back. Another reminder that it is a he and not a she, it always runs better when my daughter is around. She liked the additions as in the automatic tranny, guage dash, interior floor lights, clock and other little things I've been adding here and there. I took some trailer side marker lights and wired them into the transmission control box and a ground so that they come on when whichever transmission solinoid has power the corresponding light is lit. I can instantly tell which gear the automatic is in. I did this at first to monitor the tranny on the initial test runs, but I liked it and made a mounting plate for them and kept it. the only trouble it has given me is the reverse now. If I am correct the transmission has a low and high reverse. It seems as if it is going directly into high reverse gear and it is hard to get it to move unless i rev it higher. But it's legal all the way around now.
Fooled around with my fuel guage some. Low fuel light came on so I decided to see how far it would go before it ran out of fuel. The owners manual states you have 2 gals left when thr light comes on so I was feeling good & also confused when it chugged to a stop after 50 miles. 25 mpg is not bad I was thinking but not likely. So I start dumping gas in tank a gal at a time to see when the light will go off. It took 3 1/2 gal to put it out. That knocked my mpg to a little over 14 combined city/hwy. Anyways obvisiously my guage low fuel light is not working correctly as it is off by 1 1/2 gallons (3.5 instead of 2) remaining in tank. Allways gas up before it gets out of red area anyway so not worth fixing.
I thanked my Higher Power and the powers that be for being able to bring it back to life. Packed in a whole bunch of tools and headed to work on other peoples vehicles. As I usually do with all my spare time. I swear, some day it will all come back to me in a big way, like maybe I'll get into heaven even though I don't deserve to or something. First I tapped new threads for a water neck on my brother in laws Beretta. Then back to the Ice Cream truck to reset ponts and get it running again. went to sleep last night feeling OK. Woke up so stiff I couldn't get out of bed. From staying bent over the Beretta so long I'm sure. I am going to have to start charging full mechanic rates, relatives and friends or not.
Went to court today, won!
Promptly came home with all my excitement decided it would be a great day to dig into the power steering lines, put the new ones on......now they leak like a son of a gun and i have no power steering :fs1:
The Comanche gods can only give so much in one day
