what did you do to your MJ today?
Yep i am gonna take care of that as soon as Pat gets back bc i am getting a Valve conver new style from him
Good luck with that.
-new lower radiator hose
-new drain plug
-new water pump
-rear main seal
-timing chain and gear set
-timing chain guide
-Meilling High- flow oil pump installed/ new screen
-dist. gasket replaced
-had radiator holes fixed
-and oil and oil filter changed
- oil pan painted
I think that's it, sure runs good now, and doesn't pump any oil out on the ground :clapping:
-new drain plug
-new water pump
-rear main seal
-timing chain guide
- oil pan painted
SW2,
I hate to tell you this, but .......... I think they're crooked. Oh, you left out a bolt and nut also they are right there on the floor...... :rotf:
Yah the ends are just a tad crooked and If I really cared I could loosen the d-ring ends just a smidge and get em perfert... I don't care that much...
But you will notice the BFH that was used heavily in the install process!!! :rotf:
swapped front axle shafts for ones with good/new universals, installed rebuilt front drive shaft, rotated tires, and...
moved the snow burm left at the foot of my driveway by the :fs1: grader operators to the side to create a pedestal to park my truck on. :yes:
