You can put me down for a hat and 2 can cozies. I have never recieved any cards, magnets, stickers or anything. :roll:
At least my MJ has the windshield banner that Pat put in. ;)
I can send the payment in a couple days.
You gotta love the cold weather... It was -2 degrees here this morning. My 8 year old Optima has no problem spinning over the engine. It doesn't crank any slower now then it does on a warm day.
My coolant is good to -30 degrees :brows:
I never did check the MJ Pat sold me... I'm swapping in a '95 4.0HO so I'm not too concerned.
I checked the wifes tires tonight and they were all about 10psi low because of the cold weather. They did have a pretty good footprint when they were low. :roll:
Assemble it just like it will be when it's put together, just leave out the pinion seal and reuse the old pinion nut if its ok. Once preload is set remove the yoke install the new seal and reassemble it using the new nut.
Not all D35's are C-clip axles you'll have to pull your cover to see what you have. Use good high temp RTV instead of a gasket I use grey mopar without any problems. I also use 75w-140 synthetic gear lube.
The stock pinion is probably marked to show how far off it is so it gets shimmed right. If your new pinion is marked just change the shims by the difference between the two.
The if the marking is +.002 on your old pinion and the new one is marked -.001 you would add .003 to get the correct pinion depth.
Jack is my buddy. :brows: Although, Wild Turkey 101 and Mt. Dew; that was a recipe for an all night poker game.
EDIT: HAPPY NEW YEAR EVERYONE IN THE CC.COM FAMILY!!
Wild Turkey 101 and Mt. Dew... I think that a sin or something. :nuts:
Its a great sipping whiskey. I might have a beer to drink with it.
I have never mixed it.
It is meant to be straight in a glass with no ice. :brows:
Jack makes me cough every time I take a drink...
Jim Beam Rye whiskey is my drink of choice.
Are you drink white or yellow label Beam?
With my pain pills and valium I'm feeling good. At least my back doesn't hurt right now.
I'm not going out, I'm just going to enjoy a few drinks and stay up until the new year or longer.
Happy New Year to Everyone
If you are using a HP44 with Ford brakes this is a great write-up about better front brakes.
http://www.ford-trucks.com/article/idx/13/092/article/Complete_Brake_Upgrade_for_1978__1979_Ford_Broncos.html
It took me about an hour to put M.O.R.E. rubber mounts in my XJ. The drivers side wasn't that hard. I will never use any other mounts. The M.O.R.E. mounts are great.
