13
Everything posted by Minuit
How Bad Is The Ax5? Seriously?
Minuit replied to benjy_26's topic in MJ Tech: Modification and Repairs
The AX-5 was used behind the 2.5 up until it was retired in 2002 (at this point it had MPI for 9 years). You'll be fine. Small detail: the 2.5 uses a GM 60* V6 bellhousing pattern, different from the AMC-specific pattern of the 4.0 and AX-15. They won't adapt easily. -
That truck looks mean.
Gaskets always seem to be the most difficult things to find. That gasket maker is seriously cool - I might have to pick some up. here is a Summit Racing link for Fel-Pro timing cover gaskets although I'm sure you've probably seen it. One is nearly twice the price of the other - not sure why. I also don't know what "cork/rubber" means. I'll keep looking.
The 86 trucks always seem like they have the best paint schemes. I'm looking forward to seeing this rig in person :thumbsup:
Every problem I'm reading seems to be with large orders so I suspect hornbrod is right.
:banana:
I should've been clearer in regard to the TrueTrac name - from what I've seen both lockers and LSDs are sold under that brand name. In my post I was referring to the Limited Slip version such as this. I agree. Eaton products are generally very good. Every model of locker is going to act differently so make sure to do plenty of research.
We may disagree on style but I'm happy that you're happy with it. :thumbsup:
Some axles did. As far as I know the only way to tell is to jack it up and spin a wheel. If both wheels spin in the same direction, it's a limited slip.
Lockers range from cheap to ridiculously expensive. Cheaper lockers are automatic and will make your truck "interesting" to drive on the road. They're loud and tend to lock in turns and will wear tires very quickly if you aren't careful. Auto lockers are usually relatively simple to install. Selectable lockers (you can switch between open and locked from the cab) are usually expensive but are much nicer if the truck is driven on roads regularly. That's just the basics - someone will probably come around with more detail later. Limited slip diffs are something you'd probably want to have more on a 2wd truck. They won't lock on you in a turn and make your truck hop around and are generally much nicer to drive with. They're helpful offroad but not as much as a locker. The stock posi-trac rear end sort of sucks and most ones you are likely going to find in junkyards will need to be rebuilt - they use clutches. The Detroit TrueTrac is a much less maintenance intensive diff (it's gear operated so no clutches) and is fairly cheap. Installing an LSD is a bit more involved.
I've always liked my crank windows but sometimes the passenger side can be a little troublesome to get to from the driver side. Power windows are a nice convenience but from my Googling I'm getting the idea that it's not exactly an easy swap. What exactly does swapping power windows into an MJ entail? Swapping doors is obviously not an option - that seems to be the most common advice given.
Haven't seen another MJ on the road that I wasn't sitting in in months. I usually see several in a short period of time and then none for a while. They're usually not the same.
Cast iron grenade - that's an important detail. Don't do it. The stock knob is a couple of ounces at most.
I still can't get my head around this being the same truck as it was in the first picture. I can't fault you for making it the way you want it but it was a beautiful specimen.
It's a column shift automatic. I doubt it would hurt much unless it's REALLY heavy.
If the hole is close to the same size, glue will work at least temporarily. The knob on my column shifter is worn out so every few months I have to glue it back on. Works well enough.
"Southern Hospitality" doesn't exist as far as I'm concerned. You'll find good and bad people wherever you look.
XJs are prone to floorboard rust just as our trucks are. The problem usually stems from leaks through the firewall and that part of an XJ is identical to an MJ. As long as everything works and it drives/shifts reasonably well (at this price point don't expect perfection, but I'm guessing you already know this), $1400 ain't bad.
I think a lot of us here have the same complaints. A shop will always try to get as much money out of you as possible for as little time/effort expended and they love to prey on people who either don't know better or don't care. My MJ will never see a shop if there is even a remote possibility that I can do the work - I stopped having faith in the opinions of people who wanted my money when a number of shops told me I needed a new engine pronto at the cost of roughly $3-4000. My problem? Flexplate bolt knock. A lot of shops out there don't care at all about doing the job right and leaving a satisfied customer as long as they get the paycheck. Not to mention the money saved by not having to pay for labor.
Comanche Rear Sway Bar, Short Box
Minuit replied to Jeep Driver's topic in MJ Tech: DIY Projects and Write-Ups
Why not? It looks to be roughly stock height and it seems to work pretty well from what he has said. -
Another small update. Posted a list of pics I need. I'd rather use pics of people who want to contribute and credit them rather than grabbing stuff from google. I likely won't have time to update this any more this week. JeepcoMJ and johnj, I fixed your gripes also. Jeep Comanche Buyer's Guide v0.06 Disclaimer: This guide contains information and dates specific to the Jeep Comanche (MJ) and dates in this guide reflect Jeep Comanche (1986-1992) model years only. Outline 1: Introduction 2: Overview 3: Maintenance Information 4: Issues and Solutions 5: Buying a Comanche (how much should I pay, etc) 6: Credits (this is where all of the major contributors will be listed, including anyone who contributes pics) It is advised for new Comanche owners to read the Introduction, Issues and Solutions, and Buying a Comanche sections before others. The Overview section contains a large amount of information that may be overwhelming to new or prospective Comanche owners! Part 1: Introduction What this guide is for This guide is designed to be a comprehensive, yet relatively simple introduction to the Jeep Comanche, providing information that new owners and interested buyers will need to know. This guide is not intended to be a complete resource for every detail of these vehicles, but rather an easy to understand overview that still contains the most important details. While as many important aspects will be covered as possible, the newest Comanche is now twenty two years old, and conditions vary wildly. If you are purchasing a Comanche or have purchased one recently, you are encouraged to familiarize yourself with the vehicle and its quirks. This guide is intended to help you along in doing so. With that said, you don't need to read the entire guide - in fact doing so may be overwhelming at first glance! This guide is mainly intended to cover stock trucks, so some specifications will vary if your vehicle has been modified. What this guide isn't for This guide isn't an owner's manual - the information here is mainly intended to get new Comanche owners started with the basics. This isn't a guide for setting up your truck for wheeling, in fact virtually none of this guide involves modifying the truck at all. If you are looking to modify your truck, it is best to ask your questions in the "MJ Tech" section of ComancheClub.com. A brief history lesson Part 2: Overview Basic Specifications Construction: All Jeep Comanches are constructed on a hybrid unibody-frame platform known as the "UniFrame." The Comanche's frame is similar to that of the Cherokee in front of the doors - the cab is permanently attached to the frame. However, unlike other unibody pickups such as the Volkswagen Rabbit, the Comanche has a removable bed attached to a standard ladder-style frame behind the truck's doors. This hybrid structure is far stronger than a typical ladder frame of a body-on-frame truck, although it cannot be repaired if heavily damaged. Model Year Breakdown Although the Comanche was only offered for a short period of time, it went through many iterations, with significant changes occurring each model year. Each model year is widely considered an improvement over the previous year. 1986: Often considered the "odd duck" year, 1986 Comanches are considered the least desirable, mostly due to some key differences in the engine bay, as well as its weak 2.8L engine. Despite this, the 2.5L engine, when paired with a manual transmission, is similar to its 1987-1990 counterparts and is an excellent engine. All 1986 Comanches are fitted with the 7-foot long bed. 1986 Comanches are typically identified by an uppercase fender badge. A stock 1986 Custom. Note the long bed and uppercase 'COMANCHE' badge. 1987: A significant improvement over the 1986 model year. The carbureted 2.8L engine was replaced by the multi-point injected 4.0L inline six, and the 3-speed TorqueFlite 727 was replaced by an Aisin-Warner 4-speed. 4.0L engines could also come equipped with the somewhat troublesome Peugeot BA-10/5 manual transmission. 100 1987 "Street Comanches" were produced, with the 4.0L engine, a manual transmission, and special racing-style cosmetic body parts. 1988: The most widely produced model year, 1988 brought relatively few changes. The 10-slot grille was replaced by an 8-slot grille, and the 4.0L engine received a slight power upgrade. A special edition, the Olympic Edition, was offered. 1989: (no C101 connector blah blah AX-15 blah blah) 1990: (what changed for 1990?) 1991: Besides 1987, the 1991 model year brought the most drastic changes to the Comanche. Both the 2.5L and 4.0L engines received significant upgrades, with the 2.5L engine receiving multi-point fuel injection similar to that of the 4.0L engine, and the 4.0L engine's fuel injection system was upgraded substantially. 1991 Comanches feature On-Board Diagnostics (OBD I), interfaced through a check engine light. 1991 and later gauge clusters are fully electronic, lacking a speedometer cable. Cosmetic changes were significant, including several new colors and a new front fascia. The SporTruck package also received a significant facelift, and became quite rare. A stock 1991 SporTruck in Silver Star Metallic paint, one of the paint colors introduced that year. 1992: The final model year for the Comanche, and the most desirable. Changes for 1992 were cosmetic, with a new color (Hunter Green Metallic) and a new graphics package (Sport) introduced. Drivetrain Engines 2.1L Renault J8S I4 Turbo Diesel (1986, early 1987): The rarest by far of the available engines. Although this engine has a poor reputation and parts are extremely scarce, many Comanche Club members consider 2.1L-equipped Comanches highly desirable due to their rarity (less than 100 diesel Comanches are estimated to exist in the United States). The 2.1L is a belt-driven overhead camshaft engine. Diesel Comanche owners: Automan2164, opsled/jeepcoMJ (former), Power output: 87hp, 132 ft-lbs 2.5L AMC 150 I4 (1986-1992): The standard and most common engine found in the Comanche throughout its production, the 2.5L engine is based on the highly reliable AMC Inline 6 family of engines. It was offered in two major generations during its production run. Although lacking in power compared to 6-cylinder engines, 2.5L engines are considered strong for their size and are expected to last well past 200,000 miles if well maintained. The manufacturer specifies 10W-30 motor oil, but recommendations vary. The 2.5L is a chain-driven overhead valve engine that does not require regular timing maintenance. - Renault-Bendix Throttle Body Injection (1986-1990): A fairly simple and reliable single-port injection system, the 2.5L TBI was Renault-Bendix's first Jeep engine control system. It is considerably simpler than Multi-Point Injection systems and is not prone to as many electrical issues as a contemporary 4.0L engine. 1986 and 1987 model year vehicles with this engine have a '2.5 Litre' badge on the tailgate. - Mopar 'Power Tech' Multi-Point Injection (1991-1992): An updated system similar in design to the system used in the 4.0L engine, the Mopar 2.5L engine is similar in many respects to the 4.0L version and much of the same information applies. Vehicles with this engine do not have a badge on the tailgate. Fluid capacity: 4 qt. Power output: 117 HP/ 139 ft-lb (1986-1990), 130 HP/ 149 ft-lb (1991-1992) 2.8L General Motors LR2 V6 (1986): The original 6-cylinder option in 1986 Comanches, the 2.8L engine featured an unreliable carburetor and failure-prone oiling systems, tarnishing its reputation in the Jeep community. With its low power output, poor reliability, and marginal fuel economy compared to later engines, 1986 Comanches with the 2.8L engine are considered some of the least desirable examples. Despite its poor reputation, some 2.8L engines are known to have lasted well past 200,000 miles. The 2.8L is a chain-driven overhead valve engine that does not require regular timing maintenance. Vehicles equipped with the 2.8L engine have a 'V6-2.8L' badge on the tailgate. 2.8L engine bay. Note the carburetor and small radiator. Fluid capacity: 4.5 qt. Power output: 110 HP/150 ft-lb (1986) 4.0L AMC 242 I6 (1987-1992): The legendarily reliable successor to the 258 inline 6, the 4.0L engine appeared in Comanches in two different generations, with a great deal of difference between the two. The manufacturer specifies 10W-30 motor oil, but a wide variety of recommendations can be found. Due to their high zinc content (which an engine of this vintage was designed for), diesel engine oils such as Shell Rotella T5 are frequently recommended. 4.0L engines are generally expected to easily reach 200,000 miles without rebuilding if well maintained. The 4.0L is a chain-driven overhead valve engine that does not require regular timing maintenance. The 4.0L engine existed in two forms: - Renault-Bendix (Renix) Multi-Point Injection (1987-1990): The first iteration of the 4.0L engine's fuel injection system, the French-developed Renix engine control system was considered quite advanced for its time and is in some ways more complex than its successor. Although a significant improvement on the electronic carburetors used by its predecessors, the Renix system is prone to electrical issues, particularly revolving around its insufficient chassis grounds. The Renix system does not feature easily testable diagnostics. Certain tools can interface with this system, but it does not store trouble codes, requiring testing while the engine is running. Although the Renix system is more prone to electrical issues, a well cared for Renix example can equal a Mopar engine in reliability. Vehicles with the Renix 4.0L engine have a '4.0 Litre' badge on the tailgate. - Mopar 'Power Tech' (High Output) Multi-Point Injection (1991-1992): A significant upgrade to the previous Renix system, the Mopar system eliminates the knock sensor, EGR valve, a number of vacuum lines and adds first generation On-Board Diagnostics (OBD1) controlled through a 'Check Engine' light. The electrical system of this engine is considerably more robust than the Renix system, with far fewer ground-related issues. Revised cylinder heads and intake manifolds considerably increased high-end power at the expense of a higher torque peak. Vehicles with the Mopar 4.0L engine have a '4.0 Litre HIGH OUTPUT' badge on the tailgate. 4.0L High Output engine bay. Note the radiator cap and standard coolant overflow tank. Fluid capacity: 6 qt. Power output: 173 HP/220 ft-lb (1987), 177 HP/224 ft-lb (1988-1990), 190 HP/225 ft-lb (1991-92) Transmissions Chrysler TorqueFlite A904 (1986): The only automatic transmission option for the 1986 model year and the only Chrysler transmission used in Comanches, this 3-speed automatic was paired to some 2.8L and 2.5L engines. Although quite reliable, it was replaced for 1987 by the computer-controlled AW4. The manufacturer specifies ATF+3 fluid, which is no longer in production. Substitute ATF+4 fluid. Fluid capacity: 8-11qt. split between fluid pan and torque converter. Verify fill level using dipstick. Gear ratios: Aisin-Warner AW4 (1987-1992): The only automatic transmission found behind the 4.0L engine (as well as some 1987+ 2.5L engines), the 4-speed computer-controlled AW4 has an excellent reputation for reliability and power handling. From 1987 to 1991, this transmission featured a selectable "Power/Comfort" switch on the dash that adjusts shift points. Later AW4 units are permanently wired in the "Power" position. The AW4 is prone to overheating, so the installation of an external transmission cooler (writeup link goes here) is recommended. The AW4 is designed for Dexron-Mercon transmission fluid only. Fluid capacity: 8-10 qt. split between torque converter and fluid pan. Verify fill level using dipstick. Gear ratios: Aisin AX-4/AX-5 (1986-1992): The manual transmission options for the 2.1L, 2.5L, and 2.8L engines, the AX-4 and AX-5 are light-duty transmissions considered sufficient for the output of their engines. While both transmissions are essentially the same design, the AX-5 features an added fifth overdrive gear for highway use. 10W-30 motor oil (regular or synthetic) is specified by the manufacturer, but Pennzoil Syncromesh and Redline MT-90 fluids are also frequently recommended. DO NOT lubricate Aisin manual transmissions with GL-5 gear oil, as the transmissions feature brass synchronizers that will be destroyed by standard gear oils. Fluid capacity: 3.3 qt. Gear ratios: Peugeot BA-10/5 (1987-1989.5): The 5-speed manual transmission found behind 4.0L engines from 1987 to mid 1989. The BA-10/5 is a light-duty manual transmission that is considered inadequate for the 4.0L engine's power output if not driven carefully. While many owners have seen success with this transmission, it is considered inferior to the later AX-15 transmissions. The BA-10/5 can be identified by a square shaped drain plug that few tools will fit. The BA-10/5 is designed for standard gear oil. Fluid capacity: 2.45 qt. Gear ratios: Aisin AX-15 (1989.5-1992): The 5-speed manual transmission option found behind 4.0L engines in trucks built after March 1989. The AX-15 is a medium-duty manual transmission that is considered adequate for the 4.0L engine's power output. As with the AX-4 and AX-5, the manufacturer specifies 10W-30 motor oil, but Pennzoil Synchromesh and Redline MT-90 fluids are frequently recommended. DO NOT lubricate Aisin manual transmissions with GL-5 gear oil, as the transmissions feature brass synchronizers that will be destroyed by standard gear oils. Fluid capacity: 3.3 qt. Gear ratios: Transfer Cases New Process 207 (1986): New Process 228 (1986): New Process 231 (1987-1992): The standard transfer case for all non-1986 trucks, the NP231 is a simple, manually shifted, chain driven transfer case. The 231 is considered more than strong enough for any stock drivetrain. The NP231 is designed to use Dexron-Mercon transmission fluid. Shift Pattern: 2WD - 4WD (Part Time) - N - 4WD Low New Process 242 (1987-1992): The "full-time" transfer case for 1987-1992, the NP242 is similar to the NP231 except for the addition of a full-time 4WD option, allowing for the use of 4 wheel drive on surfaces with good traction. As with the NP231, the 242 is designed to use Dexron-Mercon transmission fluid. Shift Pattern: 2WD - 4WD (Part Time) - 4WD (Full Time) - N - 4WD Low Axles Dana 30 (1986-1992): The only front axle to equip Comanches, the Dana 30 (or D30) is considered a highly reliable axle well-suited for light to moderate off-road use. 2 wheel drive models feature a solid beam in place of this axle. Dana 35 (1986-1992): The standard rear axle to equip Comanches without the Metric Ton package. The Dana 35 (D35) has a poor reputation in the Jeep community due to its weakness under extreme use with oversized tires. The Dana 35 is typically reliable when equipped with tires less than 33 inches tall. Dana 35 units after 1989 use C-clips to retain axle shafts. AMC 20 (1986): The "heavy duty" rear axle for 1986 Comanches, the AMC 20 is a rare axle identified by its perfectly round differential cover. While not as highly prized as Dana 44 rear axles, the AMC 20 is far stronger than the Dana 35. Dana 44 (1987-1992): The rear axle of Comanches with the "Heavy Duty Axle" option or the Metric Ton/Big Ton package, the Dana 44 is highly regarded for its strength in extreme use situations with tires up to 37 inches tall. Comanches with the Dana 44 axle are highly sought after. Final Drive (axle) ratios: Part 3: Maintenance Information Part 4: Common Issues and Solutions Rust Since the newest Comanche is now 22 years old, rust is simply a fact of life for all but the most well-cared-for examples. Comanches operated in areas of high road salt use are particularly prone to rusting, with vehicles in deserts or temperate climates (such as the Southern United States) least prone to rust. Floor Pans: Virtually all Comanches are expected to have at least some rust here, and this is generally the first place a Comanche rusts. If the vehicle has not been meticulously checked for leaks during its entire lifespan, water can (and will) leak onto the floor pans and collect under the carpet without any place to go. Depending on how the vehicle has been stored, rust will range from minor surface damage to complete destruction of the vehicle's floor. A number of methods to repair floor pans exist, including ready-made patch panels, although these are often of extremely poor quality. Rocker Panels: Generally the first place rust is visible to the naked eye, rocker panel rust occurs mostly as a result of road conditions or poor maintenance. A number of methods to repair rocker panels exist. Rear Wheel Wells: After a Comanche rusts in its rocker panels, the rear wheel arches are generally the next areas to go. Salt, mud and other debris builds up behind the rear tire, and if allowed to sit uncleaned, will eventually destroy the area around the rear fender flares. Due to the Comanche's rarity, repairs to the bed will generally have to consist of either cut-out sheet metal sections from other Comanches or custom fabrication work. Part 5: Buying a Comanche Part 6: Credits Pictures Minuit: 1991 Comanche, 4.0L HO engine bay redwolf624: 1986 Comanche, 2.8L engine bay Up next: Finishing the overview and common issues. I still need pics. I need pictures of the following: - a stock 1987, 1988, 1989, 1990 and 1992 Comanche as well as possibly a Street Comanche. - a diesel engine bay - a Renix 4.0 engine bay - a Renix 2.5 engine bay - a 1991-1992 2.5 engine bay - a rusty Comanche as well as pics of rust in the floors and other common spots.
Don't forget to turn off your lights. :doh:
warshed it and took pitchers :dunno:
Rockmj's 1990 Eliminator Overland Long Haul Project
Minuit replied to RockMJ's topic in Member Projects: Your Comanches
:rotf: Glad to see another perfectionist. Great looking ride. -
I fixed the AW4 ratios in that update. It's under the spoiler tags. Roger that on the MT/BT. :thumbsup:
