Minuit
    13
Everything posted by Minuit
  1. fresh chocolate milk
  2. Minuit
    1J7FT26S9ML600717
    1991 ENGINE & PERFORMANCE: Stock engine and transmission with no modifications. DRIVETRAIN: 2 wheel drive. AW4 automatic transmission with floor shift, open differential Dana 35 rear axle. COOLING: CSF 3-core radiator with Hayden 678 automatic transmission cooler. Stock replacement heater core, water pump, and thermostat. ELECTRICAL & IGNITION: 94-97 distributor with external camshaft position sensor. Stock replacement ignition components. Power windows, mirrors, and door locks. STEERING: Stock; 12.7:1 ratio steering gearbox SUSPENSION: WJ Grand Cherokee control arms, 28mm front sway bar. INTERIOR: Luggage Fabric wingback flip-forward bucket seats, Limited door panels, full center console, carpet, and sound insulation. Stock RX-171 radio with auxiliary input, 6 speakers, and 180W Alpine amplifier. Factory cup holder. New aftermarket carpet. Export 125 mph speedometer with correct mileage. Interior fully soundproofed with mass-loaded vinyl. AIR CONDITIONING: New-build 1995-1996 R-134a native system with OEM SD7H15 compressor, parallel-flow condenser, and NOS evaporator. Factory evaporator temperature probe retained. BRAKES: Front and rear disc brakes. Rear disc brake setup sourced from 93-98 Grand Cherokee. LIGHTING: Relay-controlled headlamps with Hella H4 composite housings. Factory retrofit fog lights, wired in stock configuration. WHEELS/TIRES: 15x8 Jeep "Ravine" wheels with 235/75/R15 Michelin Defender LTX M+S tires. MISCELLANEOUS: Silver Star Metallic exterior with 'squiggly' SporTruck graphics package. Engine: 4.0L High Output Transmission: AW4 (floor shift, originally column shift) Rear Axle: Dana 35 Wheelbase: Short Exterior Color: Silver Star Metallic with red SporTruck graphics package Interior Color: Charcoal with bucket seats (originally with bench seat), modified with factory convenience and comfort options including power windows and locks. Build date: April 17, 1991, 12:55 PM Current Location: Middle TN Status: Fair weather driver Mileage: 189,000 Current owner: Minuit Build Threads: 2012 - present, owned by Minuit Original factory options (all option names and descriptions from 1991 Jeep sales brochure) - 4.0L "Power Tech" I6 engine - Air conditioning - AW4 automatic transmission with column shift - Bench seat with adjustable headrests, Jamaica fabric - Black textured vinyl floor covering - Charcoal interior - Cigar lighter (yes, that was optional) - Heavy Duty Alternator and Battery Group (90A) - Radio Delete - Rear step bumper (yep, that too was optional) - Silver Star Metallic Clearcoat paint - Variable ratio power assist steering Added 1991-era factory options - options not originally available on 1991 Comanches in italics. - AM/FM electronically tuned stereo cassette with Dolby system (auxiliary input added), six speaker "Accusound by Jensen" sound system with dash-mounted tweeters and power telescoping antenna . (all speakers aftermarket, with re-used factory hardware) - Color keyed cab carpeting - Color keyed custom vinyl door panels with perforated vinyl upper, nylon carpeting lower, and plastic storage bin - Extra Quiet Insulation package - padding on back of cab, underhood insulation, and additional sound deadening materials - Front and rear mud flaps - Front bumper guards - Full center console with floor mounted transmission shifter - Gauge Group - tachometer, voltmeter, oil pressure and engine temperature gauges, low fuel indicator light, trip odometer, digital clock - Halogen fog lamps - Power Window & Door Lock Group (w/aftermarket keyless entry wired as factory) - Power Mirrors - Light Group - Ashtray light, courtesy lights, underhood light, headlamps-on warning buzzer, Sentinel headlamp switch - Recliner wingback bucket seats with adjustable headrests, Luggage fabric - Speed control - Tilt steering column, black - Visibility Group - left and right manual remote mirrors, intermittent wipers
