Minuit
    13
Everything posted by Minuit
  1. On that topic, if you can help it, try your best to replace parts with high quality or Mopar parts. The OEM crank sensor on my truck lasted 145,000 miles. A cheap replacement lasted 800 but thankfully it didn't strand me. Cheap eventually becomes expensive.
  2. I hear that Hella H4s are good but they require the headlight wiring to be upgraded, which is something that should probably be done anyway. Sylvania Silver Stars (what I have on mine) aren't bad either, and a little cheaper.
  3. Minuit
    New Flashlight
    Didn't think so much science could go into a flashlight. Now I want one. Gotta ask, how much does one of those cost? :cheers:
  4. What you've got here is perhaps the only thing that can draw the reverence of the Comanche club more than an actual Comanche. It's beautiful. :bowdown: :bowdown:
  5. Now that's impressive.
  6. There's a couple of scrapyards in Columbia too. Not exactly sure.
  7. Minuit
    1J7FT26S9ML600717
    Edited to reflect some work that's been done, 'specially the new front end. More pics on the way soon.
  8. I believe the tailhousing has to be swapped to one that will accept a transfer case, which involves partially disassembling it. It's not something I see as practical unless you can't find a proper 4WD transmission or you have some sort of attachment to yours. Happy to help! :thumbsup:
  9. Just wanted to come and say that's some really great work you're doing! Beautiful truck.
  10. Do you happen to have any more info on this one? A rescue mission may be in order.
  11. Either that or lift the front more :brows: I do believe that's just a little bit more rake than stock.
  12. They do look pretty similar but not identical. If you're talking about the last Comanche of the Month, it's got stripes down the middle (matched to the camper) and the mirrors and wheels look different.
  13. :rotf: That's brilliant. How did it place? Carbed 4.0 IMO isn't worth it. The injection system is simple by modern standards and it's only really a couple of different things that can cause trouble.
  14. Don't think it would work without the AW4 being converted to 4WD (might as well get a whole transmission). Pretty sure rear driveshaft lengths are different between transmissions, not sure about the exact numbers. Front driveshafts for MJ and XJ are the same AFAIK, rear are not - rear axle also changes the length. Not certain but I think the actual transfer cases are the same whether it's an auto or a manual.
  15. Was there a company actually making these things? That's two now this month. Thought it was a custom job, but still cool.
  16. Minuit
    Mj Smiley
    . :MJ 1: .
  17. :fs1: I was going to check it out tomorrow, too. Probably got about $300 for it, and the taillights alone are probably worth that. Gotta figure out where he took it!
  18. I like it.
  19. 16. I only beat on my MJ when it gives me trouble. It in fact looks much nicer now than it did 6 months ago.
  20. :agree: Anyone here have a firebird? :rotf:
  21. I see no dilemma here. You can put the keys under the welcome mat any time this weekend. :thumbsup: 'it is not a show truck by no means' :rotf:
  22. :rotf: Feeling slightly disturbed here, as well.
  23. Clever and hopefully a good buy. :thumbsup:
  24. I'd do it just to keep it out of the junkyard. Of course if it did go to the junkyard I wouldn't have to go very far... :)
  25. Minuit
    Mj Smiley
    I always thought that 'smoke' coming out of the rear was the tailpipe spinning. :doh:
