Donny88
501 profile views
Donny88's Achievements
  1. I'm having the same issue. I will check the ground on mine tonight. if you figure it out pass it on I could use some help
  2. New bled master cylinder, brake lines bled and new pads and shoes. A little bit of pedal untill I start it and it goes to the floor .does not stop like it should. Any ideas?
  3. I finally heard my comanche run yesterday and it sounds beautiful. Thank you to all who helped me along the way. I coundnt have done it without you.
  4. The wiring harness the runs through the top of the fuel pump. Is there some sort of clip that holds the harness in place. Its installed but not secure.
  5. Now trying to figure out if mine has lsd stock. If so would this be good enough for a snow covered road? I'm not lookin to off road in this thing but getting to and from in snowy weather.
  6. Thanks for the info. Do you know if they came with stock posi traction?
  7. I got an 88 comanche pioneer 2w drive. Is there some kind of locking diff or positraction rear end I can put in this?
  8. I got a new spectra fuel tank but all the new fuel pumps have the filter and float on the wrong side. A mirror image of the original. Causing it to not fit due to the resvoir pan. Any idea's? The new tank is spot on the original and the original pump fits but is in to bad of shape to salvage.
