88whitemanche
    3
Everything posted by 88whitemanche
  1. Hope you get better jim!
  2. Sounds like a deal...I'm the same way with the gap but I think it's mainly the door seal...
  3. As far as motor mounts I really don't know what brand I grabbed but I got the $10 ones at the store and it made a huge difference...ax5 mount is the correct one....and the Bosch pump is the best one and everyone can account for it
  4. How is that new hood seal working with the leaking in the cab?
  5. Thanks guys...I tore into it yesterday...steering wheel puller wasn't cutting it....it's was bending the bolts that go into the mounting plate... So I called a locksmith and they'll be coming today to replace the whole cylinder....
  6. What's up guys So this morning when I got into the truck the key didn't want to turn all the way to try to start the truck it would stop right before that point... This morning pretty much sucked I finally got it going then I went to get coffee and the same routine again! Finally got on the hwy and it shut off on me completely and before I can even try to diagnose why it did that the lock cylinder did the same thing again.... When I finally got it going about 20minutes later the key was way to forward and the starter was on with the rotation of the engine and I hauled tail to work... Luckily I know which relays to take out because the truck was just running with the key stuck in the on the crank position....I'm at work now can anyone tell me what it can be? So when I'm on break I can go check it out....thanks in advance
  7. http://miami.craigslist.org/mdc/cto/4460286241.html
  8. http://treasure.craigslist.org/cto/4455226973.html
  9. Does hellcreek make them also? I see they have a layaway plan also....
  10. Double check the vacuum line from the map sensor to the throttle body...it'll run rough from a broken line or unplugged
  11. I have your front bumper on my comanche.... Getting pulled out And with a smittybilt xrc8
  12. Have you checked the sway end links?
  13. Idk but it looks bada**... That price is a bit out my price range but it is clean exterior wise....
  14. I think it'll be worth buying a new one off ebay... I bought my 18 gallon tank when I first got my truck for under $100.... That's my opinion for peace of mind
  15. PHONE dial rims!! Cool.... At least I know what they are called now lol
  16. I thought they were called sun dial rims....
  17. Turbines
  18. Congrats!!!!
  19. Tail pipe looks fine...my muffler is like a balloon from the previous event...Ive thought about the cat but thought it can be another symptom I'm not seeing
  20. Tailpipe back fire...big cloud of smoke...sounds like a shotgun!!!
  21. What's up guys I've searched and searched but haven't diagnosed my truck... For the past two weeks the truck has been back firing/ or shutting off..... So to get you guys up to speed...I've had a similar issue before but it ended up being the ignition coil and a short at the brake switch.... I've changed plugs, rotor, dist. Cap,wires, serpentine belt, tps, cps, ignition coil, oil, air filter all with in the last month.... o2 sensor in jan,added extra grounds, and done all of cruisers tips, tightened all manifolds bolts What happened at first afterwork 3pm...was a small bucking and when I got to a stop at idle the truck shuts off, starts up normal and drives the rest of the way normal....it's been like this all last week and the weekend.... until Monday in the morning no symptoms until half way to work which is a 12 mile drive the truck bucks and backfires once at 60 mph and ran normal all the way to work...it's been the same Tuesday and Wednesday and today also but now instead of in the afternoons last week it's only happening in the mornings this week... What I have been noticing is that theres little bit of a power loss shifting into gears...like a 2-5mph difference shifting into gear I've noticed the engine being revved a little more than usual but not because of my foot but seems like a clogged cat? But what can be causing the bucking and backfiring on the hwy at 60mph? A relay losing its connection once in a day? Any diagnoses would help....thanks in advance
