11
I dunno, this seems like a lot of work...
supercharging__ is it worth it?
DirtyComanche replied to 89sportruck's topic in MJ Tech: Modification and Repairs
How do you expect to see 75HP from a cam? Maybe 7.5. Roller rockers are worth maybe 2 at most, if that... E-fan, like 6HP? A HO head is worth something, but not a lot... Might as well do the late style intake as well. But still... Bored TB should be worth 1 or 2, add a performance header and see another 5 or 6 at that point. It's not like building a LS1 or a modular Furd. -
I saw a DIY setup using a 3.8 Thunderturd (Thunderbird for the slow guys) S/C. It only ran about 5 or 6psi of boost, I guess. Some google usage might yield more details. However, it cost more than a stroker in the end, I think... And 6psi on a tired 4oh is asking for trouble. I'm not one of those guys who believes these things are bombproof. -
I read this, found it to actually be accurate, and you know, maybe people should read it? Okay, yeah...
I think the max streetable safe difference is 3%.
Can you tell what this is?
DirtyComanche replied to jeepcoma's topic in MJ Tech: Modification and Repairs
There's rust inside the uniframe rails... -
Who says you have to :???:
And if you have the same sized tires front and rear...
Great. Well, I don't think I'd buy Genu-whines, but I bet they're exactly the same as anything else save stuff that has been cryo'd.
I hate D30s, but I have to agree... The problem lies in the rear with the D35. It is truely not worth a damn thing.
You lost me at 'G'. I'm extra lost with 'G2'.
Oh yeah, shackles forewards = ugly approach angle and bent leaves. Shackles back = boat anchor under the belly and bent leaves if you try to back off something. Pick your poison, both will kill you. Oh, MJ rear leafs in the front... Would be squishy I think. I recall BrettM saying he tried them, but settled for some lift YJ leaves. I used stock grand-wagoneer fronts. I should have either used some lift ones, or built the truck about 4" lower. Or just not tried front leafs.
How did I miss this thread? I did it. I wouldn't do it again. My reasoning, I think, was that my other suspension setup had inherent flaws that I could not easily fix (rusty's LAs), and motivated by the concept that front leafs would be cheap and work well, I tried it. My results were less than spectacular. Image Not Found Flex is alright. That was all that was alright. Honestly. Leafs suck, period. Luckily we don't have any F-toy retards to argue with me about that on this site. Anyways, I bent springs, nearly broke one, had ugly axlewrap, found the leafs had too be on too wide of a centre to work well with a narrow (61") axle, and they would unload while climbing. Oh, did I mention axle wrap? And the steering was slightly vauge, which is inherent to not having a track bar. You have coils and links, for the actual cost of swapping in leafs you should stick with coils and links. And you can actually have somewhat proper suspension geometry with coils.
Hi Guys... Need help desperately!
DirtyComanche replied to lilredtruck's topic in MJ Tech: Modification and Repairs
You used the tranny out of the XJ? The CPS (crank position sensor) is based off the flywheel/flexplate. You have to use a renix (87-90) flywheel/flexplate or it won't work. Otherwise, I'm somewhat at a loss. -
High idle on brakes = bad brake booster. The booster is leaking vacuum (okay, it is leaking air into the intake) and causing the idle to rise. Unless it is always or randomly high, then I'd suggest IAC or TPS. Your gauge problem I don't know about. Bad sender? Bad guage?
WJ isn't 5x4.5, but 5x5 IIRC.
231 swap to 242 questions
DirtyComanche replied to robfg67's topic in MJ Tech: Modification and Repairs
Oh, your BA10-5 is 21 spline. I thought you hadn't counted the splines on the tcase input yet. -
I don't think so. Early AW4s were 21 spline. But that ended in 89 with the introduction of the AX-15 (23 spline), AFAIK. But, they might well have still used a 21 spliner in a 90. Edit, althought it might have been behind a TF-904 I guess. I think they're 21 spline. -
Should be good one 2 and 3. And I think 4 as well, it just needs to be adjusted. For #1 you can rip all the lines out, buy you'll lose the 4wd indicator light. No biggy? -
Okay, I guess ya got me there Pete. :cheers:
They aren't really rare. If anything it is rare to get a working BA10-5. AX-15s are perhaps more expensive because of desirability, but there is plenty of wrecked jeeps to yield them.
There's a reason for it though... It is a good idea. I save about 20-25% of each pay check, the majority is for long term and some of it goes into the 'fund for whatever' account that if it grows too much I transfer into my long term savings. It's nice knowing that if I lose my job today, I have enough savings that I can go for a couple months without being employed. And if I don't lose my job, I might actually be able to retire before I'm 90.
I wouldn't use a self tapping screw in a structeral application. It is wrong. Sure, they might be rated. I don't care. I personally think welding them on and damning all thoughts of removal is the easiest method that is acceptable. The better choice, but much harder, is to drill say a 3/4" hole through both sides of the frame rail, weld a peice of 3/4x.120 DOM tubing in the hole as a sleeve, then bolt it on with 1/2" bolts through the frame. 1/2" bolts are stupid overkill, but it depends what you can get for tubing to use as a sleeve. Accurate Gauge and T&S Tubing are the guys in PG to talk to - I haven't asked for anything smaller than 1"x.120 DOM though so I do not know the avaliability of smaller sizes. Other thoughts that I've had is rivetting them on. I don't know of a commercial (read, affordable) rivet that would work for this. Perhaps a steel Cherry 'Q' if one can actually still buy them. But, that's a little more complicated. Removable though, just a PITA when the time comes. My choice would be to do weld in rocker replacements. I think they look better and offer more clearance. But, if the rockers are mint it's really hard to bring yourself to cut them up. I buy junk vehicles for a reason - no second thoughts when it comes to sheetmetal removal.
It depends how bad the locals are trying to rip him off. Once you throw in shipping and brokerage, plus waiting a week (or more) for something to show up, often there's no point ordering from the south. If rockauto ships via UPS, instantly there is no point. I won't buy anything out of the US that is shipped UPS, and I tell that to every vendor who won't ship things otherwise.
