Everything posted by Blue88Comanche
Direct Mount Coolant Temperature Gauge
Blue88Comanche replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
that is awesome! :thumbsup: -
And you owned this truck how long?....lol8 years, but to be fair I rarely opened the passenger door or even rode in that seat. Actually I think I only rode in the passenger seat twice I can remember last time being 2 or 3 years ago.
Today I discovered the passenger seat will tilt and is not a one position seat like the drivers seat.... But I'll never benefit from this discovery cause I don't use that seat lol. But Katelyn is happy now she can adjust the seat for a more comfy ride. I also cleaned out all the junk behind the seat and in the bed toolbox, sooooo much more room. Now I have all my emergency gear behind the drivers seat, an ax and gallon of water behind the passenger seat and a mostly empty tool box. I am very happy with my progress today. Just need to clean the oil out of the tool box. Sent from my iPhone using Tapatalk
someone tried to buy Blue88Comanches Comanche today
Blue88Comanche replied to Black89Comanche's topic in The Pub
the highest offer i remember was 4K, But i'v had about 6 people offer to buy my MJ, and a couple of mom and pop used car lots offered as well while we where looking for dad's jeep. if only i could get someone to buy my car instead... -
it should be doable, i think i saw a couple threads on here. you will need a switch for the brake and the clutch to deactivate the cruise control.
- 20 replies
- Cruise control
- Electric
(and 1 more)
Tagged with:
can't tell from the pics, but if it has Disk brakes and you have a later 8.25, they should be a direct swap.
NP 231 vs NP242 shifter differences
Blue88Comanche replied to cruiser54's topic in MJ Tech: Modification and Repairs
you can move the shift gate from one to the other. and it can be done while in the cab with the linkage hooked up. i swapped mine after i did my novak cable swap -
1997 Bass Tracker Pro Team 17
Blue88Comanche replied to Blue88Comanche's topic in Member Projects: Other Cool Stuff
Couple more updates, Got the bilge pump unclogged and running And now we won't sink as fast.... by Blue88Comanche, on Flickr And we took the boat out to Presley's Outing. Presley's Outing by Blue88Comanche, on Flickr Presley's Outing by Blue88Comanche, on Flickr Presley's Outing by Blue88Comanche, on Flickr- 10 replies
- Bass Tracker
- Tracker
(and 7 more)
Tagged with:
I'll start with the D30, it has developed a pinion seal leak over the past couple months, how difficult is it to change the pinion seal my self? And where can i get a new D30 breather tube? mine is damaged in a couple places and the plastic fitting is broken off. The D44 has apparently been leaking for a while through the passinger side shaft seal. i discovered it when i finally decided to fix my parking breaks not holding properly... brakes soaked in oil will do that... can i buy a shaft with pre-installed bearings and seal?
ComancheClub meet-up in Birmingham AL (postponed?)
Blue88Comanche replied to Pete M's topic in The Pub
not sure if i can make it or not, life has been busy lately.... But if i do go it will be in my Hybrid, i can't afford to feed MJ on a 658 mile round trip. Ill be keeping tabs on this thread and will let everyone know if i can make it! :driving: -
Blue88Comanche Pioneer 4X4
Blue88Comanche replied to Blue88Comanche's topic in Member Projects: Your Comanches
you forgot to add the part where i helped you and bought you some parts :thumbsup: :wrench: I sent you to the parts store to get the battery tested, you are the one who decided to come back with a new belt to put on it as well lol -
Down Shift issue AX-15
Blue88Comanche replied to Blue88Comanche's topic in MJ Tech: Modification and Repairs
I told them 10w30 for the trans. now if they did that or not who knows -
Last week I took my jeep to a local fast lube to get the trans and front diff oil changed. now it occasionally pops out of first, and when going from 5th to 4th it grinds or pops out of gear. All up shifting is fine. aside from oil is there anything they could have done to the tranny?
Replaced the outboard's gear oil not much else. If nothing comes up I'm looking forward to taking it out this weekend for a test run.- 10 replies
- Bass Tracker
- Tracker
(and 7 more)
Tagged with:
Yesterday I spend a couple hours pressure washing the carpet in the boat. I am amazed it cleaned up so well! Some during and after pictures..... Because i always forget the before photo.... Dirty Mid Deck by Blue88Comanche, on Flickr Just Started Cleaning Rear Deck by Blue88Comanche, on Flickr Clean Front Deck by Blue88Comanche, on Flickr Clean Mid Deck by Blue88Comanche, on Flickr Clean Rear Deck by Blue88Comanche, on Flickr All Nice and Clean by Blue88Comanche, on Flickr Dad bought a new starting battery yesterday as well, Some time this week I plan to replace the gear oil in the outboard's lower unit.- 10 replies
- Bass Tracker
- Tracker
(and 7 more)
Tagged with:
More work done on the boat today, Replaced the fuse box. Old Fuse Box by Blue88Comanche, on Flickr and the new New fuse box by Blue88Comanche, on Flickr and its alive! Short test run complete, tomorrow I'm planning to replace the lower unit gear oil, run it again, and pressure wash the boat Turns out my no start issue was a connector wire under the console corroded apart. So for the time being i bypassed the connector and spliced the wire back together.- 10 replies
- Bass Tracker
- Tracker
(and 7 more)
Tagged with:
More Pictures! Untitled by Blue88Comanche, on Flickr Untitled by Blue88Comanche, on Flickr Untitled by Blue88Comanche, on Flickr Untitled by Blue88Comanche, on Flickr Untitled by Blue88Comanche, on Flickr Untitled by Blue88Comanche, on Flickr Untitled by Blue88Comanche, on Flickr Untitled by Blue88Comanche, on Flickr Untitled by Blue88Comanche, on Flickr Untitled by Blue88Comanche, on Flickr Untitled by Blue88Comanche, on Flickr- 10 replies
- Bass Tracker
- Tracker
(and 7 more)
Tagged with:
The starter works, i jumped the solenoid and it works as well. I did not try to start the motor by jumping it. I tested the connections on the key switch and they all seem to work. The gauge back lights work but function of the gauges are not at the moment. Odd are once i discover the issue with the gauges the starter will work properly as well... Hopefully....- 10 replies
- Bass Tracker
- Tracker
(and 7 more)
Tagged with:
Two tires, bananas, and red potatoes. (My Lady was hungry) lol- 10 replies
- Bass Tracker
- Tracker
(and 7 more)
Tagged with:
Reserved- 10 replies
- Bass Tracker
- Tracker
(and 7 more)
Tagged with:
Last weekend, my family and Katelyn went up to our Fishing camp for the weekend to relax and get away from everything, but also to begin another project. Steven and I are working on my Grandfather's Bass Boat and hope to get it running again soon.. According to my grandfather it ran fine.... two years ago, and stored outside without a cover and no other protection or storage set up.... First up was to replace the trailer tires and we bought them before we left for the fish camp. First inspection shows, cracked seats, rotten seat boards, dead batteries, mildew, and leaves everywhere. The boat made the 3 hour trek back home without any issues. First parked it at Stevens house to clean off and to attempt to start after the batteries charged, the motor will not crank no power to starter. So yesterday i moved the boat to my house where it will likely stay for the foreseeable future. thus far i have determined the trolling motor, Accessories and, nav lights all work. I'll keep posting updates and pictures as i progress. Here are a few pics of the boat!
- 10 replies
- Bass Tracker
- Tracker
(and 7 more)
Tagged with:
Closed to Open Cooling DIY
Blue88Comanche replied to Blue88Comanche's topic in MJ Tech: DIY Projects and Write-Ups
Heater core input is on the bottom, output is on the top. this helps when purging the air out of the system.- 18 replies
posi lock on dana 30 cad axle
Blue88Comanche replied to NorthWoods's topic in MJ Tech: Modification and Repairs
The D30 most likely has an Open Diff, meaning if the cad is unlocked and the TC is in any 4wd mode, only the rear would get power. with the cad unlocked the spider gears will spin as will the passenger side half shaft. Locking the cad will allow the front axle to work like a normal axle and you will have power in all 4wd modes. if the D30 has a locker then the cad would make it 3wd and the drivers side wheel would have power when the cad is unlocked and the tc is in 4wd
