Everything posted by Chico
I thought you needed tires?
Yes it screws into the metal part of the kneeboard (I think that's what you call it) and it's right underneath the headlight switch.
Will your heater/vent fan work with key off??
Chico replied to jtdesigns's topic in MJ Tech: Modification and Repairs
Are you talking on the engine side? I'll check I might have pinched some wires when I put the booster back in... I'm just about to run out of steam on this truck!!!! yep. -
Can you see all the underdash wiring from where you look? Mine did the same thing as all the wires burnt/melted together when I had my harness problem. Check all the wires by your fuse box under the dash and on the side of the engine bay. I'd make sure no wires got stripped, are touching and melting together like mine did. -
My truck had all kind of wobbles. Are all four rims straight? And I had bad vibes in the back because my rear shocks were crap.
phillip
Well, over the weekend I ran Prestone's flush thru the engine with water and the heater on full blast for about 4 hours. It sat in my driveway because I haven't put the front clip back on yet. Drained it out. Pulled the rad again. Changed the waterpump. Put them back on, filled the system back up. Ran a couple heatup/cooldown cycles and burped the system out of the back temp sender. (It didn't need it). Still no change in temp. I'm still running 215-225* I'm gonna button everything back up and run my electric fan on a switch to see if that will bring the temp down. MY REMINDER TO PUT A PIC HERE.
The other thing is that the harnesses for the two companies might have differnt colors.
Did you by any chance get a manual with the deck? I think your problem is that you need a constant power supply to the memory wire. Is there two power wires back ther right?
Told YA :D Chico, how much did you sell the stereo for? :rotfl2: I didn't need to. Mine got stolen about a month ago, but I already got it back. Unfortunately, it's not usable anymore. If your truck's a five speed I'll tell you what happened. Some dumb white kid from Kessington figured it was an easy car to take for a joy ride, couldn't figure out how to shift a twenty year old truck because his parents are probably either crackheads or alchies and never taught the dip$#!& how to drive. So he gets four blocks away after bumping and grinding up the tranny, decides it would be faster to walk and takes the stereo so he can trade it in at the pawn shop to hit up the dollar menu at Micky Dee's. And if ya got an AW4 it's probably that your @$$ stinks and he couldn't take the smell inside so he used the $5 the pawn shop gave him to buy a bar of soap and some deodorant and got a shower for the first time in two weeks. All joking aside, I'm glad you got the truck back almost complete :cheers: Weird thing is if they took the toolbox they had help and I'm surprised they didn't take the rims and tires. All the better for you :D
No, but then again it was winter, the temp outside was 40* or lower and since I drive around all year round with the windows down the heat was always on full blast so the temp would be kept down anyway.
Told YA :D
Nope. The factory t'stat only has the hole at 12:00 Well, then I'm oficially done replacing everything with the cooling system. I'm wiring up the electric fan this week to run on a switch.
Back in the winter when I put a thermostat in because the PO wasn't running one and the truck wouldn't heat up and run like crap I put a 195* in and drilled a whole at the 12 o clock position only. You guys think it makes a differnce I didn't put one at the 6 o clock position?
Rich I finally got the pump in tonight and ran it. I think it's leaking though. No change in temp. 215 to 230. I'm going to wire my electric fan on a switch this week. If that doesn't lower the temp I'm gonna let it run outta coolant and oil and drive it till it blows and catches fire. :D Just don't kick it... I did that once and was limping around for like a week! :jump: :rotfl2:
Thanks for the replies guys. Where did you buy the Right Stuff, and does anybody know if Autozone carries it?
I've read all the threads on here and checked Alldata and I'm getting differnt answers. Should I put RTV on the water pump gasket when I install it or put it on there dry and clean?
Up to what year engine can I use?
Chico replied to Chico's topic in MJ Tech: Modification and Repairs
Nice option, but not that deep at the moment :eek: -
Yep, Jasper's the company that wants $2600. -
You know now that I have the front clip off and I'm having so many problems with the cooling issue I was thinking of going a differnt route. I have an 88 4.0 in there now. If I keep all the renix stuff and externals, up to what year Cherokee can I pull an engine out of to replace my 220,000 mile one. Obviously the newer the better with lower mileage because it makes no sense to do it with a 1990 that already has 150,000 miles plus. Would I be able to use a realatively new one that's maybe been in an accident (side or rear hit)? Is this a viable option or should I just buy a reman one for $2600 and save myself a lot of headaches?
Pulled the old rad with LEAD NOT FOLLOW"S post. http://comancheclub.com/forums/viewtopic.php?t=7695 Put the new one in but I'm still running warm. Bought a new waterpump from Autozone for $35.00. Make sure you buy the one that says reverse rotation. I also got a bottle of Prestone cooling system flush. I'm supposed to run it thru the system with just water and that for 3-6 hours of operation. This is supposed to loosen up any build-up and rust in my block from years of neglect. When I drained my 50/50 mix last night again to add this all of it came out clean with just a few specs of crap in it. We'll see how it goes. Hopefully I'll get it all buttoned up this weekend, but it's getting kind of hard doing it outside at night with a flashlight in between my teeth and under occasional thunderstorms. I envy everyone on here with a well lit garage :D
Rich, here's LEAD"S post http://comancheclub.com/forums/viewtopic.php?t=7695 Oh and make sure your waterpump is reverse rotation and is stamped with an R on the back. The moron at Autozone tried to sell me a differnt one.
Rich, I followed LEAD NOT FOLLOW"S DIY post on changing from a closed to open system. He goes step by step on how to remove your rad. It only took about 15 minutes to get the whole front clip off his way and makes working in there really easy. Great detailed write-up with pics. Anyway keep us updated and good luck :cheers:
