so i started my truck up yesterday to start working on it again started just fine backed it up, turned it off to switch gears (need to bleed to clutch) then put it in 1st to move it into the garage and nothing on power to anything
no power to my aftermarket fuse panel no lights no power to my air compressor for the air ride , i checked the battery just fine, replaced with a differnt battery, and nothin made sure all the wires were hooked up right no fuses were blown the battery wires looked fine, then checked to see if i had a good ground with a test light (from the + battery post to the body) and had power but couldnt find a dvom to see how much power i actually had but both batterys were just takin off the trickle chargers
any body know what is wrong or had the same problems????????
thanks
