cody4359
Everything posted by cody4359
  1. i got a pretty decent 2.5 ton jack from costco. it has a low profile which is good for my car and lifts around 20-24" at max stroke, i don't rember the exact heigth. it was $90 and i think when u buy stuff from costco, if it breaks/stops workin, take it back with the recipte and the swap it out
  2. glad i was bored and thumbin thru the diy section. awesome idea, went and found a 97+ washer bottle and will be doin this shortly. thanks :clapping:
  3. id like to get my name on a waiting list lol around how much were they?
  4. thanks 1987comanche :cheers:
  5. I'm confused, you swaped a 4.0 fuel pump into a 2.5 tank/sending unit. the 4.0 pump was an inch shorter than the 2.5 pump but fit fine (i under stand that) but then you wrote could you clairafy :dunno:
  6. from what i saw in the previouse pages, the driveshaft specs were for stock height mj's? can we get a lifted chart going or with the longer wheel base than xj's do i need to not worry about SYE and length?
  7. would there be any interest in CC apparel, like a hoodie and hat? i think it would be cool to have the Comanche Club on it with maybe either a pre 96 grill or post 97??? maybe chapers like the pacafic northwest or so? i wouldnt be doing it, maybe an idea for pete or somebody else on here?
  8. well i went to the junk yard and got 97+ door seals for the mj, also got ANOTHER 97+ header panel, the total os 4, time to put one or to on ebay
  9. no they won't part it out, and doubt it gets 20 mpg in the city http://seattle.craigslist.org/kit/pts/2149188865.html
  10. you can also adjust the linkage. take off the plastic cover below the tcase hande. i believe there is supose to be .125 (1/8") from the handle to the stop/bracket when its engaged in 4lo. in your hayes manual it tells you how to do it.
  11. you sure thoes welds are going to hold that winch on when you put a load on it?
  12. just got my calendar today, one or 2 cell phone pics so a lil unclear (I'm picky) but i like it. maybe next year add in a few specs like motor/ drivetrain, tire size/gears and length of build???? just a suggestion. anyways ive looked online for a xj only calander before and never found one, great job. don't know where your having them made but costco makes personal calanders if u wanted to compare $$$
  13. what lift/size tires you have on it? looks good
  14. a clip from 4wheel & offroad "canadian company HPA Motorsportshas developed a conversion kit that drops a 1.9 vw turbo diesel into a yj. tj kit in the works. after tuning ecu with power flafsh, HPA claims the diesel will put out 190 hp and 289 ft lb tq and will get 40-47 mpg" in the yj they were usin the ax5. I'm sure for the right $$ or just time and fabbing it could be done in a mj. also i think extreme 4x4 on spike tv did a vw diesel swap into a sammy. when u get ready to swap the motor out ill take your 4.0 fuel pump/sender off your hands :waving:
  15. I'm in the middle of that too (buckets, tilt ect). I'm thinkin since I'm doin buckets and center consle ill turn the foot e-brake into a hand ebrake with xj parts. havent looked into it but i doubt it would be difficult.
  16. :hijack: this is an old one so ill do it. I'm trying to understand this, and wondering if its a case by case scenerio or sumthing, as in are the sending unit the same between short bed/long bed, and from the 2.5 to 4.0?? I'm sure the pumps are different from 2.5 to 4.0. from what i understand no new mj senders are avaliable. i am doing a 96 xj 4.0 swap into my 89 mj that has a 2.5, its a swb. i have pulled the pump/sender from the xj, but not the mj yet. does anybody have pictures of how they modified/configured a cherokee pump/sender to fit in the mj tank with the baffle? or will my 4.0 pump swap onto the 2.5 sender?
  17. ctrl alt del, and alt tab are as far as i go lol
  18. yup that looks familiar. i have 3 screws in mine. ive broken my ankle 3 times snd both bones in my arm, theres a supplement called BFC- bone flesh cartledge. all 4 times i healed in half the times the doctors thought i would. pretty sure any pharmacy has it or health nut place.
  19. lookin good. are you goin to cover the fiberglass?? i looked up dynamat on ebay the other day and saw another thing fatmat, way cheaper for alot more, reviews seemed good. just did a quick search and found this link it u want some good cheaper alternatives http://forum.ecoustics.com/bbs/messages/4/124995.html
  20. X1000000!!!! the sticky on the classifieds link has it in plain view without openig it :wall: :wall: :wall: :fs2:
  21. what are H.C. packs?
  22. i just took a chisle/wedge to it and bent it back and forth til it broke the spot welds. here's a small bit of info http://www.comancheclub.com/forums/viewtopic.php?f=2&t=27753 edit: here's a few more pics this was a waste of time to do, still havent gotten around to spot weldin it back together 96- cherokee door, pretty sure same as mj after welding up old holes and made new, kinda ugly cause i reamed the holes a bit but u get the idea. i made the holes a little bigger so i could adjust where it sits.
