Everything posted by cody4359
ok, i use to wash the honeybucket trucks out in the belfair yard lol i would hurry thru them then go to bremerton raceway and get paid to watch the racing :jump:
cool just tryin to see who around. when i wheel I'm usually alone and my previouse rig wasnt built, just lift tires and rear limited slip, so i couldnt do anything too fun for risk of being stranded. here shortly ill be building a real garage/shop so ill get my mj swap done and ill be out and about. where is that tatuya (spelling wrong) in your vid clip at? sounds familiar, is it around greenwater?
3 doors down from me my neighbor has a silver long bed with 30 or 31s. don't have mine running so i havent gone over and introduced myself yet.
Suggestion for a member galery
cody4359 replied to Ridgerunner's topic in Forum Issues, Ideas, Testing
it might be what you just said just diff wording but it be nice to have the option to load pics to your profile page, so when u look at a member you can see who ur talkin to and their rigs. -
i took a small thin washer and ground it down to fill the big hole, tacked it then put a piece of brass behind to keep me from blowin thru on the other holes. aluminum works to edit: here's a few more pics this was a waste of time to do, still havent gotten around to spot weldin it back together 96- cherokee door, pretty sure same as mj after welding up old holes and made new, kinda ugly cause i reamed the holes a bit but u get the idea. i made the holes a little bigger so i could adjust where it sits.
just do it. u need to the door latch or striker piece. get a piece of flat bar, drill it for the bolts, weld nuts over holes, and drill new holes in the cab a little bigger than the bolt so you can fine adjust the striker for fitment. i welded up the extra holes from the old style striker.
looks good, but imo u should pain the engine compartment since the motor is out. I'm a bit if a detail freak tho. how did your rocky road brackets fit? i had them on my xj and the quality wasnt that great. where the bracket and brace bolt together there was a big gap. needed to make shims so they would tighten up together right. also with the 6" lift and 33"s do u need the fenders trimmed??
1989 Short Box Comanche "Manche"
cody4359 replied to pilotblake's topic in Member Projects: Your Comanches
nice hood i want it. did u cut it, space it up then weld in the filler plate or how did u do it?? also what brand is that canopy? -
cheapass! u buy a brand new truck then hack the coils instead of buyin lowered ones :rotfl2: lol i had a ranger that i welded up the diff, heated the coils til it was on the bumps the took all but 1 leaf out so it was on the bumps. ya rode like crap but it looked cool. you take the manche out much?
did you do bags front and rear on the dakota?
hmmmm now i thought it was just a coincidence there was a pic of you 2 together, thanks for the help :fool: :jump:
nice lookin truck man :clapping: your floor looked alot better than mine
as in perfect health you mean a 6" lift and 33s and locked front and rear then awesome :clapping:
cut past all the rused thru metal til you find solid. u can take a lil screw driver and hammer then tap around to find the thin stuff, ull be able to tell by the feal and noise (and looks) if its just surface rust or more. fyi its a PIA to try weldin thin metal and even worse when its half rusted thru. keep the gaps tight and itll be fine http://c2cfabrication.com/store/index.p ... e694kjk1i4 youll find your floor pans here
what are your plans for the mj?
cool everett isnt to far away. any place to wheel out there? or where do you go?
just wondering if any members on here are around me in tacoma,wa every now and then i see quite a few mj's runnin around
Gas tank problems solved. Thanks
cody4359 replied to Squeegy410's topic in MJ Tech: Modification and Repairs
brass doesnt spark. its alot softer than steel so it just chips and gets "mushed" -
if your worried bout gettin thing dirty then why have that white wife beater on :rotf:
U-Bolt Elimanator install
cody4359 replied to MiNi Beast's topic in MJ Tech: DIY Projects and Write-Ups
good to see some people can actually weld nice :cheers: -
think you need to weld a little better or atleast touch up the welds to look presentable ;)
al's liner looks like a decent kit for bed liner ect. u can color match it, and i think it has 3 diff nozzels for spray pattern. like $110 for the kit and $50 for the gun. ive used herculiner before and it sucks I'm my opnion. by the way your truck looks good.
