cody4359
Everything posted by cody4359
  1. thats a fancy spiral you got in the grill
  2. is the nv4500 the rubi 6sp?
  3. The pig has one. After replacing both bad engine mounts and a perfectly fine transmission mount that ended up being the only way to keep the fan out of the radiator during full throttle hill climbs or burn outs. wouldnt or shouldnt polyurathane mounts cure that? or did you just go straight to the chain cure?
  4. no it would be instantiouse if u had the firing order wrong. pull your plugs again and see if they already got fouled up
  5. for an all terrain ive always liked the bfg, if you drive in small gravel tho the tread picks up gravel easy and flings it around. i read a duratrack review in petersons or somewhere and it did good all round. i have no personal experince with the goodyears but they look more agressive and id be willing to try them over the bfg, just my 2 cents, sorry its not a indepth detailed technical review :idea:
  6. check that you put the plug wires on the right terminal on the distributir, one wire (2) will make it spit and sputter
  7. looking good keep it up!
  8. if its raining so hard that you losing traction maybe slow down?? 70 mph and having the back end walk out doesnt give you much time to throw it in 4hi and correct the steering. I'm NOT ALL about about saftey but that would make more sense then hoping you react quick enough before losing control. or get some pro comp extreme contact mud terrains. deep lugs never let me hydroplane, and the rubber compound was so sticky that spinning a tire was fairly difficult and didnt last long cause theyd grip and send me flyin.
  9. have a safe drive
  10. Two fans, rotating in opposing directions to cancel each other out? Really now? dual fans= side by side eletric fans, come on :doh: Tack is saddles and bridles and stuff you put on horses. also a tack is that small pointy piece of metal with a plastic grip that u stick into a wall, or pin (tack) the tail on the donkey :D . but I'm sure we all knew he meant tach., or tachometer for the easily stumpped :shake: :D suprised u didnt mention "the idals good". correct spelling since we are knit picking is "idles" ;) did anybody else look at the engine pictures and notice that chain going from the frame rail to the motor? :rotfl2:
  11. no wires stood out to me on the axles by the brakes, i might of missed them but this is the master cylinder cap Image Not Found
  12. :fool: thats for asking questions and not READING the answers :shake:
  13. did you put in a new sending unit/pump or did you just pull the parts out, paint it and try putting it back together? if its a new sending unit its a cherokee one and will not fit without mods, if its the stock u probly just need to patiently fiddle with it til it goes back from where it came.
  14. pretty much for that purpose, it it strips out you pull out the heli coil (unwind), and install a new one. with a threaded bolt hole, if you strip it out you pretty much have to step up the bolt size and rethread. I'm sure you know this but its goin to be a metric helicoil to match up with the caliper bolt, and the kit i got was like $30-35.
  15. thats still over priced with the forklift!!
  16. its been like 2 weeks, wheres the finished product :D
  17. ive found 2 chrysler 8.25 29 splines for $100 each and i put disk brakes from a zj on them for $40 from wreckin yard. lookin at gettin an aussie locker and from the webstite their $300 but out of stock. overall fairly innexpensive and will put up to my abuse with 33s
  18. cody4359
    lol
    :thumbsup:
  19. my vr6 is around 3500 at 65, i don't like it bein that high
  20. cody4359
    Chat room!...
    go the subaru brat way and mount 2 seats in the bed and give em a blanket :yes:
  21. lol as you can see i spelled back wrong, his mispelled word was a little to funny to pass up, ya I'm immature owell :yes:
  22. dick brakes in the bach huh :doh: lol are you using a adj proportional valve now that you have disks front/rear? edit :agree: you can sprinkle sugar over poop, and itll still be poop
  23. hint hint, i only grabbed it cause it looked cool lol i have no plans on wiring up that thing :) if i sell u this sentinel thingy would you want the cracked box also?
  24. cody4359
    Chat room!...
    why do you want to do that?
