offroader461
Everything posted by offroader461
  1. The last tank i got b4 i pulled the head was 23MPG...
  2. The last tank i got b4 i pulled the head was 23MPG...
  3. usually with a new filter this is normal. one should clean a filter before it is put in with an airbrush or airfilter cleaner. if you can find a K&N setup for an XJ (Cherokee) it will work. maybe try some tuner brands or go onto summitracing maybe jegs I cleaned and oiled it reguarly and had it on the jeep for 2yrs...and noticed it everytime i pulled the filter off and went on NAXJA and read some reviewed and now ill stay away from them...AirRaid is a better filter anyways IMO
  4. usually with a new filter this is normal. one should clean a filter before it is put in with an airbrush or airfilter cleaner. if you can find a K&N setup for an XJ (Cherokee) it will work. maybe try some tuner brands or go onto summitracing maybe jegs I cleaned and oiled it reguarly and had it on the jeep for 2yrs...and noticed it everytime i pulled the filter off and went on NAXJA and read some reviewed and now ill stay away from them...AirRaid is a better filter anyways IMO
  5. don't run a K&N filter period...i had one on my 87 and when i pulled the filter i noticed a crap load of dust inside my intake tube and realized the filter was doing a horrible job...i run an AirRaid and don't have that problem anymore...i won't ever run a K&N again...just my .02
  6. don't run a K&N filter period...i had one on my 87 and when i pulled the filter i noticed a crap load of dust inside my intake tube and realized the filter was doing a horrible job...i run an AirRaid and don't have that problem anymore...i won't ever run a K&N again...just my .02
  7. I had a D44 in mine and was told by a friend that it was a d35...Now boy did i fell retarded when my fellow MJ buddy came by and proved me wrong :wall: :dunce: :fool:
  8. Hmmm I'm on here enough i think i can be persuaded to MOD the classifieds :D :banana:
  9. take a pic of the rear axle so everyone can verify what rear you have...don't just assume :cheers:
  10. Looks good but be careful with those...i had a set of 32 Kumho's and the sidewalls are very soft and love to punture easily :headpop:
  11. its a bit confusing and hurt my eyes at first :no: but I'm getting used to it already
  12. I'm at 7.5" lift on my SWB with no SYE..i have plenty of engagement in the d/s
  13. i had 4.5" on my MJ and had 32's w/3.75 backspaced rims and didnt rub with fender trimming you could fit 32's on 3" but if you don't wanna trim IMO 4.5 is the way to go...My ride on Short arms wasnt bad at all but compared to my 7.5" lift with Dropbrackets its night and day
  14. You and i should meet up so i can take a look at it and see if i wanna spend the money on it :cheers:
  15. it will bolt up but the ports don't line up correctly so unless your putting on the HO head it would be pointless
  16. Shortly after i bought her in 2004 Now as of Oct 2008 After Waggy clip
  17. I hate the stupid waiting period for free agents...i have 2 QB both now injured (Romo/Kitna) so i got into the free agent pool and everyone has 2 QB's so i finally pick an ok replacement and someone else decides to take him so now i have to wait till Friday to see if i get my new QB and if i don't I'm officially done for this week since i won't have a starting QB :headpop: :mad: :hateputers:
  18. Yea CURBDOG17....saw pics of his retarded double shackle over there on NAXJA...he should not be allowed to own anything 4wd :roll:
  19. my ignition switch(down at the bottom of the column) shorted between 2 of the tangs and the blower/radio/guages yada all quit working...swapped it out and havent had a prob since...mine was due to a floppy tilt mechanism on the column
  20. Ask and you shall recieve....here's a couple of the Wagoneer clip completly installed still gotta finish up my head gasket replacement...I'm a little over half way through :nuts:
  21. yea it keeps the spring on the front axle if you happen to flex enough to clear the bumpstop tower
  22. Looks good but HOLY LONG SHACKLE :eek:
  23. wow thats a ton of rust...probably couldve found a better front axle for cheaper but can't beat $5 for the rear LOL :cheers:
  24. I'm betting you weren't the only one. :D Me also..on two leagues...
  25. Hey what do ya know...i finally got a WIN!
