fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. Are you adding some sort of railing? Don’t want to drop anything on that shiny MJ.
  2. fiatslug87
    Fly bys?
    Just went over the house.
  3. Some kind of Lamborghini???, 9/7/22 7:00pm, north bound 680 in Alamo, CA.
  4. Welcome! Make sure to add it to the ‘92 registry.
  5. Island time, brah.
  6. Welcome to CC, congrats and have fun with it! Add it to the registry if it’s not there already (search for the VIN). https://comancheclub.com/forum/29-1986/
  7. Not sure if this has been posted already, yes I'm lazy.
  8. What do you do? If you don’t mind me asking.
  9. Two Eliminatros? Nice.
  10. This is a Laredo Metric ton. Your paint codes are: Primary PA2, Sterling Metallic Clearcoat (3D on the VIN plate) Secondary QXJ Charcoal Gray Metallic Clearcoat (4M on the VIN plate)
  11. You should be fine at 94.
  12. Factory spec is only 75 ft-lbs (65-90 on recheck) (102Nm)
  13. My opinion is NOS Mopar. I had Bosch in the past and they worked great but it seems all manufactures have changed their design. They used to have white ceramic bodies with three wires coming out to the three pin connector, now all seem to have metal bodies with four wires going to the three pin connector. All the recent ones I tested, Bosch, NTK, Omix do not have the correct resistance between A&B, 4 ohms but spec is 5-7 ohms and did not cycle properly based on the REM. See this post
  14. On eBay in Bennington, VT
  15. @eaglescout526give the people what they want.
  16. August 2022 update, see first post. 26 new additions this month for a total of 1944.
  17. Build sheet?
  18. Build sheet?
  19. Build sheet?
  20. Added to 91 registry
  21. It bolts to the side of the intake manifold, driver side at the back. It holds the fuel supply line.
