8
Everything posted by fiatslug87
It bolts to the side of the intake manifold, driver side at the back. It holds the fuel supply line.
Big Green Egg smoked rib roast, baked potato, pop-overs and the obligatory vegetable, cauliflower gratin.
Manual transmission neutral safety switch
fiatslug87 replied to mdmonroe's topic in MJ Tech: Modification and Repairs
If you look at the 87-90 parts catalog (https://comancheclub.com/topic/60812-need-new-links-to-the-various-factory-shop-manual-pdfs/#comment-625489) the only listings for the NSS lead to the auto trans, that may be enough for them. -
What is that shock connected to?
^^^ Nice!!!
Project 3rd Time is the Charm
fiatslug87 replied to 89eliminator's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Is it in the registry??!! -
What fitment size is your dual post?
I like squirrels, they’re very entertaining. https://drive.google.com/file/d/1t0CBKeEDcDGQ4XpULGB5Vy1Oj6XSqmwb/view?usp=drivesdk
WJ Booster Incompatible with MJ
fiatslug87 replied to Salvagedcircuit's topic in MJ Tech: Modification and Repairs
Stock spacer from a 95 XJ. -
The 95 (&96???) XJs had an aluminum spacer with the dual diaphragm booster. Also had a foam gasket between the firewall and spacer. -
Lumpia cooked outside in the Blackstone deep fryer. IMG_0542.MOV
Try 1JTHS64P0JT161597, if it works please change the title.
It got hit so hard its grill turned upside down.
If you look between the cab and bed you can see where the drain holes are, one in the center and two a couple of inches from each bed side.
MTS makes replacement senders. http://www.mtscompany.com edit: that one is an MTS unit
