fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. @jdog can you get the build sheet for this one? Thanks.
  2. Our very own Brent’s MJ on eBay
  3. On eBay in Olathe, KS asking $13k seems like a great deal for a Crewmanche conversion.
  4. Two of mine were in much worse shape and never had an issue with the belts.
  5. Are you sure you’re tightening the belt enough?
  6. If all you’re replacing is the sender gasket and lock ring it should be a piece of cake. Just don’t move the sender. I would use a brass punch or rod (non-sparking) to knock the ring loose and tighten.
  7. This is the correct place, be patient someone will get it for you.
  8. My O2 comment was assuming it was up to temperature.
  9. Your O2 sensor is not working properly. Test the resistance between A&B on the sensor itself, should be between 5-7Ω. Aftermarket ones have not been working properly in my opinion. Your TPS reading at idle should be 17, easy to adjust search in Cruisers Tips.
  10. On eBay Link And Another
  11. Put it on your watch list, he’ll knock off $100.
  12. If it’s that weakened, I would loosen the steering column support rods and drop the column a little.
  13. On eBay in Soldiers Grove, WI.
  14. I really didn’t need a WilderNest camper but it worked out GREAT!
  15. Multitasking: doing twice that you should half as well as you could. You need a dedicated 2wd SCCA truck.
  16. Drilled a series of 5/16” holes, one inch apart, in the sleeping platform support poles to receive locking quick release pins and added adjustable feet for fine adjustment. Originally they had hose clamps but they would always move when load was applied.
  17. April 2025 update, see first post. 9 new additions this month for a total of 2376.
