fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. @JMO413 can we get the selling location for this one? Thanks
  2. My guess is since those are not MJ leaf packs the center is off.
  3. Yeah, those are not MJ leaves, MJ leaves do not have those angled ends.
  4. Appreciate that. Maybe I’ll have to set up a “glamour shot” since we can’t take the MJ camping due to space considerations for the dogs.
  5. There’s been a 20lb tank in the box on the front of the trailer. A heat exchanger isn’t necessary, the tank heats up the water pretty well in moderate sun and I don’t plan on doing any hardcore winter camping. Plus a cold shower can be refreshing. 🥶
  6. Added a couple of things to make camping a little more refined. We had a 10lb propane bottle that attached to the FJ Cruiser that we no longer use so I decided to use it for the Buddy heater instead of the 1lb canisters. I drilled a hole in the wheel well for the hose which is plugged when not in use. Here is how the tank is transported on the FJ freeing up space in the trailer. When we set up camp we now swap the propane tank for the fire extinguisher keeping it close to the cooking area, it's also on a quick release so it can be moved to the campfire or inside the WilderNest easily. The setup inside the WilderNest, you can see the hose going into the bung in the wheel well. And outside. Made a telescoping light standard using a camera monopod attached to a PVC coupling mounted on the tongue with a hose clamp and secured with a small quick fist at the bed lip. Added nutserts and screwed a garden hook to hang a light (sorry for the terrible exposure). Added a shower tent to the FJ, it mounts to the roof rack and is easily removable. The nozzle attaches to a foldable arm that stays on the roof rack and is attached using a small quick fist making it adjustable. All this worked out quite well camping last week. Now to come up with new projects.
  7. Saw it on eBay and wondered if anyone has it or has info about it. I know that Nathan died at the age of 18 in 2023 driving his Miata.
  8. On eBay in Vista, CA
  9. On eBay asking $19500 OBO in Brownsville, TX.
  10. Now for sale on eBay asking $17995 in Fairfield, OH.
  11. Just so everyone knows, that tire bracket only fits the LWB unless you drill holes in the SWB’s frame and only holds up to a 235/75R15 tire.
  12. Do you know how your previous one is doing rust-wise in that environment?
  13. But you’re not biased.
  14. Steering box spacer, goes between the cross member and box. It’s metal not rubber, right?
  15. On eBay in Evansville, IN asking $9750 OBO.
  16. Do you have a Renix Engine Monitor? If not check the resistance between A & B of the O2 sensor reading should be 5-7Ω. You can also check EGR function? https://comancheclub.com/topic/73480-21-–-renix-egr-valve-test/#comment-769327 From the FSM is in this post. https://comancheclub.com/topic/38225-egr-solenoid-renix/
  17. There’s only one bolt which goes through the “cup” portion in the rear hole the other hole is for alignment of the bracket. They have a raised portion on the back.
  18. @JIMMYRIG no apology necessary. One of the great things about this forum is any question can be asked or re-asked.
  19. And pretty soon they’ll be on an MJ I believe you’ve driven.
  20. I believe they were a factory/ dealer accessory. They are listed in the Mopar Accessories catalog dated September 1991. Apparently there were also stainless ones available.
