pizzaman09
Everything posted by pizzaman09
Water in passenger side footwell
pizzaman09 replied to Virginia's topic in MJ Tech: Modification and Repairs
Do you have opening vent windows? That's where I get my leaks. -
Isn't that just the throttle cable?
That's a Ferrari 328gts. Late 80s.
June 2023 - The Eliminator Daily Build
pizzaman09 replied to 89 MJ's topic in Comanche of the Month (MJOTM)
This is pretty awesome. Does it actually handle better than stock with the nice low suspension and changed away bars? -
Smog fail, what’s next?
pizzaman09 replied to Dammerung's topic in MJ Tech: Modification and Repairs
I got my first Comanche because the person who owned it had spent two years trying to get it to pass CA emissions. I got it for a good deal and drove it to PA. As a result of his work I ended up with a shiny new set of Banks headers and a new cat. That said, everyone else here are suggesting the right things. If all the sensors and lines are up to snuff, then it should pass. Definitely check those intake/exhaust manifold bolts. -
Is it possible that the little black tank is under the top height of the raildiator? Could you simply be fighting gravity?
I was able to buy the correct NTK one on Rock Auto last year. It completely fixed my O2 sensor issues and the tuck now runs like a champ.
1990 Comanche Eliminator
pizzaman09 replied to pizzaman09's topic in Member Projects: Your Comanches
Upgraded the transfer case linkage to the Azzy design version. I ended up with the cheap Amazon version which did require me to shorten the turn buckle threads about 1/4" on each end. It shifts so much easier and smoother than it used to. It was astoundingly fiddly to install though. My combo is an AX15 with an NP231. I had to put the transfer case turnbuckle on the farthest out hole of the three on the transfer case shift bracket. The handle bracket needed to be installed in the tilted position forward. -
I have a very experimental project car, it's a BMW inline 6 with a a homemade engine head. Over the project I've dealt with many exhaust leaks into the coolant. I tired a few stop leak products. The one product I tried , which was some ancient bottle of something made by Prestone worked great. I also tried k seal and wasn't pleased with the amount of what appeared to be copper flakes it had in it which just made a mess of the whole cooling system. At this point it sounds like you don't have much to loose, I'd try what ever product seems like the advertising works best on you and give it a shot. You'll have to flush your cooling system once the engine is replaced anyway.
Are these Turbines worth it?
pizzaman09 replied to robfg67's topic in MJ Tech: Modification and Repairs
I spent $125 a wheel to get my Eliminator wheels refinished. They are far less complex that the turbines. If you just want to sandblast them then it could be economical to refinish them but gosh $550 seems steep for a set in that bad of shape. -
Mechanical fan upgrade
pizzaman09 replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
I've recently replace my clutch with a new replacement and stock fan as well as put in a new thermo switch for the factory e fan, it works perfectly. Good cooling, even while idling for a long time on a hot day. -
Thoughts on upgrading to this auxiliary fan...
I'd plug each into a 12 volt source and see which pushes more air. -
Clutch not fully disengaging.
pizzaman09 replied to Dickinson County Comanche's topic in MJ Tech: Modification and Repairs
I just did the internal slave to external slave conversion in my Comanche, the external is undoubtedly heavier, however it is not very heavy. Very heavy hydraulic clutches I've been around included an 06 Ford Mustang V6 and any Subaru WRX. -
At idle RPM drop and feels like its about to stall
pizzaman09 replied to tdtony's topic in MJ Tech: Modification and Repairs
I'd also consider the condition of your O2 sensor. My truck did similar things and it was swapping out my Bosch O2 sensor for an NKT that fixed it. -
Transfer Case Skid Plate
pizzaman09 replied to Drahcir495's topic in MJ Tech: Modification and Repairs
Pics. There are 2 studs with nuts centered under the trans cross member. There is a stud and nut on the driver's side frame and a threaded hole with bolt on the driver's side frame. -
I had no idea that was a skid plate! I just assumed that was an extra and very odd support brace on mine. If you need I can take pictures of the one on my truck. In other news, apparently I have a transfer case skid plate. 🙂 -
Adding supplemental electric fan?
pizzaman09 replied to JZLAJeep's topic in MJ Tech: Modification and Repairs
The Comanches with AC has the electric fan as well. My truck has dealer installed AC which added the thermal switch and relay for the electric fan. I recently changed my switch and the fan now works perfectly. On a hot day my truck at idle will creep up above the 195 thermostat to 210 or so, particularly at idle. Mine is a 1990 Renix truck. Should be easy enough to do, there are after market temp sensing kits, or you can wire it to a switch. -
'87 Dana 30 C.A.D. delete
pizzaman09 replied to Eagle_SX4's topic in MJ Tech: Modification and Repairs
Cool stuff!
