Warren Mohler
Everything posted by Warren Mohler
  1. you will need to cover but the spray should get evenly to front of dash pad and into pretty tight areas
  2. remove defrost vents and A pillars, glove box, lower dash and should be able to spray I used SEM Color Coat, very good stuff
  3. No, do this BEFORE removing trans, any movement would indicate thrust bearing wear
  4. Have someone work the clutch while running and watch harmonic balancer to see if it moves forward
  5. coolwinds57 did a write up about renewing wipers including bushings not long ago
  6. https://www.ebay.com/usr/airparts8775428192?_trksid=p2047675.l2559 Ebay item# 182746202769 Sorry it took so long to find this
  7. 1999 XJ visors in 89 MJ
  8. Neg. values are a problem if old sensors did not read the same, I would swap the old back in to start.I have had injector o-rings leak and it's hard to see running,sometimes aiming a timing light at inj. spray may show trouble-large droplets, stepper motor MUST be working as ECU needs to see closed throttle or it will do all kind of bad stuff
  9. I have E-mailed Coverlay and Dashskins, both make covers for all the popular trucks Dashskins returned email saying XJ and MJ products were not on their radar at the moment.I have seen the covers and look a lot better than carpet. I would encourage CC members to contact these companies to let them know that there is interest in such a product for our trucks
  10. rear speaker should be one on both sides,just hooked mine up last summer
  11. Yes, not a whole lot there, its been picked pretty good.What are you looking for ?I may be able to save you a trip
  12. Sitting in JY-2.8-auto-4x4-AMC 20 rear-very botched lift-most everything of interior spray painted black-sitting in the mud in York Co. Pa. long bed in fair shape wheel wells cut out-not much left
  13. Very nice, wonder what real mileage is
  14. Is he looking for the spacer or "thimble" for end of rod?
  15. I thought it should be better, was disappointed don't have access to a scan tool right now. want to get REM when I collect enough change
  16. Just checked mine last week 12MPG average thats after 20 miles 10 city 10 hwy.
  17. run it I always put a dab of form a gasket there anyway
  18. It has been a while since I put one on, if I remember right the lower bolt has a shoulder that may position starter to ring gear. If new flex plate does not fix problem try to pry starter away from flex plate and tighten, a few thousands will make a big difference
  19. I will assume you used the proper starter bolts. Can't imagine what could be wrong that you would not be able to see, I have replaced a lot of flex plates due to cracks even had one that the entire center was broken and still started without such noise just sound bad running. I would put a dial indicator on and see how far it's out before spending too much $
  20. Warren Mohler
    Beer
    I like AB Natural Lite, cold,crisp, consistent, cheap
  21. Are the dowels engine to trans in place?
