JMO413
    4
Everything posted by JMO413
  1. See the first post. MTS sells the complete sender with pump.
  2. Decided it was time to change the fluid in my new to me differentials today. They came from a junk yard so they were drained when I got them. So I didn't get to see the fluid that came out. They have both been in for a little while now so it was time. I also needed to install the freshly painted new front cover. Gotta love Amazon. New soccer cover with bolts and rtv $20 to my door. Primed Painted and looking good. Bolts got a coat of black. Got everything painted last weekend so it had plenty of time to dry. The original in black just wasn't going to do. And thanks to this picture I can see I really need to paint my sway bar. Looks so much better. Changed the rear also note the covers match. Also installed some new lights for backing up in the boonies. They are definitely bright! They light up the pitch black garage quite well. The view out of the rear window. Then it was washer pump time. The old one just didn't have much pressure. The new one actually sprays the whole windshield along with the roof and both sides of the truck. Not bad for $6 from Rock Auto. Gave the washer jug a good scrubbing while I had it it to change the pump. Then these had to go on. Special thanks to schardein for these! Before Very small item but they just complete the interior to me. Off to pick up the 5 year old. I'm guessing he won't notice the new chrome. LOL
  3. My dream ride! Jeep Track Hawk. What I can afford and will probably be my next purchase of I don't but another MJ. SRT-8 Grand Cherokee.
  4. Very nice truck you found there!
  5. Well I've had this in for about a year and am overall pleased. Overall it works and the gauge sender is just a little weird. The first 1/2 half drops quick and the second half drops slower. The last 1/4 tank send like 1/3 to 1/2 the tank. It acts very similar to my 2005 WK's gauge. This is where it was when I got fuel yesterday. It took 14.6 gallons to fill it.
  6. Looks like the short side of a Dana 30 to me. I believe they are pretty interchangeable through the years, U-joint side being the difference.
  7. With that for a reading I'm fairly sure you don't need to check for spark beacuse there will be none. AC voltage should be .5 volts. http://cruiser54.com/?p=50
  8. Did you adjust the TPS correctly when you installed it? http://cruiser54.com/?p=54 I would read through his whole site. Make sure 1-5 are done.
  9. JMO413
    1J7FJ36S7ML542733
    Build Date 10/23/90 Body Model JL62 *C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT -Y6 135 Zone 35-Washington 1AA U.S. Dealer Retail 3V3 Customer Preferred Discount ADL Skid Plate Group ALN Body Color Bumper Group APA Monotone Paint ARL 300 Premium Group BAF 130 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3G STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black rear Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PG5 Hunter Green Metallic QG5 Hunter Green Metallic Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBB Full Size Spare Tire TBM Tire Carrier Winch TMW All Terrain Tires TZH Michelin Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z67 Left Front Spring Group XVI Z86 Right Front Spring Group XV
  10. Why didn't they show the $8,000 in cash in the glove box? LOL
  11. Welcome to the club and the addiction. Nice truck you've got there.
  12. JMO413
    Planning a project
    It's crazy what a build actually costs. I would say it's well worth it's while. In the end doing it once and right is way cheaper. Planning is always cheaper.
  13. JMO413
    Wasps....ugh
    I agree on the just kill em!
  14. The OEM number crosses to two different numbers. CA8664 or CA8721. CA8664 shows to be 52.31" in length. CA8721 shows to be 25.46" in length.
  15. Year? Engine? You should fill out your signature.
  16. I am very happy with my Thrush fully welded.
  17. Build Date 6/20/89 Body Model JM62 *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 4AF 5AM Largo Tracking 5KN Metro Cars of Detroit ADL Skid Plate Group ALN Body Color Bumper Group APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3C STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PQ9 DRK BALTIC BLUE M CC PRIMARY PAINT - HQ9 QQ9 DK BALTIC BLUE MCC SECONDARY PAINT - HQ9 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAE MUD && SNOW TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TMW All Terrain Tires WJM 15X7.0 Chrome Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YCD Outside Lease 93017 YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV
  18. Build Date 8/13/90 Body Model TL61 *D4 TRIM STYLE D4 - VINYL BENCH SEAT -Y6 DARK SAND 151 Zone 51-Chicago 1AA U.S. Dealer Retail 3VQ Customer Preferred Discount 5KK First American Title Insurance CO. ALA ALK APA Monotone Paint BAP 75 Amp Alternator BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PG5 Hunter Green Metallic QG5 Hunter Green Metallic Clear Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZA Goodyear Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z57 Left Front Spring Group Vii Z77 Right Front Spring Group VII
  19. 4.8/5.3/6.0 all the same block configuration. Search LS swap.
  20. Nice looking truck you found there. Welcome to the club and addiction.
  21. That is what the parts catalog shows for that VIN. You can't really do it wrong.
  22. Congratulations! That is an absolutely beautiful MJ.
