8
Everything posted by 89 MJ
Another Starting issue thread, oh boy!
89 MJ replied to NC Tom's topic in MJ Tech: Modification and Repairs
How do ALL of the battery cable connections look? At the battery, at the starter, and at the end of the ground. This does not seem like an alternator issue at all. It looks at the battery cables, then possibly the starter. -
The next show up that way that I am considering going to is the 2028 AMC Homecoming show in Kenosha
I really like that pedal idea. I know @Gjeep has gone from pedal to handbrake in at least one of his MJs. Maybe he'd be able to shed some light on going the opposite way too? Who knows, you might be as lucky as being able to swap in the front MJ parking brake cable.
I'd do it as proof of concept if nothing else. Take the free seat, get it mounted and all of the kinks worked out, then start watching for a bench with headrests (90-92 had headrests). You will need to use XJ seat brackets on the floor. The other thing you're giving up, in my opinion, is a ton of comfort up front. I can't remember if your MJ has a bench or buckets, but in case it has buckets, I think it is worth noting that being 3 wide in an MJ is not exactly my definition of fun.
Now you're making me feel old...
Wow, I can't believe its been 5 years already. I still remember you making the original post.
I think you’re going to have to create a thread on this and tell us more
$650 Longbed in Denver, CO
89 MJ replied to aris_garage_builds's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Well now that you've turned your MJ into more of a street truck, it wouldn't be such a bad thing to have a truck you can play with in the dirt or drive in the winter if needed. You kept all of your suspension parts, right? That chrome front end would look good on the Chief -
I think you're on the right track. The starter side of the battery cable would be the first thing I would check.
That will be the tricky part. It will be slow going, but worth doing, in my opinion.
Based on what I'm seeing, that rust that the doors have is from the outside. The paint cracked from shrinking most likely or the seam sealer cracked (I can't remember if the factory used seam sealer there or not) and it let moisture in. That rust does not look like it originated from inside the door from moisture getting in there. In any case, what you'll have to do its undo the fold where the outer skin wraps around the inner skin. This will give you wiggle room by separating the inner and outer skins. Then you will be able to evaluate further. If you do this, make sure not to fold one little section all the way over. Slowly work it bit by bit in the opposite way that the factory would have done it. This is exactly what was done on my MJ's doors and tailgate. 7 years later being a daily driver in the rain and dry in fairly humid WI. Rarely does it spend the night inside during these months. The truck is parked for the winters, but it is not climate controlled. There are no signs of rust or swelling. My Dad, who restores cars for a living does this and has never had a problem on any of his customer cars. He recently saw his old 70 GTO that he restored in high school (car was painted in 91) and it was still completely fine. This is the right way to fix it. I would agree that those doors are likely the best ones that you will be able to find around you easily. I will also say that you will be time ahead to drive farther south and find nicer doors as opposed to cutting the bottom off of those doors. You'd probably have the better part of a day in each door for cutting the bottom off, making the patch fit right, and then rewelding it with minimal warping (and I say minimal because on a panel as thin and flat as MJ/XJ doors, it'll be hard to keep them from warping, especially if you're welding in one of the larger flat spots).
That is a heck of a lot cheaper than you could restore one for. It is a bummer that they do not have titles, but if a guy had a really rusty Jeep with a good engine, transmission, and axles, this would be the way to go. I also like the idea of putting a 2.5L in one.
That is nothing that will require patch panels. I would open that seam up, sand blast or grind it down to bare metal, prime it, and then fold it back over.
I’d replace the whole door. It would be hard to weld that panel on without warping.
Penetrating oil, let it sit for a day or so, penetrating oil again, repeat over a few days, then hopefully it’ll come off.
I think that depends on the height that you would want to do the fence.
I’m glad I’m not the only one who refers to metric sizes that way
I was just thinking about this the other day. My parents have a JKU Sahara with 3.21 gears and the 5 speed auto transmission. Even when it was on stock tires, it was a dog. I recently drove a 2 door JL with the 3.45 gears and the 8 speed and I have to say, I am very impressed. That 8 speed makes up for the lack of torque very well. That said, the 3.45 gears and the lighter weight Jeep are also important factors here.
I would agree, concrete to set the posts.
The part that mounts the fender flare has been cut off. There looks to be a lot of other usable parts on that truck still though!
May 2026 - A Member Since (almost) The Beginning @COMJNUT's 91 Build Thread- Year/Model - 1991 Base Drivetrain- D30 front with the Posi-lok cable Stock 4.0L with 99' intake and power steering pump M.O.R.E motor mounts Ax-15 NP231 with the 4:1 Tera-low kit and slip yoke eliminator 98' ZJ D44HD rear Cooling- Napa 3 core copper radiator Stock thermostat, housing, waterpump Aftermarket aux fan with on demand switch in the dash Electrical/Ignition- Stock wiring 7-pin trailer plug Suspension/Steering- Tomken 6" front coils Tomken front upper and lower control arms 98' ZJ Drag link & tie rod Alcan rear springs with XJ shackles Interior- Bluetooth stereo Pioneer 6.5" front, 6x9" rear speakers XJ 2 door seats Tuffy CJ center console Cobra 29 LTD CB radio Brakes- Stock system, missing linkage to axle, chose to adapt a spring to the proportioning valve. Lighting- Rampage H4 MSR headlights Clear turn front turn signal lenses Stock rear taillights Stock dome lights Exterior- Rust is starting on a few of the body panels, will have to mitigate that soon. Trying to keep it dry as possible in the meantime. Wheel & Tires- Wrangler Moab wheels 265/75R16 (~32") Goodyear Wrangler MTR Misc- I have found that even though it was a base model with a radio delete, all of the wiring was still there for the more equipped models. Custom aluminum diamond-plate topper Best MJ story- I don't really have a best MJ story. Every time I take it out, I notice rubbernecking by a lot of the folks I pass by. It's been called a Hummer in a parade, a custom-built Cherokee at a show. I just enjoy every time I drive it. CC is Awesome! Why? It is a great website with ample amounts of information about our unique vehicles. It is very cool to see so many members on this forum from when it was so young. Congratulations Scott!
Here we go again! A 1986 Eagle
89 MJ replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Because Eagle Lol! They’re excellent cars when they behave -
Sounds like you found a good one. And an Eagle would be a great addition
