8
Everything posted by 89 MJ
Key Parts inner rockers are available
89 MJ replied to Pete M's topic in MJ Tech: Modification and Repairs
Same here, but that's not why I am commenting. I just wanted to say that it makes me so happy that you paint everything before putting it back together to prevent rust in the future. You see a lot of people that don't do that (more so on Facebook than on here) and I love to see people doing the job the right way. -
I’m with everyone else. Add them.
To LS or Stroker... That is the question
89 MJ replied to howeitsdone's topic in MJ Tech: Modification and Repairs
Here is another point with the LS. This truck is your overlander, yes? If you ever decided to take the truck cross-country and had an engine issue, you have OBDII. You don’t have that with Renix. You can also get dang near anything you need for an LS in an auto parts store. I haven’t had the same luck with my 4.0s. But the 4.0 will make more low end torque, which is good for off roading. -
VIN location on back half?
89 MJ replied to GonzoTheGreat's topic in MJ Tech: Modification and Repairs
@Pete M may know. He also has an MJ trailer. You may have to get an assigned VIN for it, being that it is now a trailer. -
You can get the stock LS engine computer tuned for about $300. That saves a lot of money too. The WK2 with a V8 is a more rev happy engine and has more gears in the transmission. Not exactly an apples-to-apples comparison. -
I think it depends. If you don’t plan on having the truck forever, I think an LS will hurt the value long-term, so I’d do a stroker. If it’s a forever truck, LS swap that puppy and get more power and parts availability. -
Coolant unexplained loss.
89 MJ replied to Classy Comanche's topic in MJ Tech: Modification and Repairs
If it’s dry, I’d do a compression test. -
89 MJ replied to neohic's topic in Member Projects: Other Cool Stuff
I did not know that about these CJs. You may want to check out the Facebook page “BC Vintage Jeeps”. They are out of Delta, CO and sell lots of CJs and parts. And they deliver. -
October 2022 @Comanche SS's Comanche Fun-Runner Build Thread- Year/Model - 1989 Jeep Comanche Sport 4x4 Manual, Came with a D30/D44 and AX15, bought it from the original owner in Whittier, CA...When I got home I found the original window sticker and every service record since the day he bought it...all from the same dealership in Whitter, CA. Drivetrain- Currently the truck has a Shelby supercharged 5.3 Liter LS based engine, behind that is a 1999+ 2WD 4L80E with some internal upgrades Cooling- 24''x19''x3'' Northern Aluminum Radiator, and a Derale Trans Cooler Electrical/Ignition- The chassis wiring is all stock and intact, the engine and trans are running off a Holley Terminator X-MAX Suspension/Steering- The front suspension is Equal length and centermounted I beams from Ford, the steering is double swingset equal length all custom made. Interior- All stock...Bench seat and all. Brakes- Front brakes are Ford 3/4 Ton discs and rotors, WJ master and booster, rear brakes stock for now (dana 44) Lighting- Amazon special LED lights all around Exterior- All Hanneman Fiberglass Fenders and bedsides, rattle can driveway paint job with Rustoleum Smoke gray Wheel & Tires- Pro Comp 15x8'' rims, 33'' General Grabber X3's Misc- Tons of Misc. on a build like this... Tons of fabrication and engineering into it too. Best MJ story- The build hasn't been on the road much in the last few years, but it does not fail to break necks and get the normal car guy walking up to it in parking lots scratching there heads. CC is Awesome! Why? A great community for the regular Comanche lovers, my build has progressed further from a Comanche than most, but when I have stock jeeps (of which I have a few others) this site is a great resource for information and troubleshooting. I also have met many great friends, families, and peers from this site. Congrats, @Comanche SS! I'm looking forward to seeing pictures of it in action.
Personally, I would get a complete body (hood, fenders, tub, grille) that are rust free and do a complete body swap. This way, the body will have patina so you can still use it and not worry about scratches or dents and it will all match. I think if you make it shiny, you won't want to drive it. -
I’d say so. I turned down 15k for mine in the spring.
I’ll bet they’ll be stamping full bedsides within a year.
TheCodeMonk's 91 MJ - Rocky's slow build
89 MJ replied to thecodemonk's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I was just wondering about this build the other day. Thanks for the update! -
I've been doing some research on these cars more lately. This is a very strangely optioned Eagle. It is a base model car, so it has crank windows, manual locks, manual cloth seats. The strange part is the number of options that the car has that I haven't seen on a lot of higher trim cars. Some of these options include cruise control, or the 2.73 gears (standard was 2.35 ), the rear cargo cover, AC, tilt column, and, most unusual, the rear wiper. I don't think that I've seen another rear wiper car in person ever. But right now, I am thinking about giving this thing a mild build so it will be good to come to school with me next year.
Poor guy. Good luck
I’d be a little worried about that old oil starting to break down some.
86 2.5l 2wd restoration/work truck
89 MJ replied to strictlyxjs's topic in Member Projects: Your Comanches
That’s an impressive number. I ran my MJ (4.0, 5 speed, 4.10s on 31s) across WI and got 20 mpg running 75 most of the way. They are surprisingly economical on the highway. -
I would try Bleche-White tire cleaner. It cleans up old, yellowed whitewalls very well.
I'm running the same conventional 10W30 Valvoline in my Eagle, garden tractor fleet that I run in the Comanche, and when I change the oil in the '40, its getting the same stuff. The Eagle, Comanche, and '40 get/will get zinc additive when I change the oil too. 10W30 seemed to be the oil to go with at at the time. IIRC, that's what we run in all of the old cars at work too.
Quite the collection!
Nice! If you click the "My Projects" link in my sig, I have build threads for my garden tractor collection too.
No sir, it was loaded with a forklift as it had no wheels and tires on it at the time. That was the only time I had that in the back of the truck. I would’ve used a trailer, but I didn’t have time to go home and get it. I know @jpnjake hauls garden tractors with his truck too. Not sure how he loads them though.
