13
Interior colors/paint
eaglescout526 replied to eaglescout526's topic in MJ Tech: DIY Projects and Write-Ups
I updated this thread to show the latest match for the headlight bezels with the darker silver accent trim. -
Chunk, A 1984 XJ
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Good call!! I was gonna do a simple DIY thread if it’s own. -
I feel like you could’ve gone as far as making a Monty python and the holy grail reference here.
The all high and mighty Pete.
Chunk, A 1984 XJ
Ive been plugging away at the bumper/hitch/spare tire carrier install. Its a pain because its three things at once haha but its nice as its all in one shot ordeal. Bumper is on as is all the hitch stuff, now its just to get the carrier pieces on. As I painted the bumper and waited for it to dry and cure I decided to address a couple things. One was the annoyance of the front header. All the screws were broken off. I remembered someones post about solving the issue once and for all and I did such today. Love the results! Drivers side is done too. Then I decided that if I am gonna go this far, I am gonna address the aging headlamp bezels. And I aim to keep the origianls....or at least what is still good. The drivers side is toast, its done, I broke it, it already had a piece missing but the pass side is still useable. So I recall the issue of finding the right paint color for the darker shade of grey for the bezels. Well I remembered I had a can of mopar touch up that was a bit dark and probably the right color and sure enough! It was a dead on match that I am happy with As you can see the condition of the drivers side is on the left and the pass is on the right. The drivers side got painted as a test for this color and on the right is still not painted but enough is left to check for a match. Belive it or not with that age, I see a perfect match! Now I need to find a drivers side bezel, I think I have one laying around. Here is the color code and part number of the paint: -
Interior plastic paint… worth it?
eaglescout526 replied to Elwiscon's topic in MJ Tech: Modification and Repairs
Yes. I even did a whole thread on the colors that match the absolute closest or exact to our interior. Even SEM interior paint does damn well on exterior pieces as well. -
Chunk, A 1984 XJ
By far the best sending unit I have ever seen. Besides the NOS unit in LR haha. SU is original too! Tank is clean inside too obviously lol. The outside is much better on the bottom than the original tank but its not leaking which is a big plus to me. The tank did have a dent in it, I hammered it out and threw it all back together. Used the sending unit I put together to syphon the gas out of the old tank and into this one. This should go pretty smooth. Currently working on the bumper area now. Got its issue sorted and should have a spare tire carrier on soon. -
Washer and dryer panels. Thicker than normal sheet metal and are already coated.
Chunk, A 1984 XJ
As always cactuscomanche got me once again! Got the gas tank from the 86 XJW with sending unit. Some rust on the bottom but looks mostly surface and is the same capacity. I will repair the original and put it back in one day or keep it out and put the original sending unit with it so both never get lost. Also got a rear OEM bumper. Needs a slight fixin but other than that it should suit me well vs the pushed in and dented bumper I had. This one is pushed in at the pass end cap but the spare tire carrier might rectify that. -
September 2023 - JZLAJeep's 89 Field Find
eaglescout526 replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Glad you guys were able to take some time to meet up too! Was a fun time chatting with you guys and getting the parts y’all needed. congrats! -
Chunk, A 1984 XJ
Rust hole. I’ve known about the leak prior to cleaning the tank but it wasn’t bad enough for me to get a new tank then. -
Chunk, A 1984 XJ
Aaaaaaand gas tank has a hole. I have know it to have one for a bit now but the hole got worse some how despite not cleaning up the bottom of the tank because of that issue. Now I’m going to locate a tank or try to repair. -
Chunk, A 1984 XJ
Hoooooo got lots done this evening. Fuel filter and bracket, mounted. EFI sending unit, installed And my suspicion was correct about the gas tank, it is a 20 gallon And the plastic skid is AMC made, I expected such but it was neat to see the AMC flag Guess I don't have a pic but I started installing the NOS hitch set up, got most done. I still need a OEM bumper to do more. I also got the trailer plug installed and in a body hole that took me a bit to find. Due to the damage the drivers side rear lower(thankfully it is covered by the bumper end caps) made it a challenge to install the harness that has the body plug. Spent 15 min fighting that and straightening the hole to get it pushed in to stay in place. Also found out there was damn near a 1lb of dirt in the fender. don't ask me why or how as I don't know either but thats all out via the two body plugs. Next is to put the gas tank back in, get the hoses attached and then play with the trailer harness and piggy back off the tail lamp connector as that is how it was done by the factory if you were fortunate enough to have that harness. Easy for me to make as the pack con connectors are very serviceable. -
Chunk, A 1984 XJ
Fuel lines and vapor line have been swapped into place. I removed the front drive shaft for future removal of trans/t-case. Everything is falling into place. I need to remove the sending unit and put the new EFI unit in the tank. Once the fuel system is set up, the wiring for the ECU with system sentry will go into place then the intake manifold and then vac lines. Once that’s all set the trans will be dropped to swap bell housings and transfer case. -
Another valley MJ. Sweet!
Tailgate "jeep" size and font?
eaglescout526 replied to TieDyeJK8's topic in MJ Tech: Modification and Repairs
Font is helvetica. -
Main power distribution wire splices
eaglescout526 replied to xxmetal's topic in MJ Tech: Modification and Repairs
No, there a wire for a work light under the hood. From time to time we get folks who don't know what the wire is for and plugs it into the spade terminal that is exposed on the coil and it will keep the coil on. Now if you suspect it from the dash side, you will want to check the actual ignition switch itself and make sure its not melted. -
Make sure you don’t have the hood lamp plug plugged into the coil if your MJ isn’t equipped with the hood lamp. the factory did use duct tape on their splices…..and as are the crimps. It’s AMC, you have to think cheap when working on these Jeeps.
