eaglescout526
Administrators
    13
  1. You can't. At one point it was probably an old AMC code or a recycled Chrysler that no longer has its original meaning to our trucks. I would say transmission cooler but there should be a code for that somewhere.
  2. Has anyone tried to do anything with steel cable? I want to try to reproduce the Renix cruise control servo cable clips. But this would mean I need to either figure out how to dismantle the original cables or make new ones. And making new ones would probably be a better idea than trying to remove those crimps on the ends.
  3. What 89 said. But the SoCal you want to mention is SoCalmanche. Not sure who that other one is or if they are even on here much.
  4. Yeah let me stop eating my pizza. Lol *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED Damn. Bare bones Build date 11/11/85 Body code TL62
  5. I guess swapping in a 4.2L is an option but you might as well just leave the 4.0L and drop in 4.2L guts to make a stroker. I just saw its an 86, the fact the PO dropped in the 4.2L is pretty good. Probably was literally plug and play with the 2.8L harness and set up
  6. Noted. Ill have to try this on my drives to and from work. I take it the inside of the cab is completely silent with everything off.
  7. K needs to be changed to a J *X4 -SA Charcoal 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black NAA ESA W/CATALYST (EXC CALIF SYSTEM) PQ9 QQ9 RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 12/10/87 Body code TM61
  8. *X1 -Y1 APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DDQ Transmission - 5-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 TBG SPARE TIRE - COMPACT Build date 8/27/86 Body code JL62
  9. I updated what I have replaced as I remembered I had a new drive shaft built a couple years ago. I have thought about a bent wheel but the techs would've picked that up the couple times they have replaced my tires with the road force machine. Now when you say shift sides to hear for noise or vibes, do you mean with the windows down and everything off during a turn?
  10. Alright, I know vibes usually come up probably once every few months and I myself am tired of hunting them down. I am aiming to create a master list of where the vibrations are/can appear and when. So far I have replaced EVERY rubber bushing from the steering linkage to the gutting XJ shackles for the bushings for the MJ shackles. And I did have a new drive shaft built. I can mostly feel the vibrations in the front now, not so much the rear as I suspect that's the passenger side leaf pack being a bit aged. Common things to check: Control arms Steering parts Leaf spring bushings Shackle bushings Coil spring isolators Transmission mount Motor mounts Wheel Balance Leaf packs Coil springs Drive shafts and their U-joints Honestly I can not think of any other places. The only places that keep popping into mind(for my vibrations) are the front wheel bearings for possible warpage/bent, coil springs and rear leaf. I have replaced a leaf pack due to one leaf being broken in the pack and noticed a better ride and support. Coils are up next on my to do list and quite possibly replace the other leaf pack. But I would like to hear from you guys on what you repaired and noticed a difference in ride and less vibrations.
  11. Yeah we need to meet up. Summer was pretty killer even with AC.
  12. I have been watching his channel for a while cause he gets some neat cars aside from his micro car addiction. But lately he has had something I have been very curious to see show up on his channel but hasnt. His latest video shows what is an MJ on his lot and my curiosity has been piqued about it for quite some time. He recently had a willy's wagon in his shop.
  13. Interested in mine for parts? I only bought them cause I couldn't find another M 750 lens for chunk until a week after I bought the set. The retainers are in fine shape and just need a slight de-rust.
  14. Damn. That took a while. I know the housings for mine are kinda gone and the reflectors can be saved. I tried using a parts sears fog lamp and despite the housing being very very close, the screw holes for the retainer do not line up.
  15. Welcome to my world. Trying to do the same. Rusted Out Lights.
  16. No there isn’t a difference in size. Be careful as they are prone to snapping at the tube connection. Did you check the condition of the T connection for your wipers? Mine failed and caused very very weak spray. Almost no spray really.
  17. 82200663 is the number. It’s not that it doesn’t seem to exist it’s more of the demand for the part. If the demand wasn’t there, there wasn’t a need to make a lot.
  18. ^X5. The damnedest thing is they made the same nozzle until 2001 yet there arent any left. But the cowl panel(still produced today) and the screen(vintage) are still around.
  19. Been there done that. Ive scoured every accessory part from 82200001-82201000. Even looked at the number listed and theres none out there.
  20. *X8 Cloth Low-Back Bucket Seats -SA Charcoal 167 Zone 67-Charlotte 1AA U.S. Dealer Retail 4EA Sold Vehicle 5KN Metro Cars of Detroit ADA Light Group ADL Skid Plate Group AHL Heavy Duty Insulation Group ALN Body Color Bumper Group APA Monotone Paint ARL BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUF Full Length Floor Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHN Command-Trac Part Time 4WD System DHS Floor Mount Automatic Shift Lever DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning HGD Deluxe Insulation Group JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KKE LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon NHM Speed Control PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJM 15X7.0 Chrome Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z67 Left Front Spring Group XVI Z86 Right Front Spring Group XV Build date 11/13/89 Body code JL62
  21. Mine is also one of the aftermarket pieces. I wish it was the OEM one. Would look sooo much better.
  22. Oh damn. 5 months ago. Did you solve your issue?
  23. Lol no excuses, just ran out of time The brush guard is sitting happily in the dry garage against a tower of take of rims and tires at their house. I am very excited to get that guard down here come May and work on it. I often daydream about having that guard installed.
  24. Depends. What are your goals with the MJ are. Do you want to keep everything era correct and build it how you wouldve ordered it from a dealer or do you want to build it how you want?
