youngfred
Everything posted by youngfred
  1. ... Looking for a Drivers-Side Mirror. In good condition. Folding Pogo-Stick Black With Rubber Door-Plug on the adjuster wires No Floppy-Glass(already got-one) ~ Photos ? Thanks youngfred
  2. ... Trying to stay busy, during these times. I just finished removing, all-of-the-lint, out of my belly-button, as I wondered: Why do Hospitals, Medical Centers, and Doctor's Offices - all have: Door Knobs Pull Handles on all of their doors ??? youngfred
  3. ... Like these : youngfred
  4. ... What, me worry??? youngfred
  5. ... Trying to set up the e-brake cables after this installation. Having trouble adjusting, using the original e-brake cables. Tried some XJ e-brake cables from teraflex but they did not work. youngfred
  6. ... Harbor Freight youngfred
  7. ... Saw a White Pioneer - PARKED RIGHT HERE !!! At the corner of Main St. and First St., in Cerrillos, New Mexico. In front of - The Black Bird Saloon. Went around the block - came back and - POOF - it was gone. youngfred
  8. ... I will jumper the Delay Module Connectors to see if LO returns. Thanks youngfred
  9. ... I did the same. I ran the ground wire from the lid screw to the T30 Bolt as well. I will pull the added Ground Wire and see if the LO feature returns. Thanks youngfred
  10. ... The original black ground wire on the lid connector is soldered/pressed-on, to the lid. I just added a ground wire to one of the 5 lid screws. youngfred
  11. ... Just finished the upgrade and maintenance with the added ground wire, new bushings and MolyB grease. Cleaned the three Contacts and the circular contact area. The Delay and the Fast speed work fine. I don't have a Slow Speed now??? What gives? youngfred
  12. ... Thanks youngfred
  13. ... The one that I have is like the bottom one in the photo above. I am interested in the top one. PM me with the details. Thanks youngfred
  14. ... Looking for - Clean Dash - OEM Switch Housing Bezel for Fog Lamps on Left-Side. In good shape. youngfred
  15. ... Pulled my Good Cigar Lighter : Had a scratched Spare, to work with and to test. Fitted a Rocker-Style USB/Aux Switch(possible kill-switch) ( : With Protection : Now, to wire it in and see how it does : youngfred
  16. ... Advance Auto Special Ordered my Monroe - 58497's a while back. youngfred
  17. ... My last post - 'Hard-Cranking Window Regulators', I wanted to know what was the best grease to use on the manual regulators, which had dried up. I started with the Search : 'Regulator Grease' -132 pages all kinds of : > regulators > grease. When I Searched on - 'Window Regulator Grease' - 344 pages all kinds of : > window > regulator > grease ~ I composed a detailed question and received more answers to my question than after reading and reading from the 132 or the 344 pages. youngfred
  18. ... Going in to change the outside door weatherstripping window-sweeps, on both doors. They are both, old and cracked. Both window-regulators are hard to crank and dry with both not going down, all-of-the-way (before the crank gives). I am planning to grease both, while I have each side apart. I would like to grease them, only-once though. What is the best grease to use on the regulators and the cranks, that will not be too affected, by heat/cold, moisture, dirt(and-time) ? Thanks, youngfred
  19. ... Quadratec has this one. Each Switch Pod would cover the crank-hole. https://www.quadratec.com/products/73003_801.htm youngfred
  20. ... I didn't want to change out door panels(left over-manual window crank hole). My door panels are in great shape. youngfred
  21. ... Thinking about adding Electric Door Locks. Will these XJ rear-door handle trim with switch, fit the MJ doors? The Actuators are available but I do not know about the rest of the internal hardware. Has anybody added Electric door locks using these? youngfred
  22. ... Just the Live, lately. The Red Devils King King Anders Osborne Live at Tipitina's Gary Clark Jr. Gary Clark Jr. Live Van Morrison It's Too Late To Stop Now Muddy Waters Live at Mr. Kelly's The Boneshakers Put Some Booty On It - Vols. I and II Amos Lee Live from the Artist's Den Indigenous Live at Pachederm Tab Benoit Live : Swampland Jam John Mayer Where The Light Is - Live in LA Storyville Live at Antone's Jimmie Vaughan Trio Live at C-Boys (Feat, Mike Flanigin and Frosty Smith) youngfred
  23. ... Maybe, the Trafficator will come back. youngfred
  24. ... I am very interested. I was about to start gathering parts to get some cold air going, again. youngfred
