jdog
    2
Everything posted by jdog
  1. isn't that all comanches?
  2. cruiser has a mod to make it power all the time/ see link in signature
  3. Dunno why he would down grade but whatever. Guess that changes the plan for the ugly trucking?
  4. ?? little confused, thought you sold this?
  5. yep, had quite a few already, if it's Canadian sold it will have (CAN) at the end. We've still got 88 and 89 to do (majority of the registry) should get a few done tonight.
  6. glad to hear you got it fixed, yeah they are pretty common to go out
  7. in the turn signal socket itself( the thing the bulb goes into)
  8. jdog
    1J7FJ36L1KL514853
    Build Date: 2/8/89 Body: jm61 Selling Dealer: CLOVERLEAF CHRYSLER DODGE JEEP Decatur, AL APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKAS Carpets - Floor and Cargo Area CSRS Passenger Assist Handles CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMMS 3.07 Rear Axle Ratio DRJS Dana 35 Wide Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror JAAS Instrument Panel JBDS Instrument Panel Satin Silver Bezel JCAS 85 MPH Primary Speedometer JJAS Cigar Lighter JKBS KKES DESCRIPTION NOT AVAILABLE K2XS STRIPE/BADGE/MOLDING/COLOR K3CS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MBJS Black Powder Coated Front Bumper MB1S Black Front Bumper MFGS Body Color Headlamp Bezels MHAS Black Windshield Moldings MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMKS Lower Grille Surround-Painted Silver NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NF2S 18.5 Gallon Fuel Tank QQ9S DESCRIPTION NOT AVAILABLE SBAS Power Steering SCES Steering Wheel SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch WJDS 15X7.0 Styled Steel Wheels XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 161S Zone 61-Atlanta *X1 DESCRIPTION NOT AVAILABLE -SA Charcoal ADLA Skid Plate Group ALN Body Color Bumper Group BAYP 105 Amp Alternator BCYP 95 Amp Battery CBAP Straight Back Bench Seat DBBC All Manual Transmissions DDX 5-Speed HD Manual Transmission EAAC All Engines EAFC ERB 4.0L I6 MPI Engine GFDA Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors HAA Air Conditioning JAYA DO NOT USE - See JP, KA classes JGBP Digital Clock JHAA Var Intermittent Windshield Wipers MDA Front License Plate Bracket PQ9 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RABA AM/FM Radio RCDP 4 Speakers TAAC All Tires TAEA TBBA Full Size Spare Tire TMWA Tires XEEP Fuel Tank Skid Plate Shield XEFP Transfer Case Skid Plate Shield XEUP Front Suspension Skid Plate YEP Manuf Statement of Origin YGBA 1 Additional Gallons of Gas YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z66P Left Front Group XV Z85P Right Front Spring Group XIV 5AMA JF/3450 Vehicle Family 5KNA Metro Cars of Detroit
  9. The heater is a vacuum issue, check to make sure the lines are still connected under the hood and check the vacuum ball behind the front bumper. The transfer case could be that the linkage needs adjusted. That sucks about the frame.
  10. i'll have a open radiator out of mine soon(like in the next week) if you are interested. it works fine, just swapping so that i can have a coolant sensor. otherwise there less then a 100 $ to convert to open iirc.
  11. I agree with that one, i will be sitting in the drive thru awaiting food and truck will start to get hot. To install a fan and sensor is possible, just depends if you can find the a/c harness or if you just want to make one up.
  12. Correct, another symptom would be a sweet smell inside and /or fogging of windows
  13. Sounds like a lot of work coming up,
  14. The wires on the relay are fuse links for various items in the jeep. The relay itself is the starter relay. The radiator looks good.
  15. I second the heater control valve
  16. the wires are not there, they are a seperate a/c harness. you can make a harness, just be sure to put a relay and a fuse in it
  17. does the high beams turn off when you pull on the lever? if so i'd look at the high beam switch
  18. Build date: 5/27/87 Body: JL61 Selling Dealer: JASPER JEEP-DODGE-CHRY-PLYM, Jasper, GA *A6 -H9 APA Monotone Paint BCQ Maintenance Free Battery CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area DGW 4-Spd. Automatic transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GEC Front Left Side Sliding Window HAA Air Conditioning HCC JHA Var Intermittent Windshield Wipers JJA Cigar Lighter KD8 STRIPE/BADGE/MOLDING/DELETE LMA Halogen Headlamps MD8 Delete Front License Plate Bracket NAA Federal Emissions PXJ paint QXJ paint SBA Power Steering SUA Tilt Steering Column TBG Compact Spare Tire TBL Inside Mounted Spare Tire WMC 3LR
  19. Should be done today
  20. OH wow I should probably update lol, got the tank installed, and then I got called back to work. Will probably start working on this in the spring. Atm I'm building the motor that came out of this, and will be going into another ride soon.
  21. any shiney bits? I would drain and refill, (yes low trans fluid could cause a overheat issue as the trans cooler is in the radiator). i would also flush the lines. its worth a shot, when draining look to see if there is any metal flakes in the fluid or chunks. as stated before just drain and fill, the dipstick tube is a huge pain.
  22. when i swapped my ax in i got one for the year that the trans came out of.
  23. That was a good episode
  24. Quick Google search says no
