2
Everything posted by jdog
Hello, Welcome Build date: 9/13/91 Body: jl62 Selling Dealer: Autonation Chrysler Dodge Jeep Seattle, WA APAS Monotone Paint BAPS 75 Amp Alternator BCCS Battery BGAS Power Front Disc/Rear Drum Brakes CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMMS 3.07 Rear Axle Ratio DRJS Dana 35 Wide Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass HCDS JAZS JCAS 85 MPH Primary Speedometer KWRS STRIPE/BADGE/MOLDING/COLOR K3ZS STRIPE/BADGE/MOLDING/COLOR LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Rear Door Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF5S 23 Gallon Fuel Tank QS7S Dark Silver Metallic Clear Coat SBAS Power Steering SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 172S Zone 72-Portland *C1 -H9 ALAP CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission ERH 4.0L I6 Power Tech Engine GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZP Manual Remote Mirrors JHAP Var Intermittent Windshield Wipers JJAP Cigar Lighter KERP MBJP Black Bumper MDAP Front License Plate Bracket MHAP Black Windshield Moldings MMKP Lower Grille Surround-Painted Silver PS7 Dark Silver Metallic RAAC All Radio Equipped Vehicles RAFP AM/FM Cassette Radio RCDP 4 Speakers SCGP Steering Wheel TMWP Tires TZHP Michelin Brand Tires WJHP 15X7 Aluminum Wheels WLZC All Aluminum Wheels YEP Manuf Statement of Origin YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z65P Left Front Group XIV Z84P Right Front Spring Group XIII 2TCA Customer Preferred Package 2TC 25C Customer Preferred Package 25C 3VNA Customer Preferred Discount 4BJA Wheel Credit 4M1P Retail to Bid Diversion Tracking 4UAA SCA Tissue North America LLC
Crushed Dowpipe from Factory?
jdog replied to kryptronic's topic in MJ Tech: Modification and Repairs
both my renix had the crush -
Don't forget to disconnect the cps
https://www.thedrive.com/news/39150/meet-the-90s-dodge-caravan-off-road-minivan-that-almost-made-it-to-production?xid=fbshare
I thought the dash one was way harder
I was born in the 80s but my interests are the 50s-70s
here's a easy one http://www.americantorque.com/game/muscle-car/
don't forget they are probably torx if they haven't been changed out
85% I have no life outside of car shows
'88 Eliminator... Feb. 2009 - Oct. 2026
jdog replied to neohic's topic in Member Projects: Your Comanches
bump, is it home yet? -
I do have a issue with it being green, every time I hear it's going to be green all I can think of is the song big green tractor, but I change it to lil green pickup. You better come up with a good name for it lol
Those would work to install the hitch onto the xj Xj hitches don't mount to MJs, krustyballer makes a hitch for the mj if you look in the vendor section he has them there.
As am I
No fender cutting?
any lift?
yeah i went poly for the suspension bushings, done the engine mounts a couple times, cam sensor a couple. but it keeps going and going. almost 200k on it. still waiting on a build thread
no build thread, is it in the registy? I have a neon can't seem to kill it, its a good lil vehicle for what it was, cheap.
Oh no, not another r134a conversion topic!
jdog replied to Comunchy's topic in MJ Tech: Modification and Repairs
i believe harbor freight sells some that will work. don't know about longevity -
ah yeah then that will be good, follow minuits advice and you should be good to go. -
Sorry guys I'm on a 80s kick https://youtu.be/dQw4w9WgXcQ
Iirc Mercedes had it catch fire on their test track and didn't want to convert because of it. If you look on the labels for the new ones they have the flammable symbol. Onto the original question, what is the reason to switch? If it's cause the a/c isn't cold you will need to verify it's not leaking anywhere before you start my else. Also if the lines have been off longer then a couple hours replace the dryer.
