2
Everything posted by jdog
nope still invalid, last 8 pulls up as xj,
Period correct custom 1989 Comanche
jdog replied to Dickinson County Comanche's topic in Member Projects: Your Comanches
The thermostat actually works opposite, then what your thinking, a 160 degree will open when the engine reaches 160 and thats it, once its 161 and above that thing will not close again, once its open the engine will reach its operating temp which is 200/210 depending on how good the system is. it doesn't keep the motor at 160. if you have an overheating issue while stopped you either have a bad clutch fan or a bad radiator. Please, when you fix the issue install the correct thermostat your engine and fuel mileage will thank you -
Key-in chime circuit(solved)
jdog replied to eaglescout526's topic in MJ Tech: Modification and Repairs
yeah, didn't feel like turning my display sideways
all vins added to registry
Good looking truck Build date: 10/19/87 body: TL61 *X3-DESCRIPTION NOT AVAILABLE -Q8-DESCRIPTION NOT AVAILABLE AGC- APA-Monotone Paint CBA-Straight Back Bench Seat CGX-RR Head Restraints Outboard Seating DCB-Transmission EPD-ENGINE - 2.5L I4 TBI GAS GAC-Tinted Glass Windows JJA-Cigar Lighter LAP-Shift Indicator Warning Lamp LMA-Halogen Headlamps NAA-Federal Emissions NMB-Standard Duty Engine Cooling PA2-Paint QA2-Paint TBG-Compact Spare Tire WMC-Open
Ah you are on mobile, it's a poll asking yes or no so that I can get a sample group to see if they all have that code in the build sheets
This doesn't surprise me at all, are you building something with all the hooks you have?
If you actually look at safety restraint history it is really strange, lap belts optional before 64, as well as heaters. Airbags had been installed in the 70s then removed, and now we have vehicles that are more airbags than vehicle.
But shoulder belts were mandatory that's why I'm thinking it's the grab handle as it was optional in the lower Trims
Atempting to figure out the meaning of this: RR Head Restraints Outboard Seating Thinking it might be for the passenger grab handle
stickman salvage build date: 9/6/88 body: tl61 *X2 DESCRIPTION NOT AVAILABLE -Q8 DESCRIPTION NOT AVAILABLE CBAP Straight Back Bench Seat DBBC All Manual Transmissions DCK Transmission, 4 speed man? EAAC All Engines EAFC Engine EPD ENGINE - 2.5L I4 TBI GAS GFD Rear Sliding Window GRVP Left Manual Mirror MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket PQ9 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RAB AM/FM Radio RCDP 4 Speakers SBA Power Rack and Pinion Steering TAAC All Tires TNCA P195/65R15 BSW AS Touring Tires YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z56P Left Front Spring Group Vi Z75P Right Front Spring Group V 5ALA DT-Vehicle Family APAS Monotone Paint BAQS 115 Amp Alternator BCXS Dual 700 Amp Maint. Free Batteries BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles CUMS Mini Floor Console DMDS 3.55 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror GUAS Open HCDS Do Not Use - See HCA JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS MOPAR Hood Lock KDCS DESCRIPTION NOT AVAILABLE K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS Bright Windshield Moldings MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NF2S 18.5 Gallon Fuel Tank QQ9S DESCRIPTION NOT AVAILABLE SCBS Perforated Steering Whl w/Red Stitch SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels WMCS Open XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 141S Zone 41-Cincinatti
2nd truck vin same as the first
Stickman's Salvage in service date 10/29/85 body: ts66
RIP John
