14
10 Pin Connector Behind Headlight
cruiser54 replied to 4x4hemi's topic in MJ Tech: Modification and Repairs
Refresh the grounds on the driver's side inner fender. Remove, scrape paint, polish terminals and reinstall tightly. Those 2 or 3 wires are critical for lights and wipers. Stupid sheet metal screw that sometimes isn't tight. Ever done my ground refreshing and connector refreshing? Click on the link in my signature below: -
They're supposed to be replaced every 82,000 miles or so anyway. O2 sensor testing 1987-1990 Renix For the Renix years, 87-90, the O2 sensor has 3 wires, 2 black and 1 orange. The orange wire (largest gauge of the 3) is the 12-14 volt power that comes from the O2 sensor heater relay on the passenger side firewall, and that powers the internal heater in the sensor so that the sensor can work at idle, and almost immedietly after start up. Loss of that power will hurt gas mileage even with a good O2 sensor. One of the black wires is a common ground for the heater power and O2 signal to the ECU, so a poor ground will give a voltage feedback from the heater power input, to the ECU causing poor mileage even with a good O2 sensor. The third wire, also black is a voltage feed wire, 5 volts, from the ECU to the O2 sensor. The O2 sensor is an O2 concentration sensitive variable resistor. At optimal O2 concentration the 5 volt input feed to the O2 sensor drops to 2.45 volts due to losses across the O2 sensor to ground. That same wire if disconnected from the O2 sensor will read 5 volts constant to ground. At idle that voltage should read 1-4 volts oscillating quickly back and forth roughly once every second. At 2000 rpm it should run between 2 and 3 volts max, and is optimally running between 2.3 and 2.6 volts at 2000 rpm (in park). A digital meter can NOT be used for reading the O2 sensor voltage, but it can be used to test the ground and the 12-14 volts to the heater and the 5 volt feed from the ECU with power on and engine off. You must use an old style analog meter with the needle gauge on the display to see the voltage swing back and forth with the engine runing. If the O2 sensor readings are not right, say they read 4 volts or 1 volt steady, you have a problem. BUT before you blame the O2 sensor make sure it has good wiring, and make sure the proper voltage is feeding it, by turning power on, engine off to read the engine off voltage feeds (12-14 volts on the orange wire, and 5 volts on one of the two black wires), and ensure the ground wire (power off) reads less than 1 ohm to the battery negative post. A leaky exhaust system or leaky fuel injector(s), or bad compression, bad rings or leaky valves, bad plugs, wires, cap, rotor, HV coil, and so on, or combination of these, can also cause a lean or rich condition that gives you high or low O2 sensor readings that are not the O2 sensors fault, so try and verify those other items also before buying parts like an O2 sensor to fix your problem.
Last time fuel filter was replaced? Perhaps it's chock full of crud from the bottom of the tank?
Engine Dying Out When Going Downhill
cruiser54 replied to Knucklehead97's topic in MJ Tech: Modification and Repairs
No. Only the output shaft is turning coasting in neutral. Let's not blow this out of proportion. It's okay to pop it into neutral and coast to a light. At speed, like going down long grades, does the damage. Greater speed and greater distance multiply the damage. -
Well, if you had owned a towing business for 13 years, you would be more aware of it. Even some of the NV gearboxes used the aluminum synchro deal as did some 1/2 and 3/4 ton trucks. It's ok to throw it into neutral at a light, but coasting for any distances does noth throw lube up on to the synchros as the counter gear is not moving, only the output shaft. -
OP. Make sure your intake bolts aren't loose. Clean your throttle body and IAC Ever refresh your grounds? -
Medium duty trucks have a synchro system using conical aluminim clutches which get torn up freewheeling. Most automotive applications have brass synchros. Guess what a BA-10 has? The aluminum ones. Don't freewheel it. -
An Oil Filter Is An Oil Filter Right?????
cruiser54 replied to JENSSEN's topic in MJ Tech: Modification and Repairs
Hope you went for it. Fram sucks. -
87 I6 To 2000 I6 Engine Swap Q&a
cruiser54 replied to MJfanatic87's topic in MJ Tech: Modification and Repairs
Here's something interesting about heads: http://forum.thexjguys.com/viewtopic.php?f=9&t=43 -
Here's how The Napa/Wix deal was explained to me by my buddy at Napa. ALL the Wix filters are good. The anti-drainback valves and amount of filtering media are different between the Silver, Gold, and Platinum. All have good quality media and ADBVs. The Gold and Platinum have their ADBVs made from a better material than the Silver so they hold up to the longer interval. Silver is good for 3500 mile changes, Gold for 7500 intervals, and Platinum for extended changes using synthetic oils. I use Silver and change every 3500 miles. -
Super critical to use good quality oil filters on our rigs with the upside down mounting. Thanks for posting that up. Mighta saved an engine or two for some of the readers here in the future. -
Are these the years that are compatable? No. It's a description of the years a certain model was made. -
Year? I would test the CPS and see if it has low output.
And do yourself a favor and eliminate the heater valve. It's not needed and they like to disintegrate at will.
Not really. Renix stuff can be swapped over and used. The big issue here is what Jeep the block comes from as the mountings changed. XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange. 2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange. XJ/ZJ blocks and 2000+ TJ/WJ blocks do not interchange without significant modifications. (1991 to 1995 YJ and 1997-1999 4.0L TJ Wrangler blocks will interchange in XJ/ZJ and visa-versa). TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ. XJ: "Regular" (not Grand) Cherokees 84-01 ZJ: Grand Cherokee 93-98 (Gen1) WJ: Grand Cherokee 99-04 (Gen2) YJ: Wrangler 87-95 (Gen1) TJ: Wrangler 97-06 (Gen2) -
Ground Point For Battery Cable
cruiser54 replied to snakedoc67's topic in MJ Tech: Modification and Repairs
No. -
Try adjusting the TPS this way: And, did you pull, twist or in any other way get rough with the IAC? RENIX TPS ADJUSTMENT Before attempting to adjust your TPS be sure the throttle body has been recently cleaned. It's especially important that the edges of the throttle butterfly are free of any carbon build-up. IMPORTANT NOTE: With the Key OFF, and using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector of the TPS. The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. Wiggle the wiring harness where it parallels the valve cover and also over near the MAP sensor on the firewall. If you see more than 1 ohm of resistance, or fluctuation in your ohms reading, some modifications to the sensor ground harness will be necessary. The harness repair must be performed before proceeding. I can provide an instruction sheet for that if needed. MANUAL TRANSMISSION: RENIX manual transmission equipped XJs have only a flat three-wire TPS mounted on the throttle body and it provides data input to the ECU. It has three wires in the connector and they're clearly embossed with the letters A, B, and C. Wire "A" is positive. Wire "B" is ground. Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors. Note the voltage reading--this is your REFERENCE voltage. Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For example: 4.82 volts X .17=.82 volts. Loosen both T-20 Torx screws attaching the TPS to the throttle body and rotate the TPS until you have achieved your desired output voltage. Tighten the screws carefully while watching to see that your output voltage remains where it is supposed to be. If you can't achieve the correct output voltage, replace the TPS and start over. Sometimes, after adjusting your TPS the way outlined above, you may experience a high idle upon starting. If that happens, shut the engine off and reconnect your probes to B and C. Start the engine and while watching your meter, turn the TPS clockwise until the idle drops to normal and then rotate it back counterclockwise to your desired output voltage. AUTOMATIC TRANSMISSION: RENIX automatic transmission equipped XJs have a TPS with two connectors. There is a flat three-wire connector, same as the manual transmission vehicles have, and it is tested the same as the manual transmission equipped vehicles, as outlined above—FOR ALL ENGINE MANAGEMENT RELATED ISSUES. However, the automatic TPS also has a square four-wire connector, clearly embossed with the letters A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module. THIS SQUARE FOUR WIRE CONNECTOR IS USED FOR TRANSMISSION/SHIFTING RELATED ISSUES ONLY. Key ON, measure voltage between "A" positive and "D" ground. Note the voltage. This is your REFERENCE voltage. Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage. For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage. If you can't, replace the TPS and start over. So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and the other side feeds the TCU. FOR AUTOMATIC TRANSMISSION RELATED ISSUES: Check the square four-wire connector side of the TPS. If you have ENGINE ISSUES check the flat three-wire connector side of the TPS. For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced. Revised 09-22-2012
Guys A Not Starting Problem
cruiser54 replied to banshee's topic in MJ Tech: Modification and Repairs
Do those things anyway, even though you found the problem this time. It can save you headaches in the future. -
Holy $#!&. You are quite redundant!!
Remove the air cleaner assembly. What instructions did you use for the TPS adjustment? If you used mine, you would have done a sensor ground test and tested/adjusted the TPS on the "engine" side. RENIX TPS ADJUSTMENT Before attempting to adjust your TPS be sure the throttle body has been recently cleaned. It's especially important that the edges of the throttle butterfly are free of any carbon build-up. IMPORTANT NOTE: With the Key OFF, and using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector of the TPS. The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. Wiggle the wiring harness where it parallels the valve cover and also over near the MAP sensor on the firewall. If you see more than 1 ohm of resistance, or fluctuation in your ohms reading, some modifications to the sensor ground harness will be necessary. The harness repair must be performed before proceeding. I can provide an instruction sheet for that if needed. MANUAL TRANSMISSION: RENIX manual transmission equipped XJs have only a flat three-wire TPS mounted on the throttle body and it provides data input to the ECU. It has three wires in the connector and they're clearly embossed with the letters A, B, and C. Wire "A" is positive. Wire "B" is ground. Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors. Note the voltage reading--this is your REFERENCE voltage. Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For example: 4.82 volts X .17=.82 volts. Loosen both T-20 Torx screws attaching the TPS to the throttle body and rotate the TPS until you have achieved your desired output voltage. Tighten the screws carefully while watching to see that your output voltage remains where it is supposed to be. If you can't achieve the correct output voltage, replace the TPS and start over. Sometimes, after adjusting your TPS the way outlined above, you may experience a high idle upon starting. If that happens, shut the engine off and reconnect your probes to B and C. Start the engine and while watching your meter, turn the TPS clockwise until the idle drops to normal and then rotate it back counterclockwise to your desired output voltage. AUTOMATIC TRANSMISSION: RENIX automatic transmission equipped XJs have a TPS with two connectors. There is a flat three-wire connector, same as the manual transmission vehicles have, and it is tested the same as the manual transmission equipped vehicles, as outlined above—FOR ALL ENGINE MANAGEMENT RELATED ISSUES. However, the automatic TPS also has a square four-wire connector, clearly embossed with the letters A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module. THIS SQUARE FOUR WIRE CONNECTOR IS USED FOR TRANSMISSION/SHIFTING RELATED ISSUES ONLY. Key ON, measure voltage between "A" positive and "D" ground. Note the voltage. This is your REFERENCE voltage. Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage. For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage. If you can't, replace the TPS and start over. So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and the other side feeds the TCU. FOR AUTOMATIC TRANSMISSION RELATED ISSUES: Check the square four-wire connector side of the TPS. If you have ENGINE ISSUES check the flat three-wire connector side of the TPS. For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced. Revised 09-22-2012
Generally the ground is forward of the dipstick stud. I think it's a good idea to have the battery ground at the stud along with a cable to the 8mm stud near the upper shock mount. -
This Week: Manifold & Exhaust Repair
cruiser54 replied to ParadiseMJ's topic in MJ Tech: Modification and Repairs
Take the air cleaner assembly out to give you better access. -
3.75 quarts for just the pan. Put 3 quarts in, start it up, add as needed .
You can always click on the link in my signature and read them all. -
Rotated Up, on all the time. Center position Off. Rotated down On with Door Open.
