MJfanatic87
1 Follower
    Fort Worth, Tx
  • Interests
    anything with four wheels!
781 profile views
MJfanatic87's Achievements
  1. thanks for the wise insight! I plan on doing a complete master rebuild of the engine and I was looking for some tricks to make more power, so any sugestions is welcome!
  2. The reason I ask is bc I just had the renix head redone and I really hate to not use it. I am just looking for ways to add a little hp and tq to my 87 mj.
  3. And what throttle body should I use?
  4. Will the 99+ intake bolt up to the 87 renix head or do I need to do some modifications to make it work?
  5. http://www.novak-adapt.com/catalog/rear_mounts/rmax15_rear_mount.htm here's the link for the mount
  6. I found a bell housing with external on ebay and the trans/tcase mount from novak.com I think the guy planned on putting this trans in a cherokee so he didnt need the bell from the wrangler.
  7. Okay thanks. I will just have to go look at the trans and count the splines
  8. So new drive shafts are going to be needed
  9. Yes. I know I will need a bell housing bc the one I am looking to buy dose not come with one
  10. I found a 90k trans and tcase out of a 95 wrangler for $250 and I am wanting to know if it is worth it to buy and what else I will need to invest to get it to work?
  11. you guys have answered a lot of my questions and I thank you! I still have one more, If keep my original block and want to put in a ax-15, I will need a different bell housing and trans mounts correct? If there is more to doing this swap please fill me in, please and thank you! :thumbsup:
  12. I am really just thinking of rebuilding the orig motor and doing the ax-15 swap. what are the things i need to keep in mind for doing a ax-15 swap?
  13. Is it really worth the effort to use the new stuff and junk the renix?
  14. I am waiting on a way to contact this person and give them a offer for the whole jeep. http://dallas.craigslist.org/ftw/cto/3792346189.html
  15. I have a 87 MJ with the orginal straight 6 and the non ax-15 5 speed and want to convert it to a 2000 I6 with the ax-15, what do i need to do in order to make this happen? Please help with some guidlines and some steps for this process.
