14
Imagine that!!! Congratulations. Did you do the dipstick tube stud also?
Renix 4.0 To 4.2 Stroker Questions
cruiser54 replied to big66440's topic in MJ Tech: Modification and Repairs
You'll be fine. Stock size injectors but with 4 holes will probably work, too. www.strokedjeep.com has the TBs for less than $100 exchange. -
Renix Ground Refreshing The Renix era XJs and MJs were built with an under-engineered grounding system for the engine/transmission electronics. One problem in particular involves the multiple ground connection at the engine dipstick tube stud. A poor ground here can cause a multitude of driveabililty issues, wasted time, failed emission tests, and wasted money replacing components unnecessarily. The components grounding at the dipstick tube stud are: Distributor Sync Sensor, TCU main ground, TCU “Shift Point Logic”, Ignition control Module, Injectors, ECU main ground which other engine sensors ground through, Oxygen sensor, Knock Sensor, Cruise Control, and Transmission Sync signal. All extremely important stuff. The factory was aware of the issues with this ground point and addressed it by suggesting the following: Remove the nut holding the wire terminals to the stud. Verify that the stud is indeed tightened securely into the block. Scrape any and all paint from the stud’s mounting surface where the wires will attach. Must be clean, shiny and free of any oil, grease, or paint. Inspect the wire terminals. Check to see that none of the terminals are crimped over wire insulation instead of bare wire. Be sure the crimps are tight. It wouldn’t hurt to re-crimp them just as a matter of course. Sand and polish the wire terminals until clean and shiny on both sides. Reinstall all the wires to the stud and tighten the nut down securely. While you’re in that general area, locate the battery negative cable which is fastened to the engine block just forward of the dipstick stud. Remove the bolt, scrape the block to bare metal, clean and polish the cable terminal, and reattach securely. Another area where the grounding system on Renix era Jeeps was lacking is the engine to chassis ground. There is a braided cable from the back of the cylinder head that also attaches to the driver’s side of the firewall. This cable is undersized for it’s intended use and subject to corrosion and poor connections at each end. First off, remove the cable end from the firewall using a 15mm wrench or socket. Scrape the paint off down to bare metal and clean the wire terminal. Reattach securely. Remove the other end of the cable from the rear of the head using a 3’4” socket. Clean all the oil, paint and crud from the stud. Clean the wire terminal of the cable and reattach securely. A suggestion regarding the braided cable: I prefer to add a #4 Gauge cable from the firewall to a bolt on the rear of the intake manifold, either to a heat shield bolt or fuel rail bolt. A cable about 18” long with a 3/8” lug on each end works great and you can get one at any parts store already made up. Napa has them as part number 781116. A further improvement to the grounding system can be made using a #4 cable, about 10” long with 3/8” terminals at each end. Attach one end of this cable to the negative battery bolt and the other end under the closest 10mm headed bolt on the radiator support just forward of the battery. Napa part number 781115. For those of us with Comanches, it’s very important to remove the driver’s side taillamp assembly to access the ground for the fuel pump. Remove the screw holding the black ground wire. Scrape the paint from the body and corrosion from the wire terminal. Reattach securely. If you want to upgrade your grounds and battery cables in general, contact Jon at www.kelleyswip.com. He makes an incredible cable upgrade for a very reasonable price. Revised 03-04-2013
Fuel Pump Or Maybe Cps?
cruiser54 replied to MmMBurritos's topic in MJ Tech: Modification and Repairs
The CPS harness can get burned by the exhaust if not routed properly. I have a photo of how to route it but I suck at posting photos on CC. TEST the CPS output. Renix CPS Testing and Adjusting Renix CPSs have to put out a strong enough signal to the ECU so that it will provide spark. Most tests for the CPS suggest checking it for an ohms value. This is unreliable and can cause some wasted time and aggravation in your diagnosis of a no-start issue as the CPS will test good when in fact it is bad. The problem with the ohms test is you can have the correct amount of resistance through the CPS but it isn’t generating enough voltage to trigger the ECU to provide spark. Unplug the harness connector from the CPS. Using your voltmeter set on AC volts and probing both wires in the connector going to the CPS, crank the engine over. It won’t start with the CPS disconnected. You should get a reading of .5 AC volts. If you are down in the .35 AC volts range or lower on your meter reading, you can have intermittent crank/no-start conditions from your Renix Jeep. Some NEW CPSs (from the big box parts stores) have registered only .2 AC volts while reading the proper resistance!! That’s a definite no-start condition. Best to buy your CPS from Napa or the dealer. Sometimes on a manual transmission equipped Renix Jeep there is an accumulation of debris on the tip of the CPS. It’s worn off clutch material and since the CPS is a magnet, the metal sticks to the tip of the CPS causing a reduced voltage signal. You MAY get by with cleaning the tip of the CPS off. A little trick for increasing the output of your CPS is to drill out the upper mounting hole to 3/8” from the stock 5/16”, or slot it so the CPS bracket rests on the bell housing when pushed down. Then, when mounting it, hold the CPS down as close to the flywheel as you can while tightening the bolts. Revised 01-26-2013 -
Hard Start Up In The Morning
cruiser54 replied to TheDirtyJeep401's topic in MJ Tech: Modification and Repairs
Before throwing parts at it, do some simple stuff. Are your intake manifold bolts loose? Those hoses to the intake manifold below the throttle body-are they rotted and leaking? Have YOU ever put in new copper spark plugs, cap and rotor with brass terminals, and some premium ignition wires? Done a ground refreshing and C1o1 refreshing as outlined in "Cruiser's Mostly Renix Tips" that you can click on in my signature? -
Not while it's running. In my signature, click on the link. There's a "sensor ground repair" post with photo.
Unplug the dizzy and see what happens. How did you address the ground fluctuations when wiggling the harness?
1988 Jeep Comanche Stalls, But Not In Neutral
cruiser54 replied to jnickle's topic in MJ Tech: Modification and Repairs
What on earth would loose trans bolts cause?? :hmm: Movement between engine and trans, causing the interruption of the CPS signal. -
Do aLL the grounds. And, check to see if the engine to trans bolts might be loose. -
Clutch Issue, Got I Robbed?
cruiser54 replied to Gilbertond's topic in MJ Tech: Modification and Repairs
Too late now. Replace the hose. -
Sometimes the hose between the master and slave cylinders deteriorates internally and allow it to swell. Big problem in 84 through 86 IIRC as the factory used the wrong fluid. -
Lol I know absolutely nothing at all about jeeps which was why I posted it in first place. Without ideas on what it could be I would be sitting there for hours probably just attempting to trace the leak and scratching my head. Lol I know absolutely nothing at all about jeeps which was why I posted it in first place. Without ideas on what it could be I would be sitting there for hours probably just attempting to trace the leak and scratching my head. Any comments on here are guesses. Facts will only be found by YOU.
YOU are perfectly capable of figuring this out and best of all, YOU are THERE!
I'd sure check to see if it's the OFA or dizzy gasket first before making that commitment.
So, you're telling us that your crystal ball is still in the repair shop? LOL. Good point.
Do this first. I'd be looking up ABOVE first, and VERIFYING the source of the oil leak YOURSELF. Everybody, who doesn't own or have to pay for or perform your vehicle repairs, loves to poke their noggin UNDER the Jeep and come out bearing the false bad news that your RMS is leaking. Many mechanics, friends, people on Jeep forums who can’t see your Jeep from where they’re at, and good old Uncle Bob seem to enjoy telling you it’s the rear main seal. Has a catastrophic ring to it, doesn’t it? A simple leak at the back of the valve cover or other source could produce the same symptoms. You don’t need to be a mechanic to figure this out. If you have good eyesight and a dim flashlight, you’re good to go on your own. Don't jump on the RMS/oil pan gasket bandwagon right off the bat. Almost any oil leak on your 4.0 is gonna drip from the RMS area for two simple reasons. First off, the engine sits nose-up and any oil will run back to the RMS area. Secondly, the RMS area is also the lowest point on the engine. Simple physics and the old plumber's adage apply here. "$hit flows downhill". Valve cover gasket, oil pressure sending unit, oil filter adapter seals and distributor gasket, in that order, have to be eliminated as possibilities first. Revised 02-26-2013
Just for giggles, unplug the dizzy connector, clean it out with electical cleaner, tweak the pins.receptacles, and plug it back in. Is the connector oil soaked?
It is with my DRB also.
Hard Cold Starts ( Engine Temp)
Easily checked with a meter. Have you ever done this? Cruiser’s Renix Sensor Ground Test This sensor ground circuit affects the CTS, TPS, IAT, MAP, ECU and diagnostic connector grounds. It’s very important and not something to overlook in diagnosing your Renix Jeep as it is common for the harnesses to have poor crimps causing poor grounds. If any or all of the sensors do not have a good ground, the signal the ECU receives from these sensors is inaccurate. Set your meter to measure Ohms. Be sure the key is in the OFF position. Using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector of the TPS . The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. Wiggle the wiring harness where it runs parallel to the valve cover and also near the MAP sensor mounted on the firewall. If you have an 87 or 88 with the C101 connector mounted on the firewall above the brake booster, wiggle it, too. You want to see as close to 0 ohms of resistance as possible. And when wiggling the harnesses/connectors the resistance value should stay low. If there is a variance in the values when wiggling the wires, you have a poor crimp/connection in the wiring harness or a poor ground at the engine dipstick tube stud. On 87 and 88 models, you could have a poor connection at the C101 connector as well. Revised 06/12/2012 -
Easy to test the IAT and CTS. Could also be a bad ground in the sensor circuit. -
Yep. LOL. Mr Cracker pulled a good one.
I think so.....
You frickin' bonehead. LOL. Thanks for the update.
Safe, yes. Code 54 is what?
