cruiser54
    14
  1. Fuel pressure regulator is bad, allowing higher than necessary fuel pressure at idle. Replace it.
  2. Kinda makes me think of never changing your undies because they're just gonna get soiled again.... Buy black ones or brown ones.......
  3. Well stated and exactly right.^^^^^
  4. Especially when their rig runs like crap and they haven't addressed that very well so far. My rig runs like crap and I need to mess with it's wheels!!!!
  5. Stay on task.....................
  6. And? Click on my Tech Photos link and you'll find some diagrams/photos of that hose.
  7. Check the tube from the throttle body to MAP sensor on the firewall. It must be perfect or your MJ will run pig-rich.
  8. Swap the relays around on the passenger side inner fender. Good idea shelbyluvv. With it idling, shake the crap out of the engine harness everywhere you can.
  9. Click on the link in my signature and do posts 1,3,4, and 5. After that, 8.
  10. The head can be drilled and tapped in the same location as the Renix head was to accept the gauge sender.
  11. Connector Number Locations Connector C100: Left Of Master Cylinder On Dash Connector C101: Above Master Cylinder Connector C102: Behind LH Headlamp Connector C103: Next To RH Shock Tower Connector C104: Next To RH Shock Tower Connector C105: Behind Battery Connector C106: Next To RH Shock Tower Connector C107: Next To RH Shock Tower Connector C108: In Front Of Washer Bottle Connector C109: Next To RH Shock Tower Connector C110: RH Rear Of Rocker Cover Connector C111: RH Rear Of Rocker Cover Connector C112: RH Rear Of Rocker Cover Connector C113: RH Rear Of Rocker Cover Connector C114: RH Rear Of Rocker Cover Connector C115: Under Dash To Right Of Steering Column Connector C116: Above Master Cylinder Connector C117: In Front Of Washer Bottle Connector C118: Under LH Side Of I/P Behind Kick Panel Connector C119: Under LH Side Of I/P Behind Kick Panel Connector C120: Behind A/C Mode Select Switch Connector C121: Under LH Side Of I/P Behind Kick Panel Connector C122: Under RH Side Of I/P Behind Kick Panel Connector C123: Under RH Side Of I/P Behind Kick Panel Connector C124: Under LH Side Of I/P Behind Kick Panel Connector C125: Under LH Side Of I/P At Kick Panel Connector C126: Behind LH Rear Inner Fender Panel Connector C127: Behind LH Rear Inner Fender Panel Connector C128: Under RH Side Of I/P At Kick Panel Connector C129: Behind RH Kick Panel Connector C130: Under LH Side Of I/P At Kick Panel Connector C131: Under LH Side Of I/P At Kick Panel Connector C132: Under LH Side Of I/P At Kick Panel Connector C133: Under LH Side Of I/P At Kick Panel Connector C134: Under RH Side Of I/P At Kick Panel Connector C135: Under RH Side Of I/P At Kick Panel Connector C136: Under RH Side Of I/P At Kick Panel Connector C137: Under RH Side Of I/P At Kick Panel Connector C138: Under Front Seat Connector C139: LH Rear Inner Fender Panel Connector C140: Behind LH Rear Inner Fender Panel Connector C141: Behind LH Rear Inner Fender Panel Connector C142: Behind LH Rear Inner Fender Panel Connector C143: Behind LH Rear Inner Fender Panel Connector C144: Behind LH Rear Inner Fender Panel Connector C145: Behind LH Rear Inner Fender Panel Connector C146: Behind LH Rear Inner Fender Panel Connector C147: Behind RH Rear Inner Fender Panel Connector C148: In Console Connector C149: In LH Side Of Liftgate Connector C150: In LH Side Of Liftgate Connector C151: In LH Side Of Liftgate Connector C152: Behind A/C Mode Switch Connector C153: Near Cargo Lamp Connector C154: Above Transfer Case Connector C155: Behind RH Kick Panel Connector C156: Under I/P On Steering Column Connector C157: Below LH Side Of I/P Above Parking Brake Connector C158: Rear Center Of Cab Under Carpet Connector C159: Behind LH Rear Tail Lamp Assembly Connector C160: Behind LH Rear Inner Fender Panel Connector C161: At Rear Bumper Connector C162: At Rear Bumper Connector C168: Top Of Washer Bottle Connector C169: Below Washer Bottle Connector C170: LH Side Of Cowl Panel Grille Connector C171: To Left Of Steering Column Connector C172: In Driver's Seatbelt Buckle Connector C173: Under RH Front Seat Connector C174: Under LH Front Seat Connector C175: Behind RH Headlamp Connector C176: On Left Of Steering Column Connector C177: LH Side Of I/P Next To Light Switch Connector C178: LH Side Of I/P Next To Light Switch Connector C179: Behind RH Side Of I/P Connector C180: At Speaker Connector C181: At Speaker Connector C182: At Speaker Connector C183: At Speaker Connector C184: At Speaker Connector C185: At Speaker Connector C186: In Center Of I/P Connector C187: In Center Of I/P Connector C188: Below I/P Behind Defogger Relay Connector C189: In LH Side Of Console Connector C190: Under LH Side Of I/P At Kick Panel Connector C191: Under RH Side Of I/P At Kick Panel Connector C192: Taped To Harness Above Fuse Block Connector C193: Behind Center Of I/P Below Lighter Connector C194: On I/P To Right Of Steering Column Connector C195: Below Washer Bottle Connector C196: Center Of Liftgate Connector C197: Center Of Liftgate Connector C198: On I/P To Right Of Steering Column Connector C199: In Driver's Seatbelt Buckle Connector C200: Under I/P To Right Of Steering Column COMANCHE Connector C100: In LH Dash Panel Forward Of Fuse Panel Connector C101: Behind LH Headlamps Connector C103: RH Side Rear Of Engine Connector C108: Near A/C Compressor Connector C109 (Diesel Engine): Near Lower Center RH Inner Fender Panel Connector C109 (Gasoline Engine): Near A/C Compressor Connector C112: Behind Battery Near Starter Relay Connector C115: Taped To Engine Harness Behind Cruise Servo Connector C119: LH Side Of Engine Near Glow Plugs Connector C120: LH Side Of Engine Near Glow Plugs Connector C200: Under LH Side Of I/P Behind LH Kick Panel Connector C202: Under LH Side Of I/P Behind LH Kick Panel Connector C203: Under LH Side Of I/P Near Ignition Switch Connector C204: Behind Mode Select Switch Connector C205: Under RH Side Of I/P Behind Kick Panel Connector C207: Under I/P Above Brake Pedal On Steering Column Connector C209: Under RH Side Of I/P At Kick Panel Connector C210: Near RH Door Jamb Switch Connector C211: To Left Of Steering Column Connector C314: In RH Side Of Liftgate Connector C315: In LH Side Of Liftgate Connector C402: Under LH Side Of I/P At Kick Panel Connector C404: Under RH Side Of I/P At Kick Panel
  12. You guys all oughta take a tour through the Tech Photo link.
  13. Here's one I bookmarked once. http://www.cherokeetalk.com/forum/f68/xj-hood-strut-shock-conversion-17421/
  14. Click on the Tech Photos link below in my signature. There's a photo of CTS location in there.
  15. Could me. I've always dealt with them with my engines on a stand.
  16. Cool stuff. And you know I'm only teasing you about the wiring diagrams, right? LOL.
  17. Gotta love it. Great job. How come I had to look it up for ya then? You've got a schematic!!. LOL. Any time.
  18. The brake lights and turn signals share the same wiring. They also share the turn signal/hazard switch up in the column along with a few connectors. Wiggle the hazard knob in and out and see what happens. But, don't ignore the connector previously mentioned.
  19. Is the intake boot on the throttle body held on with 3 screws or a clamp? 3 screws is renix.
  20. 2 different circuits in play. Look up under the dash/steering column and see if a long white or blue connector with a ton of wires isn't partially disconnected.
  21. Yes^^. AThanks for your post. We’re here to help but you must understand that all Jeeps are not the same. In order for us to give you more accurate advice and help, we must know the following, as applicable, along with detailed information as to the symptoms/problems etc: Year Model Engine Transmission Transfer case
  22. I think you were reading about changing the key tumbler......
  23. Just asking is there a way to tell if the system is hold pressure or not? Yep. It will get hot and spit coolant out around the cap.
