Hello all,
I bought a '90 MJ last year and have been having a blast with it. Once I work out how to post pics I will do just that. Here's some specs: 1990 4.0, 5 speed, 4x4. It has an open air filter, header, high-flow exhuast, 6 inch Terraflex lift, Summit Racing 15" steelies, BFG 33x10.50 AT's, and it's fair share of character. I actually converted to the dark side when I sold my '81 Land Cruiser and picked up this MJ.
The truck developed a high-idle problem somewhere along the line that I am still chasing. I've done a tune up and replaced the IAC. Removing and cleaning the throttle body and checking the manifolds for leaks and loose bolts is my next step. I messed with the TPS before I stumbled upon this website and found some knowledge saying "DON'T MESS WITH THE TPS" so I'll have to follow the steps to get it back in line.
There is one thing I still can't figure out. I've been working on it for a month now and I just turn up nothing. I need a tie rod end for where the drag link meets the pitman arm. It is a dropped pitman arm and it is factory steering. "Get a steering upgrade!" is unfortunately an answer that doesn't work for me at this time because funds are tight. When I got the part from NAPA it is too short. As in only a 1/4" of threads would go into the adjusting sleeve. Is there another, longer, tie rod end that will work? Some where I saw someone say a 91-2001 Grand Cherokee drag link to pitman arm tie rod end would work. I haven't had the local parts store pull the two parts for comparison yet but am I barking up the wrong tree? Or does that have some merit to it?
This truck is my daily driver and my goal is to be Rubicon ready by next Labor Day.
Thanks! And happy wheeling!
~Gabbo
