cruiser54
    14
  1. Harnesses. http://cruiser54.com/?p=121
  2. Go to www.cruiser54.com and complete Tips 1,3,4, and 5 next.
  3. Good old stethoscope beats videos any day. Glad to hear that's all it was.
  4. Wouldn't the gauge read even with the ignition off then? No. The fuse panel is powered from the Ign switch only in the Run and Start positions. So, what's the plan? Why did the guy in the link go to the trouble of using a relay?
  5. Here: http://cruiser54.com/?page_id=365
  6. Yeah man. This isn't gonna get done from a forum......
  7. Did you read the link? I like your idea better.....
  8. Wouldn't the gauge read even with the ignition off then?
  9. I think that's a silly and pedantic point to make, and I never described the volt meter specifically as Renix. To me a "Renix-ism" as an odd characteristic of a Renix era truck. I'll have to poke through the FSM to see how the 89 wiring does it and do something similar when I decide to fix it. I'd much rather do that than run a new power wire to the gauges from the battery. If I come up with something I'll report back. Did you view this link? http://www.jeepforum...uge-fix-684375/
  10. Don't fire off the parts cannon just yet. Last time it had new NGK plugs, new wires cap and rotor?
  11. If you want to get carried away: http://www.jeepforum.com/forum/f11/renix-voltage-gauge-fix-684375/
  12. Check your 12V inputs at the clock connector as follows: Pin B Orange wire "Panel intensity input" (+) - 12V variable controlled by headlight knob rotation Pin F Purple wire "Ignition on input" (+) - 12V ignition switched Pin G Blue wire "Dim display input" (+) - 12V applied when headlamps are turned on Pin C Pink wire "Battery input" (+) - 12V constant memory Pin A Black wire "Ground" (-) Is that info from the 89 manual?
  13. Clock has 2 illuminations. Only visible with key On. Changes intensity when headlight switch is activated. As for the volt gauge. add the ground and report back please.
  14. Yep. They're the best I've found.
  15. Yep. JKs have worked great for me. Smoother than anything I've had. Hornbrod's @$$ must be super sensitive.
  16. Very good guess.
  17. Or go here: http://cruiser54.com/?page_id=365
  18. That looks like a Renix nipple. What part number oil filter did it have on it?
  19. Your best chance of pinpointing it is with this:
  20. Probably not a bad idea for us guys to snag at least one or two of those first chance we get.
  21. I dedicated my website to him. http://cruiser54.com/?page_id=492
  22. Bought a new fridge from Lowe's.....
