Ωhm
    6
Everything posted by Ωhm
  1. Take this with you. Might help DMV understand better. Maybe you'll have to buy O2S and PCV. maintenance reminder light reset procedures.pdf
  2. Claims it can. From page_1 Installation Instruction manual. It treats the input and output entirely separately, so it doesn't care if the input to the gauge is scaled differently than the sender, or even if the sender signal is reversed - it can correct for that.
  3. _mj1988electricalmanual_1.pdf
  4. TCU fuse (7.5A). Fuse block.
  5. It does seem like you have two different TPS(V)(%) settings. Sticking/binding somewhere. Your ST fuel trim is bouncing above and below 128. Normal. LT fuel trim (141) is high, but your INJ PW=4.1mS is low, so I’m going to assume it just the type of injectors you’re running with. All of this is within the range of authority for the ECU.
  6. Concur, TPS values do seem low, as for the ST/LT fuel trim, let vehicle get up to normal operating temperature first.
  7. I'll take a shoot in the dark here. Is it possible that the cluster connectors can go in two different ways?
  8. Knock Sensor Component Testing pg45.pdf
  9. Coolant Temperature Sensor.
  10. Jeep_Renix_Fuel_Injection_manual.pdf
  11. Ωhm
    CPS by Holstein
    Has anyone ever heard of this company before? Holstein Parts; Use the E-Catalog - 2CRK0240 (CPS). Engine Crankshaft Position Sensor-GAS, TBI Holstein 2CRK0240 | eBay
  12. Isn't CHECK ENGINE used for OBDI codes (blinkes)?
  13. Check on the braided strap between CAB and ENGINE block.
  14. With the ECU in CLOSED LOOP (CL), your REM numbers are kinda okay. Things I don’t like are IDLE, INJ_PW, and TPS. I’d look for ≈750rpms, 5.5mS, and 17. Can only suggest a few @cruiser54 tips. http://cruiser54.com/?p=60 http://cruiser54.com/?p=94 Do this one last: http://cruiser54.com/?p=54
  15. This RED wire ties back to one of the fusible links (GRN). Only connector is C100_D4.
  16. 1vdc on O2 would indicate going RICH. Maybe its trying to correct for the LEAN condition.
