6
Everything posted by Ωhm
The small gauge wires (SW to GND), when connected, would Bulb Check when the KEY is SW to the CRANK position. The ORG wire (C268_I3) would require a 12vdc feed (C268_B3) from a HOT circuit and the KEY needs to be in the RUN position.
Bulb checking is a function performed during CRANK. It requires switching to ground (small gauge wires). This will light the lights (BRAKE_COOLANT) letting you know the bulbs are GOOD. You may lose this function unless you can come up with some Relay logic (switch to GND) for these circuits during the CRANK cycle. I’m not sure what to say about the ORG wire except it’s a HOT in RUN circuit. Wiring here is most confusing. Seem to affect certain Clocks/certain Radios circuits. Not much help here.
That proves you’re in perfect balance with the universe. Balance being the key word here.
What's the goal here? Totally eliminate the IGN SW. Big job if so. I believe there're kits out there.
Looks like Connector C268. I3(orange) should be Power Window Circuit Breaker/Clock fuse feed. Smaller gauge wires would be used for the purpose of Bulb Checking (G1_G2) (Brake bulb_Coolant bulb). B3 is Fuse_Link_F.
A few questions about my new / first MJ
Ωhm replied to CheepComanche's topic in MJ Tech: Modification and Repairs
C178 Headlamp Delay Module, if equipped. -
C260 Cruise/Trans Switch Welcome to the CC forum. -
This took nine (9) times logging in and out.
Something like this also happens to me. I’ll get the whirling whirl and nothing never happens. If I’m trying to follow a topic or when posting in a topic. If I login a dozen or more times things will sometimes work as they should. I assumed I was the only one. Running windows 10 on a desktop.
_mj1988electricalmanual_1.pdf C118 Pg 56, 61, 63
Using a voltmeter or 12vdc testlight (preferred) check for Battery_Voltage_(B+) on the following pins (use battery_negative terminal for ground): D1_5: B+ (Hot at all times) D2_4: B+ (Hot during KEY ON/CRANKING). D1_6: KEY ON (B+ (Hot for 2-3 seconds)) or CRANKING (B+ (Hot during CRANK)).
You’ll need at least 300+ engine rpms during CRANK before the ECU will even think about SPARK and FUEL. Make sure battery and/or starter motor are up to the task.
Rough idle misfire sometimes questions
Ωhm replied to knever3's topic in MJ Tech: Modification and Repairs
Manifold Absolute Pressure (MAP) Both BARO_PRES and MAP values are displayed using a absolute scale since that what the MAP sensor deals in. MAN_VAC value is calculated and displayed using a gauge scale, same as a vacuum gauge one would carry in their toolbox. MT2500/DRB/REM uses the following formula to display MAN_VAC: (BARO_PRES)-(MAP)=MAN_VAC. -
Throttle Body Position Adjustment- Help!
Ωhm replied to Eriko5000's topic in MJ Tech: Modification and Repairs
There is a relearn procedure for when the battery is disconnected. Have you disconnected your battery recently? 88 FSM Computer Relearn Procedures.pdf The 3 thou is a calibrated air leak setting. This allows the pintle on the IAC to be in such a position for idle air bypass control. That is too say, a good place for the pintle to move in or out of the air bypass chamber. Also this setting will prevent throttle plate freeze up/lockup during extreme cold temperatures. -
You might not have to move it all. Do this first: http://cruiser54.com/?p=94 -
Your MAP sensor looks good on this recording. On a previous recording MAN VAC showed 20+”Hg @ idle. 18.4”Hg @ idle is typical MAN VAC, verified with your analog gauge. That new MAP line routing has a dip in it at the MAP sensor itself. You might not want that elbow there. -
I wonder why your INJ_PW time is low (4.3_4.9mS), yet LTFT is adding time to INJ_PW. Are you running with factory injectors? -
Poor performance and gas mileage checklist
Ωhm replied to Billabob's topic in MJ Tech: Modification and Repairs
Note the metal foil with bare stranded wire (shield). This makes up the shielded circuit used for the Knock Sensor (KS). This shielded must find a path to ground. Protects against Electromotive Force (EMF) Don't want to RETARD your timing unnecessarily. Shielded circuit is shown using dashed lines.
