MuddFoot
Everything posted by MuddFoot
kinda got cold here 83 when i checked.
Ba10/5 3rd gear whine, how much time do I have?
MuddFoot replied to teamsmith's topic in MJ Tech: Modification and Repairs
http://lucasoil.com/products/engine-oil-additives/lucas-heavy-duty-oil-stabilizer -
my buddys ba10/5 had super bad whine we ran 100% lucas oil stablizer read the bottle says for noisy gear boxes use 50-100% ran it for 2 years finally took a $#!& when wheeling only had 1-2 and rev -
hasn't snowed in haines city fl since 1979 i wish it would so i could see it
Exhaust manifold bolt size
MuddFoot replied to Bounty Hunter's topic in MJ Tech: Modification and Repairs
i wouldnt use grade 8 there just incase you really ever break one drilling would be a pita -
if you get the lines from the jy when you pull the bb and mc do you still have to make new lines to connect to the mj proportioning valve???
- 70 replies
- Dual Diaphragm
- XJ
(and 7 more)
Tagged with:
ok whats it do to it?
thats what I'm painting my jeep with i already did some test sprays on some fenders i had laying around. i didn't use mineral spriets i used xylol it sprays better and drys better i did 2 coats on my test with gray primer and was happy with the results. i spent twice as much to paint my rock crawler and wasnt as happy. paint lays down better than my ppg i was using. i will also be putting on a clear coat and maybe some metal flake
you could just find the newer doors without power.its rare ive only seen 1. i did the 97 doors on my mj. the power windows to get them to work right wasn't that bad but i gave up on the power locks just because its not a 4 door.
snow whats that??? ive never seen snow in person.
Rough Country Long Arm Install
MuddFoot replied to joester1908's topic in MJ Tech: Modification and Repairs
tried to get my yj springs replaced with there lifetime warranty with proof of purchase. was on the phone for 2 weeks sent emails and pictures i ended up buying some jy springs. i wish i had there email that said it doesn't look like our product. its the looks wrong because the springs are repainted because they were rusting. so i havent bought a product since. -
transmission problems questions
MuddFoot replied to bbe's topic in MJ Tech: Modification and Repairs
when your moving it to reverse see if it trys to catch at all. i had a issue in my first 88 with no reverse i changed the fluid to Valvoline max life dex/mec which is a universal fluid if you have ever took the class from valvoline oil. added 1/2 a bottle of lucas and changed the fliter. seemed to work for me. on the tcm reverse would still work if it was bad you wouldn't be able to shift through the forward gears unless you manually did it. -
10 grand comanche
MuddFoot replied to sweet home AU's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
jk wheels here 300-500 for 5 if its as good as it looks he can keep the wheels and id give him like 3grand -
a lot of guys here in fl and on cherokeetalk.com had issues with the joints some right out of the box some 200mi 1000mi ect they are just $#!& i guess. i know my rc short arms i had joints went bad in a week. -
2000 miles and your rc joints are still good??? -
mines a 99 ext cab. i didnt mesure but the seat looks like it won't fit. withe is good but mounts are to close to the tranny tunnel. too much to modify for me right now.
i just had a issue with the actual pump wires is redid them all and redid the ground to the pump i still have a bad sending unit but it runs great.
i just bought a ranger and if they could fit i would do it because the 60/40 bench would be nice. ill mesure tomorrow but the seat brackets are way different. probley gonna need so good mods
i changed it with one i had here and it was still messing up. so i left it pluged in and unhooked the main vac line and plug the line if you unplug the solenoid it runs even worse i guess it has to be plugged in no matter what. so the electrical has to stay plugged in and the vac disconnected and it runs perfect. so I'm going to start cleaning up the truck and getting ready to paint.
what year mj and does it have the baliest resister. if so remove and put the 2 wires together
egr. i messed with everything but it pulled the vac hose off and boom runs perfect. but look at all the spare parts i have laying around now.
