MuddFoot
Everything posted by MuddFoot
  1. some do some are welded on
  2. I'm pizzman3872 on cherokeetalk.com
  3. check all fuses. check sockets for power. follow wires look and test as you go down. check and see if your flashers work.
  4. i ordered one for my yj like a few years ago. leather and everything. i think it was like 22 bucks i wish i could remember the site even came with the jam nut
  5. i also have been thinking about this
  6. both my radiators were out of 99 and 96 xjs so ho. yes it is threaded i tried to remove and could not turn it.i even heated it.
  7. thank you great idea
  8. i just used my jcr bumper i bought the diy front and rear and just finished the rear took me a while but i work alot i would highly recommend it it looks great its super strong. I'm actually ordering a few more diy kits for my buddys jeep
  9. i just tried to pull the lower connector out of the radiator good luck i had 2 bad radiators in my shop and both i couldn't get out id ether use a compression fiting on it or a good set of hose clamps. i went out to look since know one else new what your trying to do. looks like 5/16 or maybe 3/8 line note mine were factory radiators no nut just the barb fiting sticking out
  10. i'd go up in reverse lol
  11. lol he has all the parts
  12. cut the little black slide off and use vice grips. just did this on my mj. when you replace your bolts buy the allen wrench that fits it perfect and put it in your glove box and mark it because its one of those tools you lose when you need it.
  13. ordered be here soon
  14. did all cruisers tips tps is like dead on
  15. 89 jeep mj idles fine touch the gas sputters then dies sometimes. driving it it will be fine for a while the i stop and it sputters then dies. when i unplug the o2 sensor runs perfect. is this the problem or should i look elsewhere?
  16. MuddFoot
    2018 Wagoneer.
    looks like another commander with a new logo and probably another fail.
  17. i am currently building front and rear diy jcr bumpers and couldn't be happier makes it easy and not much more than i spent when i built mine for my other jeep. i will 100% buy them again
  18. i have them just waiting to install. they are super beef compared to the other crap out there
  19. custom mounts with 2 small bolts and is square wish i had a pic for you but its dark now
  20. autozone has a universal overflow bottle for like 10 bucks.i mounted mine where the pressure bottle was..
  21. i think 400 for a used motor from my buddys junkyard sounds better and its only 120 to get a head redone here just don't have the time to wait for it to get done
  22. thats why i wanted to use my extra i had it machined like 2 years ago. just been sittin
  23. I'm pretty sure its a 2pc thats what ive used in 3 rebuilds. soak in oil before install
  24. compression test 120 118 120 115 30 119
