ggcnash
Everything posted by ggcnash
  1. Needing the passenger side, square plastic peice and the light/lense peice for stock bumper. Thanks in advance for any help
  2. I have the same sub/amp I am satisfied, but that said any decent sub/amp is impressive in a comanche. My suggestion would be about 100$ more it's a kicker 10" with 250 watt amp the dimensions are almost the same as the sound ordinance and blows it out the wate! Good luck
  3. Safelite all the way, got mine 200$ they cleaned it with new trim. The biggest reason I suggest them though is their lifetime warranty against leaks.
  4. I don't normally endorse these products, but I had a leaky steering gear box also at the output shaft and tried a bottle of Lucas power steering stop leak as a temp fix. It took about a week for the leak to stop, but three years later it's still dry with no ill effects. Worth a shot. Gonna try this tomorrow before I tear into mine!
  5. The reason I ask is my first thought improper installation, unless this was a sudden occurrence with previous working brakes.
  6. How long was everything fine for?
  7. They are all over junk yards here in louisiana. Dunno what freight would be, but 150$ usually will get them with 30 day warranty
  8. Deal pm sent Thanks!
  9. Looking for a fair priced passenger taillight thanks
  10. Thanks. If I do the frost king, should I still get the extra mass backing? I've never heard of frost king so I'll read up in it. Thanks again I did 2 layers of frost king and mass backing you can never have enough sound deadening, our Jeeps are loud. Not to mention the mass backing also makes the carpet a heck of a lot more durable. This is just my personal opinion no actual facts, but it's pretty obvious when compared side by side. Now for the frost king it's a foam and foil self adhesive closed cell foam. It's normally used as metal duct wrap in hvac industry, also an assortment of other things. The product works great as sound deadning and insulating ,sticks great to floor(2 layers on floor it compresses), roof, firewall, doors, and other parts of cabin.
  11. Pretty sure Napa sales standard brand too
  12. Just did this to my manche about a month back. Bedliner then frost king then carpet. Must bedliner to avoid future rust. The frost king foam and foil adhesive worked great use two layers on floor as it will compress. Ordered my carpet from stock interiors it fit great just a tip if your old carpet is available use it as a template, because there is a lot of excess on edges. If the old carpet is not available no worries lay it in your studs on the floor for seat will be obvious also your console holes.
  13. Rock auto, I've had great luck with standard brand t series with all my sensors good luck!
  14. Funny, I found a 99 2 door it had the slanted blades but only 5, don't think anything like that was specific to that model probably just after market, oh well the search continues
  15. Thx, trying to find a fan controller that will handle it
  16. Do you happen to know the amperage draw for the stock 99+ fans?
  17. Just purchased from them a few days ago waiting on delivery! Will keep you posted
  18. Everything except rear driveshaft
  19. I would like to do this same thing. I have the fenders, and header just need to find time to do it. My plan is to keep old bumper also, I've always liked the new grill and header but just can't bring myself to like that big plastic looking bumper. Oh well to each his own
  20. Sorry misunderstood should be a straight swap except for what nitro stated.
  21. HO swap Obd1, better Reliability,More Power
