6
Rebuild Questions
Strokermjcomanche replied to wrightstuff's topic in MJ Tech: Modification and Repairs
Youre fine , I have an 01 WJ and don't like them either . I'll stick with the XJ/ MJ . -
Rebuild Questions
Wjs never had a V6 it was an I6 or the 4.7 v8 . Grand Cherokees (Wk's) started using the V6 in 2005 . To the OP : many people call an inline straight six a V6 , just make sure what it actually is . -
The Reason I'm Broke
Strokermjcomanche replied to ryrycars's topic in Member Projects: Your Comanches
Nice truck , where in Ohio are you ? I'm in Youngstown . -
Congratulations Bo !! Is the Mj the honeymoon vehicle ?
Replacement vapor canister
Strokermjcomanche replied to dkmcgowan's topic in MJ Tech: Modification and Repairs
Don't hold your breath as most times when you check they no longer have them . This search shows a couple places that's supposedly still has them . http://www.rearcounter.com/33002870-parts995145.html -
http://comancheclub.com/topic/44750-charcoal-canister-qs/?fromsearch=1 I should have a couple extra used rebuildable. 33002870 ones in my parts pile if yours is trashed . -
I didn't pm the guy but it looks like it's either 157 or 167 k but the pic is blurry . http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=171807691014&category=33678&pm=1&ds=0&t=1437274434352
gauge cluster QUESTION please help
Strokermjcomanche replied to 86manche207's topic in MJ Tech: Modification and Repairs
Wells Tu108 or Standard TS199 or BWD WT761 for the water temp gauge . I can't remember the oil pressure right now but will give you the number when I get home . Edit: Standard PS315 for the oil with gauge -
alternater- need bearing info
Strokermjcomanche replied to DWW's topic in MJ Tech: Modification and Repairs
I forgot to mention , see if there are numbers on the old bearing . If there is you can cross reference to see what bearing you have if the number I gave you is wrong . If you can't get down close enough to read it go to your local parts store and get a new alternator and look at the bearing number . -
Double post -
Iirc it's a 203ff bearing . That's a BCA number , but I could be wrong . -
1986 Metric Ton Diesel
Strokermjcomanche replied to terrawombat's topic in Member Projects: Your Comanches
I know the previous owner , looking forward to see what you do to it . Btw if you're looking for any garnet interior parts I have some extra pieces / parts . -
#s 14 and 15 ?
I had a couple that had the same exact hanger . It was held on with a 18mm bell housing bolt and looked original to me .
I don't have a picture of what you need , but can take one when I get home in a couple days . One sensor is a knock sensor which is the one that has an injector connector , the other is the Coolant temp sensor . The harness runs down behind the power steering pump in my second picture , goes straight down and runs through a cable clamp and to both sensors . Hope that helps , if not someone else should have what you need .
Like these ?
Comparison of the size of the 97 mirrors vs 96 and older folding mirrors : View of the 96 and older mirrors : View of the 97 and newer mirrors : I put electrical tape where the vent window post would be .
Oil leak I need fixed
Strokermjcomanche replied to Jeeper117's topic in MJ Tech: Modification and Repairs
Dextron 3 or equivalent , ATF + 4 came later . I'm pretty sure any of the ATF's work fine. some people run 10w30 motor oil. I put ATF4 in mine. I guess it's a preference then . I've always used dextron with no issues and some of my tcases have many miles .- 31 replies
- Transmission
- Tranny
- (and 4 more)
