Jeeper117
Jeeper117's Achievements
  1. My speedometer is not working g I thought the sensor needed replacing since it was broken still nothing gas gauge is on ultra full reading. I do not know where to begin the search to fix this issue
  2. Ok so I took photos how do I post them on here?
  3. Imma have to start posting photos because some of the things I read hear sound like Chinese lol I get somethings like my tranny is a 5 speed 6 including reverse an I was looking at photos an mine has the idk what's its called but looks like my tranny is 3 maybe 4 pieces bolted together 1 piece is darker then the rest of the tranny maybe different kind of metal
  4. I see the red atf coming out from where the drive shafts hooks up with the case I read that is a simple fix drop drive shaft an replace seal
  5. Ok this is all good to know baptism by fire is what this feels like I couldn't gradually learn this it all has to be learned right now haha
  6. Is the oil in the T case the same oil used in the tranny or do I need different oil?
  7. Yup yup it will be fun if it is indeed the tranny does anyone know what sockets sizes I need I just moved states last week an well 95% of my tools are away from me. Any here from utah, willing to lend a hand or advice I'm more of a visual learner.
  8. yeah I made sure I read another thread about the yellow metals an gl5 being bad so I was going for just plain cheap stuff in the mean while till I can afford fixing the manche. Checked motor oil still at the same levels so I think it is safe to assume tranny?
  9. yeah I made sure I read another thread about the yellow metals an gl5 being bad so I was going for just plain cheap stuff in the mean while till I can afford fixing the manche. Checked motor oil still at the same levels so I think it is safe to assume tranny?
  10. Thank you imma run down to the nearest auto store an pick up some gear oil an keep it topped off until I can afford the repairs needed also is it normal when I fill up my gas tank that when the nozzle clicks off a Lil bit of gas is underneath my truck vent maybe? I don't know
  11. If it is gear oil how do I add more?
  12. How do I check if it is gear oil? Because what is coming out is black as hell an the motor oil is still clear. So can it be gear oil? An how do I go about fixing this?
  13. It is a 1991 with a inline 4 4x4 manual tranny new to jeeps so don't know to much I'm a x-Toyota owner
  14. I just purchased my first jeep an well I drove it home guy said no leaks I looked there was none to the naked eye. As soon as I pull in to car port. Low an behold a leak so I crawl under an notice it seems to be coming from where the tranny mates with the motor. Any ideas on how to fix this asap. Since I bought this Lil truck to be my work truck.
