Strokermjcomanche
    6
  1. https://docs.google.com/spreadsheets/d/1pHFuhGgj6dQDfzyfFJH5z7NCDLW2KX3ABQgAJr3lBvM/pub?hl=en&hl=en&output=html
  2. What a game!!!
  3. Got to go with the Home team , Cavs all the way !!
  4. Factor the springs sagging from 20 + years , the longer shackles ( how much longer? ) and that the new leaves are an inch of lift and they need to settle as well , It seems possible . I don't claim to be a lift expert but I had a similar experience , My 3/2 MT rear springs gave me 3+ lift without changing anything else .
  5. An inch lift from what you had or from stock factory 2wd height ?
  6. Instead of a SYE you can go with a 96 and newer tcase that you can pull the rear shaft on and being it's sealed no ATF will leak out . Driveshaft lengths : http://comancheclub.com/topic/18925-looking-for-driveshaft-lengths-of-stock-trucks/
  7. Thanks Rockfrog , I used paypal so I'm guaranteed .I will get my money back ,that I promise . I'm just trying to get this truck drivable by Thursday for Bantams jeep Festival . If all else fails I might try to adapt the d35 plate to work until I can find the correct one .
  8. The hole was too small , the castle nut wouldn't tighten enough to put the cotter pin in . Maybe a shorter nut ?? I will try to compare the newer and older and see if there are any differences . Thanks
  9. So I bought this^^ plate ( along with another sellers plate of this same side to adapt for the left side ) and the package arrived in the mail a couple days ago . I went to bring it inside and noticed the box was rather light , that's because he sent an empty box !!!!!!!! It was all sealed and the label said the shipping weight was 0 LBS 5 OZ . I contacted him and he said that he's not in the business of shipping empty boxes and obviously he shipped it to me and acted like I was ripping him off . Anyone have access to either side of these plates? Everywhere I've checked has said it's discontinued . Thanks again .
  10. Tried to install this today along with the frame side bracket from a 95 XJ . The taper doesn't seem correct , what bracket do I need to get for this to work ?
  11. Here's a picture including both the piece yellaheep is talking about ( on the left) and the other between the fender flare and body on the right , ( it's the broken piece lol)
  12. 88 swb with 3/2 metric ton springs in rear and 3.5 OME springs (2934) and shocks (60052L) up front . On some of the older threads I've read most if not all of the OME shocks like the N40L have been discontinued . With the truck sitting on the ground I have a measurement of 22 1/4 inches from stud to stud and I'm looking for the correct shock . I bought a pair of N190 shocks but the bushings are too small to fit over the shock mounts and aren't able to be changed . I'd prefer a bolt on shock so I don't run into this problem again, but if you are 100% sure they'll work I'll change bushings too . Thanks on advance .
  13. I know where a 98 2.5 std xj is that was complete as of 3 weeks ago , should still be there at the JY As said above , roughly 94 . Or here's one , https://pittsburgh.craigslist.org/pts/5572106371.html
  14. I'm going to the yard tomorrow, I'll keep an eye out ..
  15. Are you looking for 2 or 4 door panels ?
  16. If you use felpro gasket # 35630 it seals better than the original felpro 35024 .
  17. It does , but it's already in the yard ..
  18. I'm still in the process of locating a hp30 4:10 axle , but the 3:07 axle currently in the truck is in good shape . I'm debating on putting it on now or just waiting till I find an axle / regear and I have the WJ LCAs to install too .
  19. Thanks for all the help guys !! Bushing is on the way ... A friend gave it to me and I only have the cost of the bushing , I just need to swap the frame bracket with a newer Xj one . I really like this style too , as it doesn't need to be taken off to adjust it . Thanks again guys ..
  20. Anyone know what brand this adjustable trackbar is ? I need a new bushing for it and would be nice to know where to order one , unless they're all the same . Thanks .
  21. Have you tried using truck cap tape ? It's foam and has an adhesive side . I also use it between my gas tank and straps to prevent rubbing . http://m.ebay.com/itm/FREE-SHIPPING-Truck-Cap-Mounting-Tape-2-inch-x-30-feet-VOLUME-DISCOUNT-/190885010008?nav=SEARCH
  22. I have a couple roof sections if you need a patch . I'm in Youngstown .
  23. I have a couple 2dr xjs near me at pull a part , ones pretty clean and the other isn't . I'm not sure how I could cut you the panels you need because they don't allow power tools in their yards . Any ideas from anyone ?
