I know this topic has been beaten to death, but this one is a little strange. I changed my ISA with a new one, replaced my intake/exhaust gasket and torqued the bolts, changed all of the vacuum hoses, cleaned the TB and replaced all the gaskets and o-rings.
The problem is, as the title suggests, the ISA is not working. It does not fully extend when I shut off the motor like it is supposed to. I can extend and retract the shaft with a 9 volt battery, so the motor is working. With the ISA unplugged, I have extended the shaft with a 9 volt battery, left it unplugged and started the engine. It revved up to 3500 RPM, so I shut off the engine, plugged the ISA back up and restarted the engine. The RPMs stayed at 3500 and would not come down. I took it for a test drive, and when I returned, the RPMs were still 3500. I order to be able to drive it, I unplugged the ISA, retracted the shaft with the 9 v battery, and the RPMs now are at 800.
I hate it when things don't work properly, so I would really appreciate some help figuring this out. I suspect an electrical issue. I have already checked the Closed Throttle Switch, and it is in spec according to the FSM.
This is a 1989 MJ Sporttruck with a 2.5L engine and a manual transmission.
Thanks,
Tom
