6
Don't get your hopes up , most places that say they sell comanche specific parts normally don't have anything .
WTB spring reinforcement plates for 8.25/d44 Ohio
Strokermjcomanche replied to Strokermjcomanche's topic in Wanted
Has anyone used plates like these^^ ? What kind of modifying ( if any ) needs to be done ? I'm staying SUA and these are holding me up from finishing bolting the axle in place and being able to move the truck . Thanks in advance . -
I don't have the actual plates that I will be using with the 8.25 , so I can't confirm that there is a place to mount the shock bolt . That was my intent in asking if I could use two of the same side plates . Your plates in the video are the same as what I have and I don't like the fact of elongating the holes on the plates and having very little material left . The d35 tubes are considerably smaller than the C8.25 . -
Thanks for the link Don . What I'm wondering is ( since I can't find the other plate ) are the plates a mirror of each-other? The seller on eBay has two of the same side and I was seeing if I could adapt one to fit the other side . Or it would be nice if someone had a pair to sell ... -
Fuel Pump Relay Jumper Wire
Strokermjcomanche replied to dcramer67's topic in MJ Tech: Modification and Repairs
It's had a swap done , you can see where the c101 mounting bracket has been removed directly below the HO sticker . If there is still a sticker on top of the ECU that will give you a ballpark as to what year swap was done . -
http://m.ebay.com/itm/1984-to-2001-JEEP-CHEROKEE-XJ-TRANSMISSION-CROSSMEMBER-/331806354167?nav=SEARCH
AW4 Gear Shift Cable Routing
Strokermjcomanche replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
Over . -
What to do with all my wires
Strokermjcomanche replied to Jackrabbit41's topic in MJ Tech: Modification and Repairs
In addition to the above , another idea is to use a dual terminal battery ( top / side post ) . That would relocate and hide the secondary cables and also keep those large cables from the hood . This is assuming you haven't done it yet .. -
That bridge is on route 25 right ? I think I seen it when I visited last month .
88 Mj Swb with metric ton springs . As the title states I'm looking for the leaf spring retainer plates where the ubolts run through . Or I would also take the newer 91-92 plates that are designed differently . I'm switching from a d35 to a C8.25 , I know I can probably enlarge the holes to make it work but want to just replace the plates . Let me know what you have and thanks in advance !! Here is a thread showing what I'm looking for ... http://comancheclub.com/topic/45659-rear-axle-shock-mounting-plate-question/?fromsearch=1
1986 Comanche HVAC Delete/Block off plates
Strokermjcomanche replied to Kano808's topic in MJ Tech: Modification and Repairs
You're going to have 3 holes that need covered . The two you referenced and also the one on the cowl panel . Being that the metal is relatively flat you're probably best off just making some patch panels and riveting / welding / bolting them in . To my knowledge I don't believe those delete panels are sold anywhere.. Here's a pic to reference the holes . -
Stumbled upon this
Strokermjcomanche replied to Strokermjcomanche's topic in MJ Tech: Modification and Repairs
Maybe if I was taller . I have plenty of room to spare to slide the seat back as it is now . -
Stumbled upon this
Private seller that has some parts that he's kept for years . I'm working on trying to get some more parts from him too . -
Stumbled upon this
Except 67 olds back glass trim that someone's willing to sell , sorry Troy . -
Comanche specific tool box / gun rack . Anyone have one ? It would serve a purpose for when I go to the shooting range because when I transport my guns they need to be locked seperately from the ammo .
WTB: cherokee running boards or ends . Ohio 44509
Ok now I'm looking for one complete running board , doesn't matter if it's left or right . Thanks in advance . -
Well the bench is out......
Strokermjcomanche replied to 13 Legion's topic in Member Projects: Your Comanches
1st pic ( cargo lamp ) 2nd pic ( speaker ) 3rd pic ( harness for 4wd / floor shifter illumination ) . -
87 mj 2.5 finding a p brake cable
Strokermjcomanche replied to Manson_magot's topic in Member Projects: Your Comanches
Mirrors yes ( depending on which style you have) . The xj has a hand parking brake as to where the Comanche has a foot brake , so no . The parking brake cable can be had for less then $20 at your local parts store , and it's brand new . Youll get more response if you put your questions in "Mj tech" Edit : I see you made two posts , disregard . -
Stereo harness adapter
Strokermjcomanche replied to Axeminister's topic in MJ Tech: Modification and Repairs
This is listed as a jumper , part# 56003160 . http://m.ebay.com/itm/NOS-OEM-Factory-Original-AMC-Jeep-Wiring-Harness-56003160-/111964909448?nav=SEARCH Maybe someone can confirm if this works or not .
