Strokermjcomanche
    6
  1. And when you say "no ac " are you referring to it's not gettin colder ? Or the fact that the truck came with no ac . The picture for# 1 shows a no ac truck so I just wanted to be sure .
  2. 1. I believe the blue vacuum hose should go to the vacuum ball located behind the bumper on the passenger side.there should be another hose connecting the two.The heat/ ac selector is a cable located under the passenger side of the dash make sure it's hooked up . The two are not related but if you can't change to vent / defrost etc . The blue vacuum hose being unplugged is you culprit . 2. That's a plug for lowwasher fluid which is not used to my knowledge on Mjs but is used on xjs 3. That's is the optional under hood light plug . Being I don't see one on your truck it's good where it's at.
  3. 91 Comanche kid it was cut and parts were missing I think I remember dans saying he took the liscence lights
  4. If you want used you can get the roll up window rubber out of 97 + Cherokee doors and trim to fit. But crown automotive or team cherokee should have them new .As far as the vent window rubber I've never seen it been reproduced . But someone may know otherwise
  5. It might be to 88 I'm having amnesia lol but 87 /88 is definitely a 203 base pad number
  6. Back to black by mothers . The are available aftermarket also Borg Warner # S219
  7. No it matters which ones you have 87-90 are the same 91 up are 477 pads I believe
  8. You need the 1st design . 2nd has the hub bearing and are later models . 203 should be in the brake pad number .
  9. Thanks for the comments Hornbrod and Girsmj86 like how you kept the factory look Hornbrod . I wanna say looking through the instructions Mitsubishi is written / mentioned somewhere in there. I'll have to double-check
  10. Well I got the flares back home . Gotta better look at them minor chips scratches but no major damage . They were held on with it seems like 100 self tapping screws !! as the original pic showed it has no gas door and they have the typical fiberglass "waves". any other questions I will be happy to answer
  11. I'm not trying to down anyones ideas . The gn motor with a different turbo will run 11s / 12s with very limited work there a v6 instead of a v8 so more clearance for the radiator etc . The op doesnt want a v8 and he wanted a turbo . I'm just responding to what he asked . I like ls motors and big blocks etc but when you're confined to a certain size sometimes it's bang for the buck .
  12. Replied your welcome
  13. Sure do . Could I send it to your personal email? If so could you pm me thanks
  14. Yes, that was one of the part numbers for the three models produced. Do you have any pics of it?
  15. Did you see my post ? The slider is broke it has a 35 .I have vent windows I'm not using . The doors are so so . Let me know I'll call you in a bit
  16. No problem I'm looking hard to find something else worth taking . It's the only one in the yard so kinda wasted trip except the flares
  17. Vin is 1JFT36L7LL162731 the rear slider is broke ,tailgate is gone , the wing is pretty brittle I'll see if it comes off in one piece, interior is trashed, it's has 129 k on it , has a dana 35 axle the bumper ends are holding on by a thread (pieces missing ) and no spoiler in the bed . But yes the flares are here. The cab vents were bondoed over and it has a rear sway bar but not really held on very well with muffler clamps lol. Girs the rear bumper has a baseball size hole in it .
  18. There's no replacement for displacement . Do you consider a Subaru wrx motor a ricer? If so how about a grand national 3.8 turbo?
  19. I was lucky enough to find a rare nos cd player for my truck part# 82300393 sounds great . I converted one of my trucks to power windows and put tweeters in the holes where the cranks went through originally . The dash speakers are kinda tricky to install unless you have the bracketry. I went and bought my speakers on eBay 51/4 cerwin Vegas and 4x6 kickers
  20. For what it's worth I have a ho intake if you decide you wanna convert
  21. As I'm am newer to the forum I'm not trying to stick my head out and get it chopped off . I'm not one to take sides . I will say that if I have a problem with my truck I don't wanna be bombarded with a bunch of "well you gotta rotate the air in the tires" kinda fixes . on the other hand I think carnucks trying to help . I see quite a bit of posts where I have no clue how to diagnose or make an edjucated decision so I say nothing . I do appreciate all the advice/ help though . Sorry for blabbering on your post 88 mj petterson
  22. Ok I'll grab the vin and check on the rear bumper and front bumper ends and what axle it has . Did you want me to pull them or just give you a price ? Where are you at in Ohio ? I'm in Youngstown
  23. Hey Rob . I wasnt planning on taking pics ( don't have my camera ) left it in my jeep in storage . I know I'm retarded lol. But I will get as much info as I can .
