Strokermjcomanche
    6
  1. Right . I think it has to do with another groove being in the key .
  2. Take your old key and have it made at a dealer or at your local locksmith . It will work fine iirc there are some keys that are weaker than others in the style you have . Where ever you go just ask about the strength difference and they'll know what you're talking about .
  3. If I write xj will it turn into the m word ?? Reverse psychology ?
  4. I'd do Cruisers renix tips first . Atleast you can eliminate other potential problems and it doesn't cost anything but some time .
  5. My 88 was under the passenger side of the bench seat
  6. Long story short cequent towing products in Indiana made mine . They had a guy that specifically made "custom" hitches for uhaul. That location has since closed and moved to Mexico . I'm waiting for a callback to see if they still will make these and how much it will be . It better be the same amount I paid last year .
  7. Hey Josh you going to bantams fathers day weekend?
  8. What !!!!! I still have my paperwork showing what I paid to have them make me one I'm gonna call and ream them a new one . I'll let you know what I found out .
  9. Sorry Hornbrod I wasnt aware he had a H.O. The op said he pulled the emissions timer so wouldn't that mean it was not in the ecu ? Never worked on a H.o to verify thanks
  10. You don't have to pull the bulb you can disable the emission timer .
  11. I have them in my 88 pioneer from the factory I'm the second owner
  12. Cool I was just wondering . Seeing as that you're going through all that work sure hate to see you have to replace the floors prematurely .
  13. Did you fix the rust and paint it Before you put the carpet back in?
  14. If you get the right part I'd like the part number please . Thanks Adam
  15. Have you ever lit both gas and diesel separately ? If you light diesel the very top will burn unless under compression if you light gas get ready to run it's like a bomb being the vapors ignite . Being you have a very minimal amount of diesel it's not a big problem it's just one of those being safer than sorry .
  16. What color is it ? The reason you shouldn't use it is normally gas is a red can blue or yellow is for diesel somebody can mistakenly think is has gas , water, diesel , kerosene etc and potentially injure themselves or others . To answer your question it can be used from diesel to gas but NEVER gas to diesel . The gasoline fumes will ignite in the diesel device causing injury / death. Make sure to clean it out well before (if) you switch
  17. Is that whats left of a ford van ? In all honesty I doubt it
  18. Painted to match mirrors ? Is that an option ? Never seen that . I wonder what the extra battery cable is for ?
  19. Forgot to mention they also sell a pressurized spray bottle also I forget the price but it's not uber expensive .
  20. I have a local paint store that will match your interior color and custom make a spray can for you for 20 bucks . Depending on what you're spraying depends on wether you should buy dye or paint as if youre spraying vinyl with paint it might eat away at it .
  21. Iirc I think there where only a couple hundred standard zjs . Depending on how bad the wreck was hopefully none of the rarities got damaged bhfear or k harrod should be able to answer it better as they both have a fleet of em .
  22. I have factory power windows and locks on my truck . Wasn't aware there THAT uncommon . It's sure nice not having to reach over to roll down the window or unlock the other door though .
  23. Yeah I'd be interested pm me withe price/ pics thanks
  24. Some of my friends have been known to put golf balls in their tires to help balance them out . Or maybe try to engineer a way to put a second steering stabilizer on .
